Twitch de la Brat
    6
Posts posted by Twitch de la Brat
  1. +4 on the silver sharpie.
    I love that thing.
    I've used it for hash marks on pvc plastic, cutting marks on black pipe,
    heck, I've even doodled with the thing.
    I love that marker, and I always try to store it tip down.
    I find it makes it last longer.
    I tried the whiteout marker, but it came off too easily.
    Get it wet, or accidentally rub across it once and it's gone. :mad:
    At least the silver sharpie has some staying power. :-\
    Twitch
  2. Ok, I'm currently looking at a little 91 3cyl FWD 5sp Justy that smokes like a
    chimney.
    It goes through about a quart every 80 miles :eek:
    The guy I'm buying it from thinks its the rings.
    He's a mechanic (but not a subaru mechanic) and has experience with older
    ford trucks and the like.
    I'm going to be using it as DD (if my parents will allow another car onto the property :lol:) and want to have as little issue with it as possible.
    I'm thinking a gasket, but I'm not sure.
    Any help or suggestions?
    Twitch
  3. OK, my turn to chime in.
    If it's an auto, BUT its a part time 4wd, you do NOT have to flatbed it.
    You can tow it with a dolly, no problems.
    Just make sure that the drive wheels (front in this case) are on the dolly and
    not rolling and that its not in 4wd.
    And a Tribeca shouldn't have any problems towing it.
    I believe the towing capacity is 2400lbs, or at least that's what SOA says for
    the 2009 model.
    So, to wrap this up, YES you can tow it on a dolly with a Tribeca.
    Twitch
  4. Don't forget a heavy jacket.
    And that looked like a really good list to bring scooby.
    Oh, and hand cleaner, a roll of shop towels, and electrical and duct tape
    is my first aid kit.
    I don't need no antibacterial band aid crap in my kit.
    Twitch
  5. Well it depends upon how deep off road you are planing on going. Soobies are tough, if you break a CV joint, its usually means you have broken some other serious parts too.
    Tow strap, shovel (sharp spade type), gloves, portable air compressor for airing down (and back up). A change of shoes is always a good idea. I also keep a rain poncho in the car.
    ALso you need to bring a friend along or two in another car for deep stuff. I go wheelin alone but am very careful as to where I go and avoid anything iffy.
    nipper
    I concurr with everything nipper has said.
    I would add, that I always bring two jacks of some sort with me.
    Usually my scissor jack and a tall bottle jack (for extra distance).
    A blanket, some 3ft or longer 2x4's for wedging or gapping over a hole or
    for extra lift under the jack, a flashlight, 6pack of your favorite drink (ok, its
    optional, but hey, you're out wheelin' right?) some random garbage for
    extra traction if necessary, a quart of oil (who doesn't already have oil in
    their old subaru? :-p) and a phone that gets reception everywhere. (or a
    two way radio) for emergencies.
    I think I covered all that I bring with me...
    Twitch
  6. I concurr with Mcbrat.
    It sounds like it may have a semi clogged fuel filter or a weak fuel pump.
    Another idea I have is that it may have a leak in the exhaust breather system.
    That will cause the pop gurgle BLAM!!! Backfiring and the like.
    I should know, my brat has this problem :D
    I personally don't mind, I think it makes it sound like a racecar. :-p
    But if it is accompanied with a lack of power (HA! an EA engine
    lacking power, like that ever happens) I don't know.
    Twitch
  7. Ok, I know I sound crazy, but I want to upgrade the engine in my 80' Brat.
    The EA71 isn't enough oomph for my tastes.
    I have had it up for sale for some time, but I haven't had enough interest in it
    to validate keeping it stock for sale.
    Soooooo...
    Back to my original idea, I want to fit an EG33 into the brat.
    I can pick one up for anywhere from $500-$1000.
    I kinda want to make a street racing/drag racing style Gen1.
    Now, you guys knowing more about the Gen1's, what kind of issues am I
    going to have putting an EG33 in.
    Also, I was eventually going to put an STi 6 sp in it as well, so the tranny
    issues would be taken care of.
    Thanks for any suggestions,
    Twitch
  8. I've made a BFH out of a pipe wrench :-p
    And I'm using a breaker bar as a dent remover, in addition to a BFH :D
    But I have made a pair of channel locks into a hose remover.
    Just wrapped electrical tape around the teeth to keep them from
    puncturing the hose.
    Twitch
  9. I don't know if this applies to you, but underneath the spare tire, om the driver's
    side, between the heater core and the engine block are a pair of hoses.
    I had one burst and I had coolant all over my engine.
    That might be what you're looking for.
    You may have the turbo in the way as well, I'm not sure, never seen a turbo
    EA82 before. :-\
    Twitch.
  10. I belive a mod would be necessary for a forester.
    What year is your forester?
    If you check at NAPA or CSK/O'Reilys or Autozone, they should be able to
    get you a higher amp alternator that won't require any modifications.
    Not to mention the forester has a serpentine belt, so you would have to do a
    pulley swap on the alternator.
    Just ask questions at your local parts store, they should be knowledgeable
    enough about the new stuff, that they could get you a proper alternator.
    Twitch
  11. I just installed an alt out of an 83' Caddillac Brougham Elegance.
    It appeared to be a 7157 although it seemed a bit big.
    I looked it over for any stickers or part numbers and all I got was a
    manufacturer number :-\
    It is a large case alt rated to, I believe 80 amps.
    I had to add another plate to my current bracket and shave off some of the
    metal on the inside of the bracket to make it fit.
    I'll post pics as soon as I remember to take them :rolleyes:
    Twitch
  12. I have the same issue sometimes. Try putting it back into 4 high then pulling
    with as much force as you deem necessary until you feel a "clunk."
    If you feel nothing, then I would look at the linkage underneath the
    center console.
    It may also help if someone helped you by pulling the lever while you're
    underneath the car.
    You may be able to see the mechanism and if its working or not.
    Hope it helps...
    Twitch
  13. Feel free to ask!
    We're a family here.
    And as a preemptive strike I'll offer some suggestions on the carb.
    This is a stock hitachi, right?
    Check for any crusty hoses or any missing plugs where there are no hoses.
    Also, carb cleaner never hurt a carb...
    Just make sure the car is off when you apply the carb cleaner.
    And also, clean the outside of the carb.
    If its really cruddy, it may be sticking something.
    Hope it helps!
    Twitch
  14. OK. First off: Year, Model, Mileage, Engine
    And second of all, compress the tensioner.
    Third, remove the tensioner pulley and the tensioner.
    Fourth, route the belt around the lower pulleys.
    Now, it appears that your timing belt has lines on it.
    Line up the lines with proper marks on the cams (the end pulleys) and the
    crankshaft (the center pulley) while their at tdc (top dead center.)
    They should line up just fine.
    All the slack in the belt should be between the driver's side cam
    and the crankshaft.
    Hold everything in place and reattach the tesioner pulley.
    Then just reattach the tesioner, pull the pin, and TAH DAH!!!
    Your timing should be set. :)
    Twitch
  15. Man, that sucks...
    Could have lost the clutch cable retaining nut :-\
    I'm kinda lost on this one.
    Ummm, might have had a tine/tooth on the pressure plate snap,
    and given the history of the hatch, I wouldn't doubt it could happen.
    Twitch
    PS: I haven't forgotten about the 5 speed,
    I've been replacing/upgrading an alt on the brat.
    And fighting it all the way. :mad:
