Olnick
10
Everything posted by Olnick
Just so I can better understand: Even with the hot oil smell the car was NOT exhibiting any of the problems you now have--noise, rough running, vibrations? If that's the case I'd give them one more chance to make good. If they put you off again call Subaru and talk to the Regional Rep (and don't be shy about letting the dealership know that's what you intend to do.) You deserve satisfaction, either with the operation of the car or with their explanation. And it doesn't sound like the latter's going to happen!
Only advice I can offer is stand your ground, be pleasant but persistent. You know your car better than anyone, even a mechanic on a short test drive. Sounds like you're a long time Subaru owner. How long have you had this car? Did you buy it from that dealership? Talk to the Service Manager, explain your concerns just as you laid them out here for us. If he doesn't offer any help, ask to speak to the Manager (or Owner) of the dealership. If that doesn't help, call Subaru of America and contact the Regional Rep for your area. You paid your money, you deserve satisfaction. Just stand up for your rights. Good luck--and let us know how it goes.
Help!!
Olnick replied to kukliani's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Was going to suggest you search but, wow, that pulls up a lot of vaguely related stuff! Here are a coupla' threads that may help. http://www.ultimatesubaru.org/forum/showthread.php?t=40494 http://www.ultimatesubaru.org/forum/showthread.php?t=34734 http://www.ultimatesubaru.org/forum/showthread.php?t=33198 Good luck. -
And, since that's what the code said that's the very first thing you should do. Can make a tremendous difference in your engine's operation. IIRC our '95 Legacies have just one temp sensor--it talks to the computer then the computer tells the temp gauge what to read. Yes, it's a bit of a pain to get to but it is doable. Get a Haynes manual to point you in the right direction. Try to find a friend who has some wrenching ability. Go to an independent shop if you have to. Ask questions here. But by all means replace the coolant temperature sensor. It's $30 well spent. Good luck.
Hi, Gene. (I just love saying that--it sounds so . . . clean!) How many miles on your car? How does it smell like it's running rich--raw gas smell or excess exhaust smell? Have you checked for codes? Might consider replacing your fuel filter if it hasn't been done in awhile. PCV valve too. Also might need to replace the engine coolant temperature sensor and/or the O2 sensor. But I'd start by checking (with an OBDII scanner) for any stored codes. That might point you to a specific problem. Good luck.
