Everything posted by legacy2.5
trans. help
legacy2.5 replied to legacy2.5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks. after driving it more today, i noticed if i shift slowly, it hardly grinds. i think tom. i will replace the fluid, maybe with an additive, and test test drive it. and if i need to i will start to remove the trans. can you see the clips you are talking about through the rubber boot, where the clutch pedal freeplay is adj. ?? Does anyone have any recommendations for manual trans. fluid?
trans. help
i just bought a 1990 legacy 5 speed for my winter car, so i dont have to drive my '97. i picked up for a good deal, and the previous owner said he just had the clutch replaced somewhere. my problem is when i shift fro 1st to 2nd, and 2nd to 3rd the gears want to grind for a second before engaging, and the same thing happens when downshifting. anyone with any ideas???? i had a problem like that with a manual dodge before, and it was fixed by mopar manual trans. fluid. i thought subarus took a regular off the shelf gear lube. Has anyone had a similiar problem with there older legacy 5 speed? thanks for the possible help in advance.
Door Chime
legacy2.5 replied to Reverendray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks. i try to help with enough real world and training that i have. if anyone has any questions ever feel free to email me. i think the problem with the micro switch is removing and re-installing it. jason
Door Chime
legacy2.5 replied to Reverendray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was an import auto dealer tech for over 10 years. As I posted the same type of question 3 months ago with a full description of the problem. the dome light does not go on, and the door open light does not go on in the dash cluster, the door switches operate and test fine, the doors are in adjustment, hinges are perfect, the door latches properly. Now I will tell you what I found out this weekend. A single black wire on the end of th ignition switch leads to a micro switch, which after a long time spent diagnosing seems to be sticking. The micro switch senses the key in the ignition, which will start beeping if the keys are left in the igniton when you park and open the drivers side door. My chimer was going off while driving. because it was sticking it was making the chime go off. Now the chime is in the meter display area near the fuel gauge, but you have to remove the printed circuit board to remove it. So instead of spending the cash to replace an other wise perfectly good ignition switch, and having to get a new one re-keyed ( because you cant get the micro-switch alone ), I elected to cut the negative wire for the micro- switch ( which can be repaired if i ever replace the ignition switch ) I did use a subaru electrical manual to trace wires and look at diagrams to make sure there would be no negative effects on cutting the wire, and there were none. Plus that damn noise drives me crazy in the first place and I dont think I would ever hook it up again anyway. So, as you can see I did attack the root of the problem, I was curious to see if any other legacy owners had a similair problem.
Door Chime
legacy2.5 replied to Reverendray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you ever get an answer about the key chime? i have the same question
99 legacy GT, loss of power
legacy2.5 replied to dDigitalPimp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif i am not mistaking the fuel filter on yours is the same spot as mine, under the hood behind the windshield washer tank. i have been using blended oil which is half oil, half synthetic and priced in between the two.
Engine light and fuel system pressure
legacy2.5 replied to ashton_subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you hooked your computer up to a scanner to find out what code is being set. i would retrieve the code and go from there before you just start replacing parts. once the code is pulled you will have an idea where to start looking.
need some ideas about a front end noise
legacy2.5 replied to legacy2.5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy frustration level is ok, i work on cars for a living (nissan). i had the rims on for the last 1 3/4 years with no problem till recently, but i will check the mating surfaces, i did not notice anything out of the ordinary the last few weeks when i keep tearing the frt. wheels off. thanks for your help, at this point i am open to all suggestions.
legacy2.5 replied to legacy2.5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi thought the rotors might be the problem, so i replaced them with brembo slotted rotors, noise still there, i used disc brake assy. lube , i lubed all the contact points and installed the guide pins correctly, caliper is free and floats normally
legacy2.5 replied to legacy2.5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1997 with 95,000
legacy2.5 replied to legacy2.5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe noise was there before i updated the brakes. see, i was saving some cash to upgrade the stock brakes, but i noticed the steering wheel was vibrating some i resurfaced the stock rotors, after that i started becoming aware of the noise. then i just ordered the rotors and pads, noise was still there, then replaced guide pins, caliper mounting bolts pad retainer clips, lubed eveything up, noise still there. inspected front suspension and founf one outer tie rod end seeping a little grease, with the mileage i had i just went and bought a loaded subaru rack so everything was new. have not tried to downshift it because i can only hear it when i just about to come to a stop, the noise a clicking/creaking type noise is rythmic (rotional type noise?) starts to slow as the vehicle slows. i just added pics of my legay gt to the readers rides
legacy2.5 replied to legacy2.5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi was thinking that too, i just could not figure out how come it only happens when hot would apply to axles, but i am open to that also, thanx
i have this strange noise and after replacing a few parts still cant fix it. so heres the deal, i have this strange clicking type noise coming from the front end only after the brakes and vehicle are hot, after repeated braking, and goes along with vehicle speed (1997 legacy gt). i can here it when braking 15 mph and under, it goes away when i lift my foot off the brakes, and did i mention that the vehicle need to be warm and only start after repeated braking.. i have recently installed brembo slotted rotors, ebc geen pads, all new brake hardware from the pad clips to the guide pins, and mounting hardware, the caliper pistons are not sticking, the brake fluid is fresh, and all the lines have been flushed. the noise was there before i installed all the new brake hardware. i just put a new subaru rack in today with brand new inner and outer tie rod ends. it was doin this with the old rack in it. the steering universal joint seems ok, i had someone shake the steering wheel back and forth while i held the universal joint and and i did not feel it binding and it moved freely when it was loose from the rack today. the front suspension is fine ie: struts, springs, ball joints, there is no movement or play. the nopise is not coming from the motor. i was wondering if anyone has encountered this before, i am a technician and either me nor any tech can figure it out. the car has never been in an accident, the alignment is in spec, the wheels are tight, the motor mounts are good. i was thinking either a front axle is starting to go?, a bearing in the front diff is starting to go? (it happens if the trans is in neutral, its an auto). the fluid in the front diff is still clear and was changed maybe 15-20 thousand miles ago, i was thinking maybe the diff fluid is heating up and causing a slight bind under load. i talked to some subaru techs and they cant really think of anything after i told them the symptoms. the car seems to drive fine. if anyone has any ideas it would be helpful. i think i got all the symptoms down, but ask away and i will try to answer them.
Shift Lever will not release
legacy2.5 replied to DiscoStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi would check the shift interlock assy.
Newbie Intro and ? about A/T
legacy2.5 replied to Labguy1970's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfind a shop that has a tranny flush machine, i made a post about this a few weeks ago. fully flushing the tranny is the first and cheapest place to start.[ QUOTE=Labguy1970]Hi,my name is Jason and live in Asheville NC, I'm an Organic Chemist and car hobbiest. I've owned many a subaru from my 84GL wagon to my 2000Outback Limited, and I think they are great cars. I also restore 1st generation Toyota Celicas(1971-77), so I've got a fair amount of mechanical know how. I'm posting for two reasons; to say hello and to ask about a problem I'm having with my 2000 Outback's auto transmission(wife's choice on the A/T:-\ ). The problem I'm having seems to come and go. I'll drive around for a while, stop and turn off the car, do something, get back in the car to go somewhere, and the transmission will not go into forward gears(it goes into reverse w/o problem). I've checked the fluid and it seem to be foamy, so I had it flushed, and it worked fine for about a month. Now it is doing it again. I can put it in gear and rev the engine to about 4k and then it will slowly engage and I can drive(this happened to me @ HomeDepot yesterday). Has anyone had this problem and/or have info on what might be happening? Thank you. Jason
AT Selector Light
legacy2.5 replied to jp98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmine shifter is mounted in the center console. 97 legacy gt
AT Selector Light
legacy2.5 replied to jp98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou have to remove the center console cover, the shifter handle, and the cover for the shifter ( the part with the trans indicator. the bulb is on the side underneath the indicator cover
'04 WRX, Some Vibration at 67MPH+
legacy2.5 replied to pugelly's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry to find a shop that has a hunter wheel balancer that has the capability to road forcer your tires. it basically measures the pressure of the tread on the road and if needed has you move the remount the tire to a different part of the rim. a lexus or infinity shop has this stlye machine because they are more strict than other companies on there raod force measurements. i know th nissan dealer i work for has this machine. I own a '04 WRX with now 3500 miles on it. Since I bought it (never noticed one test drive) it vibrated in steering wheel moderately past 65MPH. They rebalanced tires, test drove and did not work, swapped wheels from another new WRX, same thing. They ordered new axles and a the vibration has lessened to slight to occasionally above slight. They recently rebalanced the tires whcih made no difference. I noticed that in the morning, when first driving, it does a similar feel in the wheel. The next step is ????. I was thinking I will be due for tire rotation and maybe this will help and point to the existing tires or rims?? Thanks
Intake
legacy2.5 replied to Skanky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXan internal combustion engine will not make enough p.s.i. to compress water.
Intake
legacy2.5 replied to Skanky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have replaced many hydrolocked motors in my years of working om cars for a living and i have seen and replaced rods, valves, pistons, blocks, broken cams, all from hydro-locked motors from sport cars to little economy cars. i have said it before to many people on here go on "theory" on this site, insterad of listening to people who are trying to help.
Intake
legacy2.5 replied to Skanky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsubie gal, nice to see someone else who understands how in internal combustion engine works. you cant compress any liquid, and any given part of a motor will break/bend when you try.
AT Selector Light
legacy2.5 replied to jp98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is a light. i had to change the one in my legacy a few months ago. its pretty easy to change yourself, you jst nee a phillips screwdiver. if you need some help let me know.
2005 GT ECU Upgrade?
legacy2.5 replied to Baldwin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi am looking for an e.c.u. upgrade for my '97 gt. any help would also be appreciated.
Need recommendation.
legacy2.5 replied to photo2001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have seen plenty of vehicle's come in for service with a check engine light on ( for a small evap leak code ) because the wrong gas cap was on the vehicle. just nake sure you get a cap that fits your vehicles spec's.
Why do my antilock brakes activate when they should not?
legacy2.5 replied to bertherr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhey, i sent that info on pulling your abs codes to your email
