Everything posted by Mark-O-Back
Need Mechanic in Seattle-area! (kirkland)
Mark-O-Back replied to salamandaark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can't say they're the best but I have been happy with my dealings with Superior Repair. That's over ten years for the big stuff. Not a charity shop but no doubt they have low overhead when you see the place. Don't panic. I don't regret trusting "Those Subaru Guys" At least consider them for another alternative. Here is a link: http://www.superiorrepairseattle.com/ I've also gone to Walker's, the dealer in Renton, someone else's dime there though. Big shop, loaner cars. Job done.
New Radio in 2009 Impreza Sport Wagon
Mark-O-Back replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had HD radio in my Subaru for about 5 years. The sound is noticeably better than standard FM. Signal to noise ratio, dynamic range, channel separation are all improved. I liked it so much I bought an HD tuner for my home too. No reception trouble throughout the Seattle area. I live about 30 miles south east of the city. A plus is many stations have additional content on sub channels. Also you get text info like station call letters & show name. For music they can send the artist and track information. I agree it's worth the cost if you're area has the stations. Check here (http://www.hdradio.com/find_an_hd_digital_radio_station.php) I think HD radio is going to grow; for instance the new zune players have built in HD radios. Highly recommended.
Conversion kit for '99 Forester radio
Mark-O-Back replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.crutchfield.com/p_120988999/Dash-Pocket.html?search=pockets
1997 Legacy Gt 2.5 Power door locks
Mark-O-Back replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have to hold the unlock button for about 3 seconds for all the doors to unlock. For my 97 I noticed this feature starting to fail. The driver door would unlock but the rest... maybe if I was patient. The solution for this was a new battery for the remote. I figure that the battery was so low it could not maintain a signal for the 3 seconds. I measured about 5 volts on the battery at that time. It is a 12 volt battery new. (type 23A) Mark
Brain Teaser
Mark-O-Back replied to Hotshot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could connect blue square to "+12 on with ignition" for the daytime running light. Will ground through the high beam bulb, be on with the low beams and go out with the high beam. Be like a new car! Now where's Cougar to show me the error in my thinking? Could it be that easy? Nipper?
Brain Teaser
Mark-O-Back replied to Hotshot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Blue light is probably a daytime running light. You didn't have one. Connect GND to the red square. Connect +12 Low to the white square Connect + 12 High to the Black square The lights will work. Do I win? :-\
pic of pvc valve location '95 legacy
Mark-O-Back replied to gohawks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBe sure to check the hose that attaches to it. It can get clogged with stuff too. Mine was down to a pin-hole at the PCV end.
2005 Baja Stereo in 01 Legacy?
Mark-O-Back replied to RedRum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor this thread I attached a pdf for stereo install that may be usefull. Since you asked for pointers. http://www.ultimatesubaru.org/forum/showthread.php?t=66532 Good Luck ~ Mark Look for the dog
Fan won't blow
Mark-O-Back replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are more fuses to check under the hood. Take a look near the battery in a box. ~ Mark
Bar's stuff any good for cracked block?
Mark-O-Back replied to eseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- Rear window washer fluid diagnostics??
Mark-O-Back replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt could be a simple as low washer fluid level. As the level drops the pump for the rear window starves first. That's how my 97 goes anyway. ~Mark- What's wrong with this picture?
Mark-O-Back replied to Hondasucks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXObvious... Loose nut behind wheel I see a asymetrical gap on the right side of the air bag too.- What's wrong with this picture?
Mark-O-Back replied to Hondasucks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you bring the car into the office, literally? I see files :cool:- How to get 40+ amps on the roof.....
Mark-O-Back replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's an idea. Does you car have a mast anntena on the roof? With a plastic fitting about 1.5" long. If so you could drill a hole in that and go out there. Use a grommet or something around the wire to keep water out. Repair to stock would be a new plastic piece or a chassis plug in the hole. ~Mark- 97 Legacy Transmission issue
Mark-O-Back replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd be worth it to be back in shape. Thanks nipper, you have eased my anxiety. Good job, not easy to do 8-900 I can do... 3200 big ouch! ~Mark- 97 Legacy Transmission issue
Mark-O-Back replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's great, thanks. The cynic in me still wants the rest of the story. The optimist too. Greenwood near where I grew up. Bet it looks smaller now. ~Mark Hey I'm # 253, not so new...- 97 Legacy Transmission issue
Mark-O-Back replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOpus, is she in the Seattle area? If she has found a good shop please name it. I have a 97 that occationally gets the flashing ATF Temp light and torque bind. Trouble looms. I called a local dealer, car's been there before, told 800 to 3200 bucks best to worse case "might want to trade her in 'as is' on a new one. It's month end and we're dealing" 97 may sound old but she's earned my respect and all. Was good as new till this problem. So if you've found a good tranny shop I want to know! I know the feeling of long distance car repair for a loved one. I feel for you brother :cool: Best of luck and be sure to post as the saga goes on. ~Mark- New radio install problem
Mark-O-Back replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX12V across a fuse means it's blown. Arrgh!But you had looked at it so weird is right. But on the bright side this thread has me determined to fix my car's faulty lighter outlet. Hope the tunes are sounding good for you now! Mark- New radio install problem
Mark-O-Back replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was wrong that [15] is not a fuse. F45 & B62 are connectors. 15 is the pin number. I have been studying my PDF copy of the electrical system and I'm noting F45 is a 20 pin connector that is somehow connected to the main fuse block (underhhood) I'm not sure but it seems to be at the firewall. There are many things (20 I guess!) that are run through it. I would follow the wire bundels to find a two row 20 pin connector.Pin 15 is just left of center on the bottom row, facing? the mating end (I think) Could be this conection is loose and all you need do is find the connectors and press them to. I can email you the PDF, 92 pages (5,367KB) for the 97 legacy. Send me a PM with your email address and I'll send it off to you. Mark- New radio install problem
Mark-O-Back replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe what is a 15 amp fuse. The where is ? Have you looked in the fuse panel inside the cab? Maybe there. I believe there is a fuse block along the kick panel on the driver's side. Short of that if you can't follow the wire, do try, a new wire run as you suggest would work. Put a 15 amp fuse in line to be sure. I would think that Subaru would not hide the fuse too much so look around for it as that is the best way to fix this problem. Good luck! Gotta have the radio! Mark- Pair of windows won't go down
Mark-O-Back replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 97 has the kid proofing disable switch on the driver's door. Does your 96? Since the switches act on the ground side that ground must be routed through that switch, likely on a single wire. I'd check that switch and wire(s?) Let us know how how it works out ~ Mark ... Uh well I walked away thinking this post over and realized that the "kid switch" stops the action both up and down. Oh well, still curious at what you find.- Line in on stock stereos?
Mark-O-Back replied to BushmasterSI's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet one of those cassette car kit adapters. It goes in like a tape but has a cord with a 3.5mm plug at the end. I used one of those for years in my 97 until I upgraded to a (much) nicer head unit... no weather band though. You can get them still at many places, electronic stores. I've even seem them at NAPA. Good Luck, ~Mark- replace speakers
Mark-O-Back replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis may help. If I did this right! ~Mark 1stGenCrutchfieldMastersheet-Official.pdf- Oil level: overfill?
Oh no, engine off. Let it sit a little while, engine off, then check as I outlined. Also the little oilcan icon on the stick should be right side up as viewed from the front of the car.- Oil level: overfill?
To get a good reading on the dip-stick make sure your Forester is level. Then I've found that you take the oil filler cap off first then pull the stick, wipe it and then check for the oil level. Oh yeah you have to run the engine to fill the filter before the first oil level check. Try it. ~ Mark - Rear window washer fluid diagnostics??
