Warming up the engine on cold days?
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLetting it warm to normal operating temp shouldn't cause any harm per-se, but it will burn up more gas. I give mine about a minute or two, but drive it easy until it reaches operating temp. Everyone has their opinion about this, but any warm-up is 100 times better than a jackrabbit start.
Tranny pushing ATF thru vent tube
Fairtax4me replied to Lindaw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds good! Hopefully it lasts longer than the rest of the car!
driving without a hood - or vote for which way to transport
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell then, If its legal in VA, I don't see any reason it would be illegal in WV.
Another engine crank but wont start case
Fairtax4me replied to vincentmoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck fuses first. Then check for spark.
oxygen sensor problem
Fairtax4me replied to lushy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad to hear you found the problem! Car looks great! Are those some kinda huge canons in the background?!
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see people do it here all the time. Pretty sure it is illegal in VA though. IF it won't fit in the back (I'd be willing to bet it will), strap it to the roof. Shiny side up just like it would be if it was mounted to the car. Might need to remove the safety catch if it has one.
Input on minor tune for 98 Outback, SAN DIEGO
Fairtax4me replied to ferox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust about any parts store will Scan the CEL for you in hopes that you'll buy the part to fix it while you're there. Honestly though, I don't see what you're worried about. If he drives it every day anyway, do an oil change and hit the road. Its a Subaru. Barring catastrophic failure (head gaskets, timing belt) it'll run just fine for the few days you'll spend on a road trip. Anybody wanna guess on the code? P0420 if you're lucky, maybe P0325 if you're not.
Best Oil Catch Can / Oil Separator Set-Up's
Fairtax4me replied to CFK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are some easy options for homemade setups if you want to save some coin at the expense of aesthetics. The most popular that I've seen are coffee cans filled with any number of different types of "filter" media. Usually one or two chambers full of stuff like a fine mesh type of material such as those copper kitchen scrubbers, hardware cloth, or expanded sheet metal. Then another chamber with cotton or paper air filter media, with some room at the bottom for runoff and a drain plug. Using a PCV valve attached to the side of the container would keep liquid oil from being sucked into the engine. The basic idea is that the breather hoses are routed to the can, along with a source of fresh air. The PCV hose draws any leftovers out and burn it in the intake stream. You can design your catch to just introduce the drippings back into the sump to be circulated with the rest of the oil, or manually drain it at each oil change. Screw emissions. The most important reason for having a crankcase ventilation system is for air to circulate through the crankcase and pull oil vapor out. Oil vapor will collect in corners and turn to sludge. The vapor is mostly oil that is full of contaminants, such as water or gasoline, which have a lower "flash point" (boiling temperature). For the most part whatever "oil" is in the vapor is too far degraded to protect the engine properly anyway, so discarding it can prevent wear, but in small quantities, it does no more harm than starting the engine when it's cold. Proper oil change intervals will vastly decrease the chance of wear. A larger PCV valve by itself will help keep blowby to a minimum, by providing a larger source of vacuum to carry vapors out of the engine, preventing them from being forced out through the breather hoses into the intake. Search for Homemade oil catch can on google and you'll get like a million hits. NASIOC has a nice FAQ about it too, specifically for subaru.
97 Legacy GT Trans noise
Fairtax4me replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat would be great if that's all it is! Not sure what sounds a starved pump makes, but that's definitely worth looking into.
Fairtax4me replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot that I know of. There are some transmission additives out there, Stop leak, stop slip that kind of thing, But none that really get rid of noises. If it's full of air it can make some noise. If the fluid level is too high it will cavitate and the fluid will foam. Foam causes problems in power steering pumps. A trans pump works basically the same. Do you check the fluid level with the engine idling, warm, in park, after shifting through all gears?
Hayward&Scott - don't buy their stuff...doesn't fit!
Fairtax4me replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow, That really sucks! I'm pissed just reading about it! That's a lot of damn money! How do they mess that up though? It's not like Subaru exhausts are any different between any of the N/A engines are they? Except for single vs dual port anyway.
new girl!
X2. If you have any male friends, one of them will have or will buy a video camera to make a video of a girl doing a burnout.
Fairtax4me replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDO NOT PUT FRICTION MODIFIER IN AN AUTOMATIC TRANSMISSION!!!!!!!!!!!! :eek::eek: Friction modifier is designed to allow clutch type limited slip differentials to slip EASIER. It WILL destroy the clutches in an automatic trans. Think a few letters got cut off the end of your link URL. Was this the video? you linked? http://www.youtube.com/watch?v=H5gZZqr3********* That noise, if it is being cause by the transmission, is likely the fluid pump. This is often caused by incorrect installation of the torque converter after an engine or trans removal. The trans might be hosed anyway. But there are a few other things that can make similar noises. Pulleys will whine if the bearings go bad. You can remove the accessory belts and start the engine to determine if any of the pulley bearings have failed. Timing belt idler bearings. These area bit more involved to check but they do often fail on engines with over 100k miles.
cleaning the engine
Fairtax4me replied to LanceDa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think he meant to use just ATF. Just replace one quart of oil with a quart of ATF. There are other additives that work as well. Seafoam, MMO, Gunk motor flush, I think Lucas makes a cleaner now as well. See post #5.
replace ignition switch
Fairtax4me replied to jrt2nd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't have a thread but you might find it in the FSM here: http://www.ludicrous-speed.com/automotive/impreza/fsm/Impreza_2005/
cleaning the engine
Fairtax4me replied to LanceDa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFull synthetic is far and away better than any of the high mileage synthetic blends. It has all the same detergents and conditioners, but lasts longer between changes. Just stick with the full syn. edit: You can find out anything and everything you ever wanted to know about oil, and then everything you don't know about it, at http://www.bobistheoilguy.com/cms/
new girl!
Awesome! Now make a burnout movie and post it up!
cleaning the engine
Fairtax4me replied to LanceDa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKerosene is too thin to protect the bearings and such. Mix it with a couple quarts of non detergent oil and it works great. But don't smoke around it. Diesel works good too. But with all the new oil mixes available today, all you really have to do is change your oil. Most of the "High mileage" mixes on the shelf at you local parts store contain cleaners that will remove and prevent sludge and varnish buildup. Combine with a quality filter such as Wix or Mann, and in a few changes (which you would have to do anyway) you have a squeaky clean crankcase. It won't get out everything, but neither will any of the other home brew or store bought mixes to clean engines. Short a complete tear down, its the next best thing.
2006 IACV cleaning question
Fairtax4me replied to jkb_6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat engine and transmission do you have? Sloppy idle and sluggish acceleration point more toward a vacuum leak. But periodic cleaning of the intake system and throttle body will help keep things running smoothly.
about to do a clutch
Fairtax4me replied to shin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat he said. ^ Separator plate kit: http://subarupartsforyou.com/cp_partdetail.php?partid=11564
Engine vibrations, who has them?
Fairtax4me replied to Ross's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, that sounds like a the flywheel is too light. You will get some "chugginess" below 1500 rpm under load. The weight of the flywheel will affect clutch engagement from a standstill more than anything, but you will also feel the effects of the lighter weight at lower rpm. Why it shakes the car probably some kind of balance issue, but if it's livable, then like you said it's not worth pulling the engine again to change it. There are people on here who swear by Delta Cams for getting more bottom end grunt out of the EJ. It might be something worth looking into if you have a lot of hills to traverse.
Meet the new ride
First glance at that I thought it was a Corolla! I gotta go to bed! Congrats on the great buy.
Fairtax4me replied to Ross's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, I was thinking along the lines of the buzz. Not sure, that might have something to do with the weight of the flywheel + clutch assembly. The 2.0 clutch assembly has a "pull type" pressure plate, while the 2.5 (non turbo at least) are "push type". Of course I can't find any flywheel weight specs for either. Mileage sounds good for easy mixed driving. I'd expect approx ~30 mpg at 55-60mph. Might do better if driven right. 2900rpm seems fast at that speed. You got 4.44 FDR?
Fairtax4me replied to shin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, you're better off to pick the engine than to drop the trans unless the trans needs work. You can R&R the trans by yourself, but it's 100 times easier with a helper. Get a set of exhaust manifold gaskets. Replace the release lever. It's cheap (like $25) and they tend to crack with age which will prevent the clutch from disengaging when you push the pedal down. And if the separator plate hasn't been done before, definitely change it. edit: Steer clear of lightweight flywheels for road use.
Fairtax4me replied to Ross's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it a shaky feeling like a misfire, or more like a buzz type of vibration? Didn't knock a heat shield loose by accident did you? There are some rubber dampeners that go between the transmission mount brace and the cross member, are they in good shape?
