Fairtax4me
  1. Look like Toyota of Honda wires to me. Do they have a part number on the box they came in? Subaru wires in 97 I think they had 2 different types for coil packs for that year, but they were still mounted in the same place. All 4 wires should be the same or close to the same length. And the spark plug ends should be the same. NGK 97 GT 2.5 wire set at rockauto.com. That one is for the female end type coil. The other wire style is for the male end type coil. But the plug end is the same.
  2. Awesome! Thanks! Looks like Team Dynamics Pro-Race 1 is the winner. This is it to a T, just one less lug hole...
  3. Lambda or Lambda-sonde is an oxygen sensor. If it does this when the engine is cold the O2 sensor is not the culprit, although it probably won't hurt to replace it at 245k km. I think you have... A vacuum leak. There should be a diagram on the bottom side of the hood detailing the vacuum hose routing for the engine. Follow all of those hoses (there are only a handful) and make sure each one is connected securely, free of cracks, splits, and general dry-rot. Did this problem start immediately after the LPG conversion?
  4. Rust, maybe. He lives in AK, don't know if they salt the roads like it's going out of style the way they do here. But suspension parts will be well worn, wheel bearings, U joints, engine might be worn out, transmission, anything that moves basically, will almost certainly be ready for overhaul or replacement by 250k miles. So you either dump a ton of money into it on parts, sell it to someone else who wants to, or scrap it.
  5. O2 sensor don't work when it's cold. Has to warm to about 600°F before it has any effect on fuel delivery. Have you checked fuel pressure when cranking when it does this? A bad crank sensor won't make it sputter slowly to life. That will get you either all or nothing. You got a fuel issue. This is OBD1 we're talking about here. The car could be on fire and it wouldn't throw a code.
  6. I thought OZ Racing when I first saw them, but the similar styles I can find aren't quite the same, and don't come in a 15" size. They're 15x7". Feel fairly light weight. Stock sticker on each with "5M1-570485100", (which yields a big fat 0 results searching on Google) "Made in UK" Iso9001 cert., and a picture of the British Flag. Any ideas?
  7. People forget that these have a differential stuffed underneath the gear case, and diffs are much more susceptible to damage from old gear oil. But differential failure in the MT is much less common than the main shaft roller bearing failure, and the guaranteed worn out synchros. It won't hurt, but it probably won't help much either. You get 100k more miles out of it and by then the rest of the car will be worn out just as much and ready for the scrap yard, or to become someones weekend off-road basher.
  8. Do this. Drive down a back road somewhere not to far from home. Something not busy with traffic, where you can run 40-45mph safely. In 5th gear, at about 40-45mph, push in the clutch, push and hold the gas pedal to the floor, let it rev up to about 5000 rpm then drop the clutch, Right foot still plastered to the floor like your life depends on it. Heres what should happen. It should jump, kick and lurch around, but engine speed should immediately drop back to running rpm for that gear at that speed, roughly 2000 rpm. If engine speed does NOT immediately drop, it slowly rides back down over the course of several seconds, or stays at 5000 rpm or goes higher, and it makes the same screaming noise, the clutch is bad. The other good clutch test, which is more for older stuff with metal bumpers, is to pull up to a big tree and set the parking brake. Rev the engine and drop the clutch in 4th gear. Car stalls right away, clutch is good. It keeps running, clutch is bad.
  9. You can check all of them. That's probably not the cause of your shake though.
  10. Every parts listing I have seen says the 2.5 and 2.2 clutch disc are the same size. I haven't seen dimensions for the pressure plate, other than a few that list clamping force, which is higher for the 2.5 plate. The dual mass flywheel is quite different, and so is the pull type pressure plate used with it. That setup is larger, but only available on the STI as far as I know.
  11. I've always had the opposite. Clutch slips in higher gears under acceleration, or if you go fast enough, just trying to fight the wind, before it will slip in lower gears. I wanna say clutch. If you suspect accessory belts, remove them and drive the car around the block. It won't hurt anything, unless your battery is dead, or you aren't strong enough to turn the steering wheel without power steering.
  12. Any EJ flywheel will fit on any EJ engine. The only real difference between them being weight. You want lightweight so any EJ lightweight flywheel should do.
  13. If the rear main is dry don't even think about touching it. Metal oil separator is probably worth resealing if it looks like it is seeping or has any wetness. Pedal down, neutral or any gear it makes no noise, correct? Pedal up in any gear it makes noise. Pedal UP in neutral does it make noise?
  14. Motor mounts, transmission mount, pitch mount, any of those being worn will transfer excessive vibration to the chassis of the car. Is this a shaking feeling or is it a buzz vibration?
  15. I don't have any info but have you tried asking over on Subaruoutback.org? They tend to have a bit more info on the "newer" models.
  16. I dunno what a used cat goes for. I'll have to check it real well and make sure it's not plugged up. It's in great shape on the outside though. Thanks for the tip Ericem.
  17. No "special tools" needed. Nothing you can't do with basic tools and a little ingenuity and knowledge. Ej25s are cheap because they puke head gaskets, and eat rod bearings like candy. Most people here do Ej22 swaps when the 2.5 bites the dust.
  18. Made a nice pick on CL today. Saw an add for Subaru parts and sent an email. Ladies Ex had split for Cali and left some junk behind taking up space in her garage. She wanted it gone. Four stock struts, four stock springs, TMIC, and cat pipe all from an 06 or 07 WRX. Four 15x7 after market aluminum wheels, a set of plastic wheel ramps, a 15qt drain pan, and a Duralast roller creeper. All for the price of..... $100 Gonna put some pics up later. I'd like to try to identify the maker of the wheels. Stickers on them just say "Made in UK", and have a part number. No manufacturers markings anywhere that I can see. One of the struts was blown, (reason for replacement I bet) But the other 3 appear to be in good working order. And since I have no real use for them they'll probably be in the Classified section before long. The cat pipe and intercooler are in good shape, except it would seem a mouse used them for storage and left some seed husks and acorn shells inside them. At least on the Cat it was on the OUT end of the pipe. Not sure how cleanable the IC is. Ideas?
  19. Corrosion is inevitable. Corrosion on the mounting bolt shouldn't be the cause of a misfire, but clean it again just for giggles. And coating it with anti corrosive paste or spray should help keep corrosion to a minimum. Improper plug gap or a weak spark from a failing coil pack could be possible too. A lean mixture creating spark knock would cause the knock sensor to retard ignition timing. Turbo engines are very easily damaged by spark knock so it's not hard to imagine the knock sensor could retard spark so far to cause misfire. A bad O2 sensor could cause misfires as well. What are your ideas for the fuel mileage? What mileage is on the car?
  20. Statistics. Overheating means certain death for the EJ25. The possibility of damage is more certain than the possibility of no damage. It's a complete waste to pay money to have the head gaskets replaced, then have it toss a rod through the case in 500 miles.
  21. A constant squeak? That won't be a differential. Got 4 jack stands? Get all 4 wheels off the ground and put it in gear. Walk around and find the sound.
  22. If it works, the it's fine. No wobbles means it's all in perfect balance and you can go on about your business. Change that timing belt ASAP though. You're riding on borrowed time, and when the clock comes to collect it ain't pretty. "TheImportExperts" on Ebay timing kits are the cheapest and best route so long as you get the complete kit. Belt, idlers, tensioner, water pump. The seals are cheap enough from a dealer, and the OE quality means there is much less chance of a leak.
  23. Welcome to the USMB. It sounds like your local shop isn't a Subaru specific shop. Or they would have known that you just can't use an after market thermostat in a Subaru. It has to come from a dealer, any else is just not going to work properly. The engine doesn't have to be removed to change the valve cover gaskets, and all of the seals in the timing belt area are easily accessible with the engine still in the car. Thermostat and an improper bleeding of the cooling system will lead to overheating. Unfortunately, as was mentioned earlier, overheating is very bad for the 2.5 engine. It's like a snowball effect after that. You mildly overheat it once, that's fine. Twice is pushing it. The head gaskets will be compromised, which leads to more overheating, and eventually to rod bearing damage. There is no real way to tell if the head gaskets have been damaged until they start leaking. But if they are leaking, it will show up in a block test. Bearing damage can be determined by an Engine Oil Analysis Test. A sample of oil is captured during draining and is sent in to a lab where they can determine if there is excessive copper in the oil, which would indicate bearing wear. But, all of this is directly related to the work the first shop did. Had they known what they were doing this could have all been avoided. I'd be having a firm conversation with the manager and the owner of that shop ASAP, asking why the valve cover gaskets you just paid to have changed are still leaking. I'd also be pressing the issue of the potential damage done to the engine. Not for a new engine though. I'd be wanting back every penny of what was paid to them for the work. If they won't co-operate, I'm sure the Better Business Bureau would be happy to file a report about this. And a nice "thank you" letter from your lawyer might help get you some leverage. What they did to your power steering, I have no idea. I wouldn't have driven the car that way. And the fact that they even let you leave with the car in that condition doesn't sit well with me. I only wish you had found the site before all this. Plenty of honest and knowledgeable members on the board here along the west coast who could have done the work for much less $$ and you wouldn't have any problems afterwards.
