Nav in a 2008 OBW - worth it?
Fairtax4me replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgreed. For the most part, factory Navi systems (on any car) are a waste of time and money, expensive to update, and difficult to use.
No spark on one side of coil pack
Fairtax4me replied to murphywd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFSM pinout for the Coil has only 3 wires. One (yellow) is power with ignition run/start. The other two (Red w/green, Blue) go to the ignitor module through connector B22. It's a large grey 16 pin connector on the passenger side top o the bellhousing. Check those for continuity. Visually check the wiring for cuts/cracks in the insulation. Also check all the connectors (especially B22) for corrosion/dirt in the pins. Spray them with some contact cleaner to ensure cleanliness. Sometimes unplugging and plugging them back together a few times get's them cleaned up. The Crank and Cam angle sensors can only be checked with an analog multimeter or Oscope. Doubtful it's either of those since the ECU would not see the signal it wants from those sensors. I would think it would not fire at all if that were the case.
Fairtax4me replied to murphywd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWill it start at all now? Is the "new" coil pack brand new or used?
Too much vibration with brakes applied in DRIVE at stoplights.
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm still skeptical, but I don't think we can discount the fact that multiple people are having problems with excessive vibration when sitting still after replacing axles. This seems to be limited to only automatic transmission vehicles. So maybe it has something to do with the axles being under load? Gonna ask some of the guys at the shop if they've heard of anything like this.
2.5 dohc the engine I love to hate and love again
It's actually a very common practice. Some engines it works out fine, others not so fine. Personally I've seen it cause more problems than it prevents. Especially in the case of the new style MLS gaskets, which already have a thin coating of sealer on them. From Cometic's FAQ section: More information about Viton based compounds can be found on DuPonts website. Another problem... Dust. Dust will not stick to a dry gasket. It will stick, and glue itself, to a gasket covered in wet spray on sealer. Now your average household dust, in small quantities, isn't a big deal. But if you're doing this in a shop or outside somewhere and you have pollen or other "large" (in comparison) particles of various types of dust flying around in the air... you can see where this is going. Dust gets between the gasket and the sealing surface and creates a pocket where air can be trapped, air expands and contracts with heat cycling. If the pocket is near the combustion chamber seal ring, it will eventually open a path for combustion gases to get under the gasket, and after that it's all over. Sealer gets burned out, gasket gets burned out, leak begins.
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm going to read up on that axle stuff tomorrow. Incorrect axle length is an interesting theory. I just can't concentrate on it enough to read through the multiple threads right now. Need to make a few of these first... zzz
96 2.2 motors
Fairtax4me replied to plodder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not that hard, but it is good to have some experienced guidance. There are a handful of members up there in the PNW that have more than enough knowhow to teach a novice a few tricks. Whether they are willing is a whole other story. :-p
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a common problem on many 4 cylinder engine vehicles. To an extent it is considered normal on many cars, Saab, Toyota, VW, anything with a 4 cyl engine, most of the time FWD, but some RWD cars will do it as well. Most of the time (when excessive) it can be attributed to incorrect (too low) idle speed. Cleaning the intake and idle control system may help. It can also be caused by incorrect cam timing. A worn/stretched timing belt/chain can cause the timing to be off by just enough to create problems at idle. Ignition timing is another cause of this, but the ECU controls the timing on all modern cars. No adjustment there. You can check it to see if it is out of spec, but that's really kind of pointless. I fail to see how an axle would cause this, unless it's flat out broken. The axles don't move when the car is sitting still. No movement, no vibration.
ice build up, 96 outback
Fairtax4me replied to goof_ball's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think I know what you're talking about. Last year I had some ice down on top of the rocker panels that would freeze the door shut at night. I figured it was from me kicking my boots against the rocker to knock the snow off before I got in the car. Might have come from somewhere else though. Didn't pay much attention to it honestly. Just learned to knock it off with the scraper when I parked the car for the night.
"ringing" goes away when a/c on
Fairtax4me replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAccessory belts are supposed to be done every... 60k these days? Of course they can usually go for longer, but most of the time they start screaming after a few years. Yours has done well to still be in one piece after 6 years. I'd bank on the belt first. If that doesn't fix it then Ac compressor pulley bearing is probably going bad.
Looking for new (used) Subaru Outback!
Fairtax4me replied to Jaimesbeam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might be able to get PO info from a Carfax report, but I'm not sure (never bothered to try). Piston slap is benign. Every 2.5 does it. Pilot bearing is not a big deal. I think you meant the Throwout aka Release bearing though. Again probably not a huge deal, unless it really starts screaming. A friend of mine has had one whirring in a Volvo 240 for 125k miles. The rest of the car has worn out, TOB still sounds the same.
Light Weight Parts and Fuel Economy Info Needed
Carbon fiber. Lightest, strongest hoods you can get. Probably the most expensive too. Doubt you can find one for a Legacy though. Not much out there for lightweight options on the Legacy. Especially the Outback. The Outback is heavier by nature. More ground clearance from the taller struts, has lift blocks in the sub-frame, more goodies inside the car (leather seats, door trim, more sound deadening material) all that nickel and dime stuff adds up. If anything, the best way to lose weight, buy an Impreza. The 6 speed trans (one of them anyway) is marginally better top gear ratio than the 5 speed. The other 6 speeds are the same or worse. And at that, any 6 speed is gonna cost you big $$$, where any 5 speed more than 5 years old will be like $500 or less. A trans and diff swap isn't that hard, but the fdr change will get you ~300 rpm lower revs at 60. Hardly worth the money unless you get the parts really cheap. 99 OB will have 5x100 lug pattern wheels. Only way to see the weight of the wheels, is to look them up. Tirerack.com has a decent selection, there are plenty of brands out there that make very light rally/racing wheels that will fit Subarus. Team Dynamics Racing is a pretty big name in the Rally world. I have a set of Team dynamics wheels I need to sell listed in the Classified section here. Check in the vendor forums, and Classified sections here and at some of the links at the top of the page. You may find better info for your weigh loss plan at some of the more performance oriented forums. This board has more of the keep it stock, or add weight so it can off road better crowd. edit: we've had plenty of fuel economy threads here. Click the search button and you should find a few with plenty of hints/tips for better mileage. Might check out the links at the bottom of the page here under "Similar Threads".
Fairtax4me replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBeing RPM related, can you replicate this noise with the car sitting still?
Rough idle
Fairtax4me replied to e4620's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might be better off to start a new thread for your issue. But here's my 3 cents. You just did some work on the engine, now a few hundred miles later you have trouble. Coincidence? Go over anything you touched while you were doing the work. What did you have to remove/disconnect in order to get access to what you worked on? Hoses, clamps, wiring?
Code P2096 Now what?
Fairtax4me replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe definition of a drive cycle varies. For some systems it is just time with the key on. Others needs a whole string of conditions to be met in a certain order before the monitor will be set as "ready". 95 and 96 Subarus have exceptions for emissions testing because several of the monitors reset after each key cycle, which means they will never be "ready" during testing. After that Subaru fixed the issue, so all models 97 and after have to have monitors set "ready" to pass testing. IIRC the Evap system has the most difficult monitor as far as completing the proper drive cycle in order to get it to set "ready". Just keep driving. You may need to make several trips of various duration from 5 to 30 minutes to get it to set. I haven't had the chance to look into the deal with the O2 sensors. Though I'm not entirely sure I could find anything useful. :-p
Fairtax4me replied to Jaimesbeam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou said it was a 99 in your other thread. A 96 outback could have the 2.5 with automagic trans. 2.2 with manual trans.
ABS light, sometimes
Yeah check the wheel sensors and wiring. Make sure there aren't any metal shavings stuck to the sensors. The wiring for the rear sensors is routed a little strange where it starts to run down the trailing arm to the hub. Check up by the body to make sure it isn't pinched/cut.
Fairtax4me replied to Jaimesbeam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell as you may know, the 2.5 is prone to head gasket failure. The SOHC 2.5 is prone to external HG failure, they will leak coolant, sometimes for years as long as you keep the level full and prevent it from overheating. But it's not something that will leave you stranded with a boiling engine like the DOHC 2.5 will as long as you keep the coolant level up. Anything 2.2 or 2.5 after 96 is interference design so timing belt maintenance is a must. If you can't find out when the belt was done last, and that all of the idlers, tensioner, and water pump were done along with it, plan on doing that soon after you get the car. The manual transmissions do tend to wear out around 250k miles (seems I've seen quite a few threads about MT troubles lately). Replacements are easy to come across, but it's still going to cost on the order of $1000 - $1500 if you have a shop replace it. The ATs are hit or miss, but overall seem to be a little more robust than the MT. Fluid changes make a HUGE difference in the life of an AT, and one that has had the fluid changed regularly will cover 300k+ miles before it gives up the ghost.
Slammed a curb... help me out guys
Fairtax4me replied to daredevil1166's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrill/dremel oval out the hole in the sub-frame where the link attaches. Your adjustment plate for the cam-head bolt is gone anyway. Also did you check to see if the sub-frame had shifted any? Hits like that will usually make it move a little, and loosening the bolts that attach it to the chassis will allow it to just slip right back into place.
Auto Tranny Help
Fairtax4me replied to markjw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh well, you gave it the good ole college try at least. Now at least you know it's hosed. :-p Honestly a good 4EAT shouldn't cost much at a junkyard, ($150ish from a picknpull?) and they don't take that long to swap.
Gotta love that nice white snow to point out little green dots!
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou did that much on the first torque step?!?! Suppose it could be worse, but I'd plan on the heads being warped out of spec for sure.
93 2.2T 177k how reliable?
Fairtax4me replied to mikewilke77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs said before, the low compression of the turbo engine leaves it severely lacking any kind of power on the bottom end. Not gonna do well off road. Turbos can be used off road, but there are way more chances for failure of the catastrophic kind. Pop the vacuum line off the waste gate, get over-boost, put a hole through a piston (or three), your motor is toast, and you're up a creek out in BFE. Consider a franken motor for off road. Keep the turbo for a DD in the meantime.
Major Front end shimmy under load help!
Fairtax4me replied to mgkmark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably a bad half axle. The trick is to figure out exactly which one. Have any of the axles ever been replaced? Possibly with an after market rebuilt axle?
Head Gasket Bullet Dodged?
Fairtax4me replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe probably has one of "the lucky ones". There are a handful out there it seems (probably more than a handful, but we never hear about them because they don't have trouble) that go well past 200k miles with no head gasket problems. You can expect to have head gasket issues on ANY engine after 200k, so failures of original gaskets at such high mileage really can't be attributed to the same cause as low mileage failures. It's almost considered just normal wear and tear at that point.
How To: Read transmission codes
Fairtax4me replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow about a listing of what models and years this method applies to?
