136
Cheaper to buy an Ej22T block and toss it in the car the way it is. You need a lower base compression ratio to run high boost levels or you'll just blow it to smithereens the first time you hit boost. Do some research on Tubrocharging before you go buying parts. Save yourself some time and headache. NASIOC.com has more of a performance-oriented crowd that will be able to help more with what and where to buy.
I looked about 3 days ago and didn't see it. Looked back today for kicks and noticed it and somehow, a week after it was first listed, he still has it? Probably not in as great shape as he says. And you're absolutely right about the lack of TLC. Letting HGs go for that long, what else has been ignored? He said the tires are "new" which I don't particularly like. I think I'd much rather see old tires on an awd soob. Forester is built on the Impreza platform which makes sense that it might feel a bit "small" inside. I'm not hauling a family around though, I'm more interested in the cargo space and the utilitarian aspect. The back seats would probably be folded down all the time with my tools and random car crap scattered all around the back of it. Have set up to see this thing on Wed. I doubt it's going to be a tough decision.
So I'm going to look at a 99 Outback, AT, 180k. Blown HGs, has been driven repeatedly overheated for about the past year. So the engine is "well done". Timing belt and other odds and ends done at 125k by local dealer. Decent tires, minor body damage scratches/scrape from a parking lot incident. Leather, but some dog chew marks. Dual roof. What do you guys say its worth? This might be a decent keeper, though I would prefer a manual trans. I'm after a wagon of some sort, I was actually looking for a Forester, but this one popped up for a seemingly decent asking price of $1,000. I figure if I wave some cash around he might come down another couple hundred.
Using that much might be because of a clogged PCV valve. Check that and clean/replace it. Check the PCV hoses for obstruction as well. How many miles on this thing? Some leaks tend to make oil puke out when driving but not when parked so no large puddles in the driveway. You have any blue smoke in the exhaust?
What I've been reading about building "Frankenmotors" is that the 2.2 and 1.8 heads are mostly the same, the biggest difference is the 2.2 heads flow better. So performance is better with the 2.2 heads. Search for Frankenstein or Frankenmotor and you will find some info about it. The most threads about it are on NASIOC though.
On the old ones it's not that bad, entirely doable inside the car. The only two seals that require the engine to be removed from the car are the Oil separator plate, and the rear main. But every oil leak on a Subaru eventually winds on on the exhaust, so it could be coming from anywhere. With a car that old it's probably a good idea to just pull the engine and reseal the whole thing but the majority of the seals can be done with the engine in the car.
That's a lot of seemingly unconnected issues. What year was the engine from? Where was this car stored? I'm kinda thinking mouse damage. I just got another wild idea. Check under the dash on the drivers side for the green diagnostic connectors. Those should be left unplugged. If they're connected unhook them. Clicking solenoids and relays sounds like those two connectors are plugged together and the ECU is in self test mode.
That is a heater circuit code which means there is either a bad connection at the sensor or at the ECU, or the sensor needs to be replaced. These new sensors work a bit differently than the old ones and I'm not entirely familiar with what goes on inside them yet, but the ECU monitors how much current is being drawn by the heater in the sensor. If it finds a problem it throws a code for it. There are several wires on the ECU for the O2 sensor. 05 FSM says pins A2 and A3 are for the heater circuit, both of those connect to pin 4 on the sensor harness connector. I can't seem to dig up an FSM for an Imp earlier than 05 though so I'm not sure how much this helps you. I'd say if anything, 04 is probably 90% chance gonna be the same, so look on the ECU connector for wires on pins A2 and A3. Those should be tied together somewhere near the ECU. I'll keep looking though to see what I can find. (I bookmark and/or download copies of all the FSMs I can find for reference. [/nerd])
