Everything posted by Ricearu
Unacceptably poor fuel mileage. (cliffs at bottom)
Ricearu replied to cal_look_zero's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour mileage will decrease as your speed goes past 60mph. My wife's legacy with 2.2 gets 26-28 if I drive 60mph to work, but if I drive 80mph, it gets 21. I was late to work today, and had traffic on the way home, so when I wasn't in traffic wasting gas, I was driving 80. Filled up again just today to see what repercussions it had on my tank. 20.68mpg. :-\ One's foot has a huge effect on MPG. and yeah the surf board rack will hurt areodnamics
Noob torque bind question...
I know I shouldn't be making a post about this buuuuttt... I cannot find a part number for the duty cycle C solenoid itself. Wife's 96 LSi has TB and putting the FWD fuse in it does NOTHING, doesn't even light up the light. I called subaru, they gave me the part # for the assembly which is $320... I'm in texas and for that price, the wife's car can stay FWD :-\ oh and don't say search button, I tried about 10 different searches I have heard talk in the past that the solenoid is under $50...
Rod knock? (video enclosed)
Ricearu replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds pretty rod knocky to me. Hate to say it but roommate's postal does the same thing.
95 Impr. L - Need to fix rust spot behind left rear wheel (donor car years?)
Ricearu replied to brycarp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX3 words my friend. Battery Powered Sawzall...
Brand new Impreza starts with difficulty
Ricearu replied to Flopka's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2012 impreza? if so, it's GDI and has a high pressure (way higher than the standard 45-60 psi) and could just take a little more time to pressure up when cold. I would document a complaint with the dealer. Subaru can't fix it if they don't know there is a problem. all my old subies crank within 1-2 seconds. chee chee chee roooooooommmmmmblablablablablabla.
Ricearu replied to cal_look_zero's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes your freeway have traffic? My 90 lego got 25-26 out on the open road but get it around dallas, in city traffic and it got 18-20...
JBweld fix
Ricearu replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjb'd a wallowed out crank key way on a 1.8 impreza. Bought the car with a kajillion miles on it and a loose crank pulley. We got a new crank pulley did the timing belt/waterpump/idlers, filled the void in the crank snout with JB added a little for some extra love and impacted it on with my snap on MG725 LIKE A BOSS. Let it set for a couple days and my buddy drove it like that for a long time!
'91 Legacy - Stumble During Hard Turn?
Ricearu replied to uwjberg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe mesh bag he speaks of (some call it the sock) has fallen off. mine did exactly that. Pissed me off when I was driving "spiritedly" through the cloverleaf on my WRX struts/springs and my car would cut an buck and surge.
Front fender interchange G1 Legacy
Ricearu replied to notnowles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tried it. No. Simple answer. The 92-94 fenders are longer and the marker is set deeper into the fender and different shaped. The whole front is stretched on the facelifted version and has a significantly different core support. I had the whole front end from a turbo SS and know it WONT fit a pre face lift
Learned a couple of valuable lessons last night
Ricearu replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for the input GD, it makes me feel better I am at the Indianapolis dealer expo now so car work has halted, but I will be right back at it on monday or thursday. And yes, on all 3 auto subies that have had the radiators out, I just cut the hoses and replace them with nice new supple Gates transmission cooler hose. I just wish I could find a source for 10mm hose, not this 3/8" stuff. Good time to replace them anyways, I learned the first time I tried to get bugger break loose, I busted my hands all to hell.
Ricearu replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit wasn't too hard to get them to mate. I hope it works now... grrrr. I HATE automatics.
Ricearu replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdouble ouch. pride and head LOL
Learned a couple of valuable lessons last night. Lesson one. EJ22 Flexplates are about 1/2 smaller than EJ25's (overall diameter) Found this out THROUGH the tiny bolt "inspection" hole. Lesson Two. Don't leave your engine hoist boom up at about 5 1/2 feef off the ground in the dark. Bent the SHNIZZ out of my glasses and knocked me to the ground. I saw stars. I still have a lump/bruise on my forehead. Im most pissed that I have to pull the engine again...
how i fixed my F***ing 420 code
Ricearu replied to shin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a degree in automotive technology. I can say that too. Because I DO... The ECM adjusts the AF ratio based on the front O2 sensor. Rear sensor only indicates a problem with the cat or with the O2 sensors. It will not damage the engine by taking it out of the stream.
AWD not working,But something weird tho.
Ricearu replied to 05-Subie-98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits the wheel speed sensor the awd system monitors wheel slip at each wheel on that car and applies braking to the "slipping" wheel via the abs/tcs. If you have an intermittent wheel speed sensor failing, it puts the awd into FWD mode only with no traction control.
98 Outback hitch won't fit. Ideas?
Ricearu replied to cnc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXahhh originally you said it was for a 97 legacy. a forester one is different I believe
1997 Subaru Impreza Sport wagon
Ricearu replied to soobie_newbie67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1. all of it!
Lowering my outback...
Ricearu replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah im not too worried about ground clearance lol. I am looking for a set of wrx struts and if I cannot find wagon rears, I will just put 1"/1 1/2" tokiko sportlines on them. But I bet that is hella low. here is my roommate's 1995 postal with tokiko sportlines on wrx struts. 1"f 1 1/2" r
96 Legacy wagon - HG Leak?Pre-Purchase q's
Ricearu replied to tehP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat is a steal. I bought a 1997 outback knowing that the headgasket was blown for 900. Jump on that sucker and worry about it later EJ22's are solid, if I were you, I would replace the timing belt, water pump, Idlers, water pump elbow (little rubber hose) and any other original rubber hoses on the car and you should be good to go oh and check the pcv valve, and change the valve cover gaskets. I would buy it. I could easily double my money on it :cool:
Ricearu replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use gimp and the whole car is dropped, I cut the whole frame in half at the bottom line of the car following the wheel arches, leave the wheels with the lower half of the "picture" and move the body of the car down. It is just something I figured out. Notice the picture is about 1/4 inch shorter after editing If I cannot find a full set with springs and struts, I will let you know texan. The outback struts are longer. WRX struts are 3" shorter than standard legacy struts so who knows the diff for outback struts maybe another 2". I will know once I have a set and go to swap them. I will measure them when I do. gimp is a free image editing tool rugby and is full feature and works on linux, mac, and windows http://www.gimp.org/downloads I like the outback look, and I know there are lego GT's everywhere in the north, but even "L" legacies are kinda scarce down here. I see outbacks daily, but legacy gt's are a pretty rare occurance. Plus I got this gem for 900 with a blown headgasket and am getting rid of my 91 in order to keep it :-\
Replaced spindle knuckle....update
Ricearu replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't do it, unless I was in a bind out of town or something. If I can pull a hub, I can sure as hell take it to a local shop and have the bearing pressed in/out
Ricearu replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas she sits now my "end game" with the obw is something like this i know, quicky photodrop
Ricearu replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno I don't have the parts currently. I was looking to pick up a set off of craigslist. They are always floating around. you in the DFW area 1 Lucky?
Yeah yeah, I know flame flame lol. I got a 1997 outback as my new daily driver and I am lowering it with WRX struts/springs. My question is to lower it and be "right", do I need to change the trailing arm brackets and remove the subframe spacers? My answer is yes but don't know what all this entails, like steering shaft length etc. What I am really looking for in an answer is from someone who has first or second hand experience lowering an outback.
Quelling Piston Slap - Best oil
Ricearu replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi probably wouldn't run rotella with lucas, but I guess half of a quart won't really hurt it. I run Rotella 15w-40 with WIX filters on all my 100k Plus subies. It shut up the forester's piston slap, and It NEVER went away before then. It did it cold, warm or hot before the rotella. My wife bought a Legacy LSi last month, had new "valvoline" 5w-30 from some lube shop, and was 1 qt low when we got it. I added a quart of rotella to it and It shut up the slap on that beast too! EDIT, I also live in TEXAS. A BAWLS COLD winter here is 17*... ABOVE 0!
