Hi, first post on USMB. I'm new to Subarus, but not new to wrenching on my cars. I plan do the spark plugs in my '99 Outback Wagon this weekend, hopefully I can avoid a similar problem.
I've dealt with plenty of broken fasteners, here's a few hints to add to the others:
- Easy-Outs are evil! They break easily, and are harder than drill bits. A broken bolt containing a broken easy-out is a nightmare to remove. I've never had success with one.
- The Truebite bits probably work as advertised, but they seem a bit expensive for a carbide Dremel bit. If you're in the US, Home Depot and Wal-Mart sell Dremel brand carbide bits for about $5.00.
- Drill out the bolts with a LEFT HAND drill bit. No joke, they exist, industrial supply shops sell them (for example, www.mcmaster.com). You need a reversible drill, of course. Often, the drill will spin the bolt out.
- If you end up drilling them out, you can dill the next size larger and tap new threads. Alternatively, you can use Heli-Coil thread inserts or Loc-Tite Form-A-Thread to create new threads the same size (any auto parts shop should have them).
- Weld a nut to the remainder of the bolt. Hold the nut on top of the bolt with pliers and fill up the hole with a MIG or stick welder. The heat will loosen the bolt, and the nut allows you to put a wrench on it. Probably overkill for these small bolts, but it's a handy trick for bigger stuff.
Hope this helps!
-Ron
