Everything posted by 99obw
The head gasket/overheating thing is a chicken or the egg situation. Head gasket failure causes overheating, and overheating causes head gasket failure, but which came first in any particular engine may be difficult to prove conclusively. My guess is that most EJ25's start to leak just a little bit of exhaust gas into the coolant, which eventually causes overheating, which then leads to a much more severe head gasket failure.
P1102/p0106
99obw replied to YetiMan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The best way to test the MAP sensor is with a vacuum pump and gauge connected directly to it, rather than relying on the vacuum signal from the engine. It does sound as if the MAP is suspect, can you get one from the junkyard? -
P1102/p0106
My understanding of the PSSV is that it allows the MAP sensor to either sample the intake manifold pressure or the atmosphere, allowing it to function both as a MAP and a BAP. You don't list your car, but on our 99 outback the PSSV is on the right strut tower. I went through checking all of these systems when we first got the evaporative emissions code (still have it). It's pretty easy. Haynes or the FSM should describe it pretty well. I can take a look at the manual at a later time and help if needed. Maybe endwrench has something on PSSV diagnosis. -
Gasket Dressing
99obw replied to Top's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think that technically they should be replaced, but I didn't replace the bolts when I did our head gaskets, and that was about 75k miles ago with no troubles, FWIW. -
Gasket Dressing
Use sealant on the oil pump, cam caps near the corners where the valve cover gasket will lay, and over the ends of the plastic plugs in the rear of the heads where the valve cover gasket meets the head. Use sparingly. -
Ours has used about that much oil for a long time, probably over 100k miles (192k miles now). It uses significantly less of 5w-40 than 5w-30, and it uses virtually no 10w-40 or 15w-40. I have settled on 5w-40 for the summer and 0w-30 for the winter, and I just deal with the oil consumption. Some is leaking, some is burning. The car is past the point where I am going to worry about it. My Jeep on the other hand recently used 0 quarts of 5w-40 oil over a 12,500 mile oil interval.
Thanks for the info. I don't find it surprising. Our piston slap seems to have stabilized, it hasn't really gotten any worse since about 100k miles. I'm curious to see the bearing wear numbers given that relatively thick oil. Can you post the entire UOA? Did you get TBN? What was your driving routine? How long was the oil in service? That is a short run for M1. Here's a link to my run of 12498 miles in my XJ on M1 5w-40. I could have probably gone to 15k. http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=3;t=003140#000000 I don't have any UOAs for our EJ25 or we could do some compare and contrast. I'm sure that plenty of EJ25 UOAs can be found on BITOG. Maybe I'll have the current batch of GC that's in the EJ25 analyzed this spring.
Theotherskip has written a great site dedicated to Phase I EJ25 head gasket replacement. It seems to be "locked" though. Here is the link to the google cache... http://64.233.161.104/search?q=cache:u8zk6XseIKoJ:mysite.verizon.net/vze730qe/Head_gasket_replacement.html+subaru+2.5+head+gasket+myself&hl=en&client=firefox-a When I did my gaskets there was a thread going.... http://www.ultimatesubaru.org/forum/showthread.php?t=2444&page=1&pp=10 I used a haynes manual and the USMB. I used the torque procedure in the above USMB thread. 75k miles so far.
These engines use a wasted-spark type ignition, so there will be four sparks per revolution on a 4 cylinder engine, with each spark plug firing once per revolution, somewhere near top dead center on the compression and exhaust strokes. So it may seem that there are twice as many sparks as are necessary, which there are. There really is no setting of the timing on these engines. A properly installed timing belt is all that is required for proper engine timing. The cam and crank position sensors and the ECU do the rest. I agree with the others that yours does sound like a timing problem. I would pull the timing covers and verify the timing of the timing belt. When was the last time it was changed? How many miles and years ago?
I just installed the silverstars and the relay harness, and all I can say is WOW!!! I aimed them low intentionally because I didn't have time to aim them properly and I wanted to take it easy on other drivers. Once I get them aimed properly they should be even better. If they last a year I think it will be money well spent.
