2005 Impreza 2.5RS
i_subie replied to bkcraun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey're still all 2.5L, '06 WRX+
1998 Forester auto trans swap compatability??
i_subie replied to 99gtott's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as you have matching final drive with the rear differential then you should be fine.
4th Annual Madison Subaru Meet June 25/26
I would like to come but then I'll be at the MAP, drift, drag, autoX, track event up in MN getting some seat time.
PIAA 520 5291 Fog light kit!
i_subie replied to mr.radon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should definitely get some pictures! I wanna get a set too for my daily driver. I hate it when you have those morons that leaves their high beams on.
Is Valvoline Lying?
i_subie replied to rugbyben's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used to run Castrol Syn and then switched over to Mobil 1. After switching over to Mobil 1, that's when I noticed having only 2-3.5qts of oil left, after every oil change. That's with the weekend AutoX events and including lapping days. Then one day at a lapping day event, my rod bearings went out. All of my fellow Subaru buddies asked what engine oil I used. I told them Mobil 1, they all gave me hell. Told me I should go with Rotella syn 5w40. I haven't had any issues yet or having only 2-3qts left doing an oil change.
stock oil pan bolt size?
i_subie replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe the stock oil pan bolts are 10mm.
code p0102
i_subie replied to Bad Brian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould possibly be a bad MAF sensor.
My EJ25D is almost done
i_subie replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhile you're still at it, you should go with a set of 10:1 compression pistons and maybe some delta cams!
Knock Sensor Nightmare
i_subie replied to mccullough's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had to replace the knock sensor for both of my RS and I don't have any issues with them yet. I only order OEM because I get it the next day and less expensive.
i_subie replied to mccullough's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry going with OEM Subaru parts? It may be costly but you won't have any issues later down the road.
How rare are 1st gen and 2nd gen Subaru Brat?
Yes, I was in Laramie for school.
Timing belt question
i_subie replied to ktdenali's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat you can do is take the timing belt cover on the driver's side off. Their should be 3-4 bolts holding it on. It should slide out, don't try and yank it out. Put the car in neutral and take a ratchet with a 22mm socket and turn the crank pulley bolt clockwise or counterclockwise. If you can't get the ratchet in due to the radiator fans in the way, you will have to remove the fans. Then from there, turn the crank pulley bolt with your ratchet and inspect the timing belt. Look for cracks, see if the markings on the TB are still there and the "Subaru ---->" marking. As for the slap, could be due to piston slap. Not a big issue typical Subaru thing, my '99 2.5RS has(116K) does the same until the engine gets up to temp, never drive the car with a cold engine.
I've wrenched on cars, I do my own work. I rebuild my EJ25D, spun a rod bearing at a lapping day event and found out the previous owner used a Phase 2 block. I've done tranny swap, engine swap, differential and such. As long as it isn't electrical then I'm good. lol. I live in WI, I've come upon 2-3 Subaru Brat and seen one back in WY, when I was there for school. Other than that, I found a Brat for sale but it needs work, A LOT of work actually. I'm looking for another car incase my '99 RS (DD) needs maintenance. The guy isn't asking much but it just needs work and it'll cost me more to get the car home.
check engine light on -- but communications fails
i_subie replied to zyewdall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe car/engine isn't suppose to be running while you are checking for codes.
1996 Outback differential for fiddilin jay
i_subie replied to johnceggleston's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's a 4.111 just find a 4.111 rear diff and it should bolt on.
i_subie
