About DaveSluder
- Birthday 11/11/1969
Location
Andover
Vehicles
I Love My Subaru
DaveSluder's Achievements
Member (2/11)
0
I have a 98 Forester Automatic. The front end is making noise constantly now, 208K mi. Fluid is OK. Pretty noisy, good thing the radio is good. So, here's the question, when do I go ahead and replace this? I want to ride it all the way out stopping just before it strands me. Anybody had one totally fail? How does that normally happen? Thanks....
Use an industrial heat gun, it's temp will be more even and will not have a hot spot like you will have with a torch. And no open flame to boot! Use a stiff paint scraper multitool, the one with a semicircle on the side for cleaning the paint roller. That is just the one with all of it's different sides and angles to get all the spots. It costs maybe $5-$7 at Home Depot or the like. Happy Scraping--
I have a 98 legacy. Recently, when I drive on roads that are slick, my car handles strangely. That is it is a bit squirrely, it almost seems like it wants to "pass" itself. My tires are new (less than 1500 miles), car was aligned when I replaced the tires. This symptom does not exist on dry roads, or is at least not perceptable. The symptom is not noticeable until about 35mph. There is no perceptable movement in any of the suspension components when I examine the car jacked up. Wheel bearings are OK. I am clueless other that something could be really wrong with the alignment. Any suggestions would be appreciated--------------Thanks Dave
Anyways brake lines were installed last night. I just broke down and bought a double flare tool and spliced in under the back seat onto clean brake lines. I just need to wait for my oldest boy to help me bleed the brakes. I just went over to the left side under the back seat and exiting through the fuel line grommet. I am assuming that the line forward of the back seat stays in reasonable condition. Guess we will see.
I have a 98 Forester, last night in the middle of a pizza delivery, I saw a snow filled field. Finding the temptation too great, I went for a little spin. Well anyways coming out of the field I applied the brakes and the went to the floor! So, I pulled onto the road popped the hood and found the resevoir low. I then pulled forward slightly to find a puddle on the rear right side. Today I went under for a look and it looks like the leak is coming from on top of the fuel tank. So I am assuming it is going to be a hard line. Is there one up there? How can I go about replacing that one? I guess there is 1 or 2 lines coming from up front. Anybody got any suggestions? What flare style do these cars have? Thanks in advance for your help... Dave
Don't even bother with the Harbor Freight Welder!! That's gonna be a waste of time. I have a Lincoln 110 volt Welder I think it is 100 amps. Unless you are welding thick stuff like greater than 3/16ths. I have had this machine for about 12 years and it has been used and abused, and still performs flawlessly. I use it to weld on many automotive projects, and around the farm. I bought the base kit from Home Depot (just wire feed) and later added the gas kit. But really I have not used it as a mig machine in years. Flux core welding gets a bad wrap cause well, I don't know!! You can weld on "dirty" metal, never have to worry about running out of gas and you can ultimately weld thicker material with this process. Also you can use it outside with a breeze. I use a 12-3 HD extention cord and it works great!! Don't waste your money on chinese junk, that's what it is!! Lincoln is made in Cleveland Oh. Best Luck!! Dave:banana:
