Everything posted by cohophysh
92 Legacy Clock Spring? horn doesn't work
cohophysh replied to brendanr279's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had 2 90 legacies where the horn wouldn't work, for me it was just the relay. Are you positive you have the right relay cause I know the relay I replaced was behind the fuse box under the dash on the driver's side...and what is a clock spring?
Idle-this weeks issue
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyea, I only tweeked it a little, and marked it so I can reset it.
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI probably shouldn't have but I adjusted the idle screw, at least that should get me safely home...probably the TPS needs to be replaced
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno EGR on 90 but I am pretty sure it has an IAVC, I will check hoses
90 leg 2.2 5 speed. Car won't idle, was running fine, pulled up to a stop light and it dies, restarted just fine but I had to sit on the throttle to keep it idling...where do I start? MAS, TPS, IACV? other parts to check?? Thanks
Idle issue
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXya she has put in the miles...here is another tid bit, it only idles like this once the engine has reached operating temperature.
Idle issue
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXya that is my next thought, but what to do, replace, adjust?
Idle issue
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo if it is the IACV, how do you clean it?
Idle issue
Ugh.....another problem, this is getting old. 90 leg 2.2 manual 364K miles. so here is the issue, when stopped the car idles between 100rpm-900rpms. Up and down up and down. At one point it did die but started back up. No CEL I have recently replaced Knock sensor, fuel filter, plugs, wires, and PCV. Any thoughts...
knock sensor
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI miss the CEL coming on...NOT!
how can you access the vent door, that changes air flow direction?
cohophysh replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXactually it was the control unit, replaced with one from the bone yard and voila, all vents are working:clap:
A/c
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTxv?
A/c
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes on both accounts
A/c
Does anyone have a good link to troubleshooting the A/C in a 90 legacy. The compressor would run but all that came out was hot air.
cohophysh replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hope this is the same for a 90 legacy cause I am going to see what I can find behind the control unit. B
1997 Outback Wagon knock sensor question
cohophysh replied to Bill Hambone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just bought a knock sensor from ebay for my 90 legacy for 13.00...if you don't mind waiting a couple days, ebay is worth the savings. Autozone had them priced for 45 or so.
About to junk it! 2002 OB Bucks from stop poor idle
cohophysh replied to vintagecamping's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPCV replaced????
knock sensor
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXokay, I put it back:clap:
knock sensor
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi will probably move it back where it belongs...
knock sensor
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have someone telling me in another forum that the knock sensor shouldn't be moved because it won't sense knock as well, if at all and could cause damage. Any thoughts
knock sensor
knock sensor
90 leg 2.2, I just replaced the knock sensor, however, I did not put it back where it came. I found a bolt hole up and just towards the firewall that was easy access. So I mounted it there. Seems to me all the knock sensor needed was good contact to the block, so basically it could go anywhere the wire would reach. Is this right? B btw...knock sensor was in bad shape. split housing rusty...yuk
power loss-clutch issue??
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh bloody hell and f' me running....I replaced all of the plug wires and it is running fine....
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for that, I was going to replace the temp sensor as well since it is only a couple bucks
cohophysh replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgot all of the plugs to stay in, still running like crapola. I hate to start throwing parts at it and seeing what sticks. i did pull a couple codes off but I don't know how old they are...temp sensor, knock sensor, mass air...however, it has overheated in the past and I did have the mass air flow disconnected one time so I would expect those codes to be on...maybe need to replace knock sensor and plug wires. It really is a strange problem cause sometimes it will run just fine but then mash the pedal and...sputter sputter...any help is appreciated as always.
