Everything posted by Setright
Boxer engines put extra stress on their valve cover seals because the oil tends to stay in the "top" of the engine. With age comes a tendency to leak, on the underside where most people dont see it, and the oil runs straight onto the exhaust manifolds. This is most likely the cause of the burning smell. Valve cover gaskets are cheap and easy to replace. The PCV valve should be replaced at the same time - to avoid excess gas pressure inside the engine block, pushing the oil out. If the right side CV boot has been replace and the mechanic didn't wipe excess grease of the axle it will fly off and hit the catalyst - REALLY bad burning smell, but harmless. The clutch judder can be terrible. The only fix is to get a new clutch. Subaru knows it, but it can be difficult to get a dealer to admit it.
Subylvr, my 1990 "GX" did not have sub-par interior materials. On the contrary, after 14 years it still looks new, apart from a slight sag in the driver seat squab. Thick fabric covers nearly everything, and nowhere does it show any signs of friction wearing it down. All this at 190k miles! Must be why I was able to sell it for 12% of its original price
Impressed
Setright replied to CJK440's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Your post begs the question: "Which car?" -
crank position sensor questions
Setright replied to speedbump's topic in Old Gen.: 80's GL/DL/XT/Loyales...
May I recommend reseting the ECU when you replace the sensor? Battery disconnect for an hour, connect back up, start and idle until the engine reaches normal operating temp, switch off. She'll be like a brand new engine -
Oil seals: Cam shafts front and rear, crank front and rear (engine or tranny needs to come out). Certainly oil pump o-ring and housing seal. Valve cover seals, including those around the bolts. CV boots will need inspection. If its and early model manual transmission, the main bearings fail around 120k, and should have been replaced. 162k miles is only about half-way for the engine
It is the KNOCK sensor, no question. Cam and crank angle are at the front of the engine, immediately behind the cam belt covers. There was a redesign of the internals of the knock sensor, and the good one has a white connector - grey on the old style. If the sensor returns a garbage signal, the ECU retards the timing and you can limp home. Just don't expect any throttle response -
As some of you may have noticed, my tag has changed, I bought a four year old Impreza to replace my 12 year old Legacy! How do I fix the Imp's long travel brake pedal? The pedal doesn't firm up until it has gone about half an inch lower than the throttle, and this makes heel-and-toe gear changes nearly impossible. In the Legacy, they lined up perfectly, and throttle "blipping" on downshifts was a cinch A new MC is a possibility, but I would rather do the relavtively easy job of replacing the brake hoses - should give other benefits too. Anyone care to share their experience?
Reset the ECU. Should be enough to disconnect the battery for an hour. Connect, idle up to operating temp, and shut off again. You might want to replace the knock sensor. Sometimes they break down interally and create a "lose connection" which amplifies engine noise, and gives you timing retarded to the back-stop.
You know your a Subaru Freak...when
Setright replied to Stupidru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
..you are telling your brother the sad story of a long-term relationship breakdown and interrupt the conversation to say "Hey look! A Subaru!" -
Advice?
Setright replied to Canadian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The engine should go double that mileage without bother. Provided of course you replace oil/oil filter and coolant at the required intervals -
I would second the 120k-140k miles life expectancy. So, if the pump is ok now, replace it later - how much time before you reach "critical mileage? BTW, the main worry is the bearing, which might fail and allow enough play to let the timing belt jump a tooth. As soon as this happens, you will notice the difference. That would be the time to replace the pump!
Nasty. If you're quick some Holts exhaust bandage might hold together for a few months longer :-)
