Zoltan
Everything posted by Zoltan
  1. OK. So Have raised the tranny 3 inches up from the cross member. I think this will help. I am now waiting for a input shaft seal, as I just noticed mine is bit damaged. I may have done that while inserting and removing torque convertor 10 times. I will get seal in a day or two and thanks again for the advise.
  2. Ok. Thanks for the advise. I will try it later today and report back!
  3. On my 07 Outback, EJ25 NON turbo I had to remove the engine with the torque convertor as the motor was seized. I got a different motor finally, and am now trying to re install the torque convertor. I know the correct depth that it needs to go in but cant seem to achieve this. The torque convertor spins freely in both directions and still need to go in another 2 or 3 inches. I tried for an hour to spin and push. Some sites say it will go in three different stages. I also saw a video online and am now wondering if I need to take out the outer shaft from the tranny (seems to be about a foot long) and put in on torque convertor with its C clip and try this again. I am confused and very frustrated. Not sure what to do. Thanks in advance for any advise or links.
  4. I just ended up grinding and chiseling away the block to gain access. I tried drilling it out but the flywheel was in the way and I could not drill perfectly straight and then I ened up breaking a atraight bolt extractor I just bought for the job. Thanks for everyones advise.
  5. Ok. THanks. I will try drilling it out first. I dont want to hurt the thread on the torque convertor. How exactly would I drill this out? Do I just use a slightly smaller drill bit? Sorry for being a pain.
  6. I have 06 Outback with an auto transmission and a NA EJ25 that has a connecting rod sticking our of the block next to the oil pressure gauge. Dont you love it when you can diagnos the problem 3 seconds after opening the hood! The motor only moved a few degrees so I was only able to get out one torque convertor bolt. I pulled the motor with the torque convertor as I could see no other way to get it out. Any ideas on how to get the torque convertor off the engine, now that its sitiing on my garage floor. Short Block is garbage. I will take off the heads and reuse them on a 2002 EJ25 I pulled from pick n pull. Does anyone happen to know if the 2002 torque convertor will work the 2006? I could go and pick it up as the pick and pull is close to me. Also I need to get the PCV valve conection off the Garbage block. Is this pressed in. With the dual outlets on this PCV connnection coming out of the block, I cant seem to figure out how to get it out as I cant get a wrench or socket on it. Thanks again for everyones input. ?
  7. I cant use the heads from the pick and pull engine because they are from an 02 EJ25 and the the heads from the 06 Forester are different.
  8. Thanks everyone. I should have mentioned that the 08 has a hole in the block. Not sure if it was overheated, I bought it that way from a shop and not directly form the owner. So zero history on the car, so not sure if it was overheated or not. I will try to get in touch with the previous owner and see exactly what happened. THe car is a manual and it was driven by a young male so he may have just been really hard on it!
  9. So im off to pick and pull to get an EJ25 SOHC from an 03 outback. I dont need the heads, as I will be using the heads from my 08 impreza. My question is do I need to keep track of the head bolts from the 03 or should I just use the ones from the 08? From the research I've done everyone seems to say no new heads bolts need to be purchased. Thanks in advance for everyones help.
  10. Ok. thanks for all the help. I think due to the fact that the zero comp engine may have been overheated I will be going to get the one from pick and pull
  11. Ok. THahks guys. It would be nice to have someone to help me out., but I don't have anyone like that so I spend a lot of time researching and taking things slow. So I bought a 04 na Ej25 sohc Forester today as a parts car. I paid $280 and thats basically what the tires are worth. I bought it from someone who had it for a year and spent the whole time on vacation with it. From all the paperwork I got it seems it was driven about 20 000 miles. Car has 165 000 miles on it. It idles very rough so I did a compression test. 190 psi on 3 cylinders and zero on the last one. I did some research on this and my question is how can I tell if this problem is in the head or a problem with the rings or pistons etc. I dont need the heads. I will be using the heads from the 08 impreza. I went through the paperwork and a jiffy lube mentioned no oil on dipstick when the car was brought in, so I figure it was overheated. Should I just stay away from this engine? I did see a nice 03 Outback with similiar milage in the my pick n pull that was in a small fender bender and written off by our goverment insurance agency. Would love to hear everyones opinon on this.
  12. I just picked up a 08 Impreza sedan, 5 speed EJ25 Sohc, with a hole in the block. Looks like connecting rod did it. I noticed that this motor has a soleniod in the head. I think its for variable timing. Can I take a EJ25 SOHC short block from lets say 2000 to 2004 and use the 08 heads? I will take heads to a machine shop. I have never done a head gasket job but I did watch 4 good videos on it, and if I take my time I think I can do it. Thanks for everyones time and input. It is much apprecaited.
  13. Ok I finally got it back together. But the transmisson seems to be sliipping, not sure if this is related. I will keep it as a winter beater and see how it goes. AT least I learned a lot and it gives me time to find a low mileage tranny. Body motor and interior are real nice. Thanks again for everyones help.
  14. When you say "drum" do you mean the large round thing currently on my rear housing, or the large round thing currently on my tranny? I really did try hard to keep everything together, not sure how it cam off like this. Twice. I have the service manual. Confused the spoob out of me. I cant seem to make heads or tales of it.
  15. Ok, thanks for everyones patience. I got my old digital camera out. So pic 1 is the rear housing from my car. You can see I placed one of the clutch bands that just came loose. Picture 2 (no clutch band at the bottom of pic) is of the one I took from pick and pull. Almost the same situation but bands stayed together (did not fall out) although they seem loose. Pic 3 and 4 is from my car at the back of the tranny. I took two different angles to try to show what was left on it when I pulled off the rear housing. So I guess my question is, how do put this back together, and I guess more specifically, what to do with the loose clutch bands. Thanks again I really want to get this toegether properly. I called mt local dlr (Kelowna Canada) yesterday and the gasket wont be here till tuesday, so I do have some time to try to figure this out. I will try to read the factory manual later tonight but sometimes that stuff goes over my head. Ps I just noticed the little o ring on pic two. I will make sure I dont miss it or double up on it. lol O
  16. I just watched a video on u tube. 4AT/Phase 2 Teardown. It ssems that on both my car and the pick pull car, when the rear extension housing came off the tranny, the transfer clutch stayed in the extension housing and not on the tranny. So some of the clutch pack rings are loose. II wonder if my VDC makes it a bit different? I will dig out my old digital camera and figure out how to post some pics.
  17. I posted some pics on Flickr and I am having trouble figuring out how to get them here. Have spent 45 minutes doing this. A bit frustrating. Im not a comptuter person. Oh well, I have run out of time for now, will have to try again later.
  18. I will figure out how to compress a picture or post it. I think it would be best if you guys could see what I am taking about
  19. The steel Rings/Bands are the dia of a dessert plate and are located twards the rear of the car (in the extension housing. I will now take a look at the service manaul. Thanks Again.
  20. I went to pick and pull and got a new rear extension housing, driveshaft, and complete shifter assembly from a H6 VDC sedan. One question I have is do I have to do anything the the steel rings in the extension housing. I notice that they are loose and seem to move around. I was much more carefull taking this one off. I did not bang it much, just took my time and pried it off. So any suggestion or links on writeups on what to do with these steel rings in the extension housing before I put it on the tranny? I'm not really sure what they do and how trhey will be held in place. Tranny Fluid Pressure, I guess. But this is still worrying me . THanks again for eveyone helping out.
  21. Ok. Understood. I will get the Subaru Gasket. I will report back on how this turns out. Thanks again
  22. Ok Idosubaru. Thats what I understood but the conformation is much appreciated. Do I need to get a new rear extension housing gasket from subaru or can I just make one with "the right stuff" gasket maker. If I need the gasket from Subaru does it go on dry? I may have put a tiny indent or two on the tranny. Thanks again for the advise. '
  23. Thanks forester2002s. Ok I read things over again and now understand that I have to get the `receiving end from a VDC H6, 2000 to 2004 sedan or wgn. . There are 2 sedans and One wgn in my local pick and pull. So i think my odds are good. Thanks again to everyone.
  24. Ok Now im a bit confused. First of all what does "OP" mean. Second, My car is a 01 Outback H6 VDC ,auto tranny. I have take out the receiving end of the tranny with the stuck yoke from the drive shaft. So do I need to take one from a car with VDC or will any H6 do?
