hey,thats awsome ill do that, another question i had is, the 4wd lever doesnt allow me to get in 2wd, i figured i would just cut it and weld in an extension ,any suggestions of how much of an extension i would need?
hey, im putiing a 4inch lift on my 85gl wagon and the water pump fan/ fan clutch fan is pretty close to the radiator core suport has anyone taken off the fan clutch with fan and installed an electric fan? i figured it would work fine for cooling, would it cause problems on the motor side? would i gain Horse Power with the motor having less drag?
they are xt6 backing plates the guy i got them from just e-mailed me and said he did have xt6 parts lying around, i really appriciate the help. i was lost and i found usmb and im so gratfull!!! thank you kindly all!
will the xt6 ones work with the proper rotors or am i hosed? these rotors are 8.89 inches, do you think if i went and bought the xt6 rotors which are 10.07 around will work? i just wonder if the rear hub off the wagon will fit inside the xt6's rotor. and too think i thought this was a plugg and play sort of a gig....... nothing you think will be easy is EVER easy lol 1st rule of mechanics easy=
:banghead:im putting a set of rear disc brakes from a turbo model on my 85 gl,im having 2 problems #1. the brake pads only contact maybe an inch of the rotor leaving a half inch of the pad untouched by the rotor, the rotor is just under 9inch diameter #2 the bolts that hold the caliper bracket onto the backing plate are 1 1/2 inches long, so if i bolt them all the way tight they will be rubbing on the back of the rotor. so my questions are: am i putting these on wrong? or do i have the wrong backing plate or calipers?
if the rear disc brakes are suppose to only have an inch of the pad touching the rotor leaving a half inch of the pad untouched anyone wanna buy a set of rear disc brakes lol:D
i was wondering about a radius arm mod? i guess it helps gain positive caster, i was wondering if anyone had done this and what type of vehicle you had taken the radius arm out of. any ideas? http://offroadingsubarus.com/83sedan_radiusrods.html is where i saw this mod but i cant get ahold of a 81 Toyota Crown radius arm. thanks for any ideas
