Tmb9862
Everything posted by Tmb9862
The 2.2l is indeed stock as has already been mentioned. I thought it might have been a mistake in their book and looked at the gaskets for the regular legacy 2.2l cars. The part numbers are the same for both. A year ago I would have spent the extra money on the dealer part off the bat but this thing has become such a rust bucket over the last winter that I'm thinking this one will do it in. Does anyone know the part number for the gaskets or make a recommendation on a dealer who will be able to get them for me? After what the local dealer tried to charge me for parts last time I went there I'm not going back. As for re-using them, they're completely toast. Thanks for the help and responses.
I'm trying to find up pipe to manifold gaskets for my 1996 Legacy Outback 2.2l 5spd. I ordered them from a local NAPA store and they came back with gaskets with three bolt holes and two holes for the exhaust. The ones I need have one hole for the exhaust and two bolt holes. It looks like the muffler and cat gaskets only elongated. I looked in their part catalag (2 of them actually) and it does show the three bolt gasket. Does anyone know the correct Subaru part number or perhaps what to ask for at the parts store to get the correct part. Thanks for any assistance.
It's a 2.2l in a 96 Outback so it's non-interface. I'd like to take the car from NY to Florida in a month and don't want to wind up stuck on the side of the highway somewhere in South Carolina and have to pay for towing, a mechanic to do the job and loose a couple days of the trip. I forgot to post the link to the kit I was looking at. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&_trksid=p5197.c0.m619&item=370536153552&viewitem=&category=33625. Is that the one a lot of people are using? How much more would it cost to buy OEM through your site? Thanks.
I did a search and it seems most people on here are either using theimportexperts on eBay or going OEM. I can't justify dropping almost $500 at the dealer for a timing belt job in a $2,000 car so eBay it is. Now some people have talked about upgrading the belt in the kit or just not using the one in the kit. I e-mailed theimportexperts and asked if their was any such upgrade. If their isn't am I better off getting another brand of belt? What should I look for in a belt besides OEM? Any other comments on these eBay kits?
Well a few swear words and about ten hours (including some breaks) later the new coupling is in. She drives well now with no more binding. The old one was defiantly a little burnt as you can see. If I had to do it again it would probably be a three or four hour job having learned a bit. Those roll pins suck and aren't even worth trying to punch out by hand. The air hammer got them right out and next time I'll go right for it instead of wasting time doing it by hand. The same goes for getting the knuckle off. You can play with the stupid thing all day and it won't go anywhere but the air hammer knocks it right off. I wasn't thinking straight and removed the reverse light sensor. I then spent half an hour trying to figure out why it wouldn't go into gear. Then I removed the whole cross member again and disconnected the linkage to isolate the problem. Only after I gave up an took a half hour break did I come back, look in the parts box and see that washer staring at me. That cost me over two hours from a stupid mistake. The welds nuts on the transmission mount (I think that's where they were) broke on me. I couldn't find any suitable replacement nuts and bolts in my bolt bucket so to save a trip to the hardware store I re-welded them. One of the transmission mount bolts also snapped off in the tranny. I didn't even bother with it and have three bolts in there. I'm going to have to drop the tranny to do the clutch in the next few months so I'll weld a nut to it and pull it out when the tranny is down. Other then that it went pretty smoothly and I just took my time and kept everything organized. Some of the replies here and articles on this bored defiantly helped. And special thanks to GeneralDisorder for selling me the new center differential.
You could drop the exhaust, heat shield and cross member. That's only about a half hour job and another half hour to get back in. Add another half hour if you need to cut the exhaust bolts. Then it would be pretty easy to get an air chisel in there. That should make short work of the pin and removing the piece without dropping the transmission. As a last resort if you're changing that piece anyway then you probably don't care about wrecking the bushing. So why not throw a little heat on it.
I don't know about the rest of the country but in NY we have a couple people who actually go around and check it out. They have this weird tank in the back of their pickup that measures how much gas is going in. They just drive around and cover probably 20 gas stations a day each testing the accuracy of the pumps. But... If you do the math the odds are in favor of you not getting caught. 40 stations a day of probably 5,000 in the state is a .008% chance of being caught.
If you have a compressor 3m Scotch Brite Roloc discs. They have to be the greatest thing ever for removing gaskets, rust or paint. They turn a half hour job with a razor blade into a two minute job. Before I had one I just used a razor blade very carefully. RTV usually comes off easially with a blade though it's 20 year old gaskets that are a PITA.
My number is ty752vabca and is not listed in the chart. A quick search and it seems all 96 Outback 2.2l 5spds had that code. From what I can gather on here it should be a 4.11. I also found a website with that number on it saying the trans has 37 teeth on the ring and 9 on the pinion which would be 4.11. The 97 is ty752vacca and is listed as 4.11. So I'm pretty sure it would work. Are the transmissions stamped somewhere so I can make sure they're both original to the vehicle? I'd love to know how you manage that. If I cruise at 60 with just myself and about 60lbs of tools in the car I get about 28 on the highway. If I cruise at 75 I'm down to about 24. This thing really needs a 6th gear.
I have a 96 Legacy Outback 2.2l, 5spd. I don't need it but I can get a transmission from a 97 2.5l Outback with fairly low (120k) mileage pretty cheap and am considering getting it as a spare. Question 1. Is their any way to find out what the ratio in my transmission and the 97 transmission is? I can get the numbers off the plates from both of them if their is some way to determine through them. I know mine differs by one number. Question 2. The 97 has a hydrolic clutch and my 96 has a cable clutch. Are the bell housings the same where I can just pull off the clutch slave and fork and swap in the cable fork and bracket?
I've always had good luck with Goodyear tires. I had them on my Camaro, my pickup, my Jeep and now my Outback. I think mine were about $450 for the set a couple years ago. They're great in the rain and snow, road noise isn't to bad and 30k later the tread still looks new. They probably still have another 60k left in them and will outlast the rest of the car (96 with 160k on it). Additionally Goodyear is mostly made in the US or Canada.
Well I took it to Autozone and like I though as long as it's putting out more then 13v they won't warranty it. I got a used OEM one for twenty bucks, threw it in and no more light. The bills are piling up right now, once I have a little more cash I'll pick up a re manufactured one from the dealer. Thanks for all the help and advice. Now. How can I completely destroy the Auto Zone one so they make good on their warranty. It wouldn't hurt to have a spare sitting around even if it's an Auto Zone one.
That piece is from a 97, mine is a 96 Legacy Outback. The piece I want to remove and replace the bushing around is identical to the one in my picture. To me it looks like it's a rivet that would have to but cut, knocked out and replaced with a bolt. I'd rather change the bushings then buy a new piece if they are available.
I have 96 Legacy Outback 2.2l, 5spd. I know their are a ton of threads on this and I've went through most of them trying to find this bit of information. I need to change out the two shifter bushings in the dog (pictured part) I believe it's called. The pictured one isn't the one in my car, I have the older style but the answer should still be the same. My question is how to change the one with the arrow. It looks like a rivet holding it together. Do I need to grind the head off and replace it with a bolt? Does anyone know the part numbers or where I can get the part numbers for the two dog bushings for the older style shifter (not the one pictured)?
Thanks for the help. I checked for AC current and don't have any. Then again the light hasn't come back on and I never did tighten the belt. If it comes back on again I'll try and check for AC current. If an alternator from the dealer really is only $75 I'll probably just pick one up. I paid probably twice that for the Auto Zone one.
Thanks for the ideas. The one in my car is from Autozone and has been replaced under the lifetime warranty once already. The first one lasted about a year, this one is probably about six months old now. Normally I wouldn't have bought from them but it was Sunday and I couldn't wait for the part. I put the tester from the alternator to a ground and turned on everything again (lights, fogs, defroster, mirrors, seats, radio, ac, dome lights) and got 12.9v. If I increased the RPMS a bit it jumped to the high 13s to 14.1. I think that sounds pretty normal considering the load on it? Yesterday I noticed the light coming on if I hit the gas hard going up hill. The belt is pretty new (about six months) and seems to be tensioned right. I'm going to tighten it up a little and see if that helps. I'm thinking maybe a bearing or something in the alternator is starting to seize up causing the belt to slip. Or it just has some sort of intermittent charging problem. Hopefully just tightening up the belt helps. It sucks if it is the alternator again which it sounds like it is because Autozone won't warranty it unless it fails in their testing machine. I doubt it would fail in their machine as it is now. Maybe I just need to find a way to completely fry the alternator so I can get it warrantied.
1996 Legacy Outback 2.2l, 5spd. I've had this happen twice before and both times the alternator was bad. No every time it rains even if I don't drive the car in the rain the brake and battery light turn on for the first minute or so. Their is no way anything is wet because the car wasn't driven in the rain. Now it just did it without it being wet out. I put my tester on there and with the light on I was getting 14.3 across the terminals and to ground. The three year old NAPA battery is about 12.5 with the car off. So the battery and alternator both seem to be good. The last two times it happened I was getting low voltage readings. Could it be anything else or is my alternator going bad again and somehow reading good? I guess this is what I get for buying an Autozone part.
