Everything posted by later, Peter
roof rail thingys
later, Peter replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXshould be some sort of allen or star screw maybe hidden under some sort of cover....
Head gasket issues and PNW mechanics/shops
later, Peter replied to awesomeshow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are so many "specialty Subaru shops"... They do head gaskets regularly (as well as other services). Trust someone that deals exclusively (or at least mainly) with Subarus. By the way, my 1999 Outback has nearly 200,000 miles... no headgaskets replaced.
'99 OBW
ahhh. Mr. Texan, tests to be applied tomorrow or the next day... (don't think it's torque bind... all tires are of a matched set but, should check all the pressures)... Thanks again for the advice.
'99 OBW
got a 1999 OBW 2.5 liter that made an occasional grinding noise when braking. Wasn't dirt in the calipers (checked) couldn't see any other issues. Recently took the FWD fuse out for the up coming winter months & the noise has returned... I didn't notice it when the fuse was in (you don't miss what you don't hear, I guess) but quite obvious now. Again, intermittent... braking is solid other than the noise so, what's the AWD doing? thanks, Peter
where can i buy this clip?
or try a body shop... I've gotten some internal plastic clips/screws/whatevers for the local body shops...
Cannot unlock my Subaru Outback Ltd with fob or keys
later, Peter replied to gordsan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou have any enemies or practical jokers in you life? did someone put "super glue" into your lock mechanisms?
Overheating Forester
later, Peter replied to CFab's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhead gaskets or plugged radiator.... & if not refilled with coolant PROPERLY, you'll create more air pockets & the cycle starts again...
NGK plug differences?
later, Peter replied to tbolt1003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould still be the wires (check that they're tight on the plugs). have you re-set the CEL? (FLAPS or disconnect the battery for a few minutes). have you checked the wires to the injectors?... once had this happen when a mouse chewed through the shielding of an injector wire.... good luck.
Subaru 2.5L in my Vanagon started!
later, Peter replied to coclimber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had to sell my 1985 Westfalia recently... & own a Subaru with 2.5l... always thought I make that transfer (2.5 for 1.8) but never needed to do so... the dream of long trips with out the paranoia of getting back home... ah. sweet peace of mind.
Recommended SOB mechanic in NJ?
later, Peter replied to Lisa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry the "Car Talk" web site...
P0141 code...
later, Peter replied to efseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreset!
Subaru noob coolant hose question
later, Peter replied to vladvv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbe careful about getting *ALL* the air out of the cooling system... this was/is the down fall of many Subaru head gaskets...
Car is stalling randomly
later, Peter replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm guessing you've re-tested your alternator... I had to replace the wrecking yard one for it's defect & the next one they gave me was also a problem... re-manufactured from Subaru dealer was like $80 & has kept the charge up & stalling out down (none)
Best tires for Outback & Costco tire replacement policy
love the Michelins... (Use the X-Ice for the winter months... lasts YEARS)
Tribeca wont start when wet
later, Peter replied to jimh21524's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsomething's shorting out when wet... I'd start with new plug wires.
99 Legacy Speedometer Problems
later, Peter replied to mikeshoup's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep, gotta make sure that soldering is secure & done on the front & the back of the PC board... & the screw fix is good until a nice bump...
later, Peter replied to mikeshoup's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt turns out to be a simple (easy) fix! you need to remove the cluster & re-solder the correct wire (front & back of the circuit board) there are SPECIFIC instructions on this board.... I fixed it once (solder only the front) then again soldering both sides of board... try it.
What's this in my tranny pan?
later, Peter replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa piece of a previous transmission gasket?
Should we move our Outbacks or sell them here?
later, Peter replied to Todd GT5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfrom another Central Oregonian... sell them here.
stumble at idle
hmmm. I'll look for a vacuum leak in the moring. Yes, less than 750 (closer to 700 RPM)... 189K on engine... I've used "the seafoam treatment" sucking through a vacuum hose... in any event, I'm hoping for a minor vacuum leak. later, Peter
stumble at idle
btw.... 2.5 liter engine.
stumble at idle
1999 Subaru Outback Wagon. Newly replaced spark plugs & wires. My knuckles have healed enough to type now. Runs great. Good mileage on a recent 1,000 mile trip. But at idle (like a stop light) there is a "stumble" every now & then... not consistent. almost disappears totally in neutral... the idle speed is low but can't see the how to increase that. later, Peter
Need a price check
I'll sell him my 1999 outback 30th Anniversary edition (2 moon roofs, heated seats & wipers, great stereo with woofer upgrade, power & heated side mirrors & more...) for 1/2 of that $23,000! (& it runs great, too)
looking to buy 1999 Outback Wagon - Your thoughts?
later, Peter replied to TheRFG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have one. It's the 30th Anniversary edition (costs more for all the features) I heard all the reservations about the head gaskets etcetera. Although, everyone I asked that owned a Subaru of that model, had no problems. Anyway, the only problems I've had in 140k miles are: the time a mouse chewed through the wire to my #3 fuel injector AND When my alternator died (@ 165k miles) & I, mistakenly, replaced it with a used one... love the car. feel safe/secure dollar amount seems a bit high though unless it has low mileage (sort of does) & it depends on where you live. Rustless Subarus command a higher price in snowy mountain country. & all those extras (2 moon roofs/heated leather seats/heated mirrors/heated windshield wiper/am/fm/cassette/cd/weather radio/seperate woofer... )get more money, too. later, Peter
rear stabilizer link question...
just came back in from seeing if I could undo without the "zapgun" (which I could). & I placed a floor jack under the rear bar where it hooks into the link... too easy. NOW if those parts would get here! UPS where are you? later, Peter
