Everything posted by old sub freak
hard core!
yes to pull the core by the book is a JOB! what i have done on e81s is to use a dremmel tool and cut it out.its still a lot a of work but better then pulling the whole show out. it slides out like a tape deck and slide the new one back , little silicone. HEAT!! do try flushing first. i've saved a few that way .stay warm todd duh! i was trying to answer the guy with heater core problem. live and learn
rear axle removal
what worked for me was to remave the pins and drive slowly around the block. but even that is no garente? they will come loose. just be sure to clean the threads and use anti sieze for next time good luck todd
rubicon pictures?
is there a mother load of pic or just a few here and there todd
1400 swap
i got a good ea81 there this summer 150 bucks. w/dist, carb ,alt and starter,the hole ball of wax!! i took in a battery and did a compresion check. seems good. i was leery too,thew were side stepping any testing questing.so i did it myself. you can't beat the price w/a 30 day swap. i know of a 74 wagon,for parts if you go w/a1400[as foolish as it seems] just kidding man!! todd 360 424 4340
oil leaking on my 1.8 Gl 4WD '86 Coupe
hey, i 've had good luck fixing those leaks. the trick to the front seal is to use high tack sealer [almost glue] to hold in the seal i've used blue silicone onley to have it " walk" it moved 1/8 inch. in 6 months. and pre-oil the race before putting in the pully. now on to the oil pump,i've also good luck installing a oil seal kit[from the dealer] it can be hard to get the pump out. take your time pulling the oil filter up & down while GENTLY prying it out. pry on outside areas of the pump not in between the metal to metal plates[ does that make sence]. the seals are probaly hard as a hard seal and will break in your hand. take it easy taking out the 2 philip screws,there easy to strip[i've had to un screw them with a small chisil] once the pump is out its easy to "reseal"it. the last stinker is to put a LITTLE sealer on the seal between the pump and the block. i've had them fall off or move on install. i've done this a dozen times with good results. don't get in a hurry and you'll do fine. good luck ,todd ,the old one p.s. it can be tough getting it back in. line up the "keys" .get in place and use the bolts to pull it in [cris cross],be carefull that everything is lined up and slowly pull it in. have fun todd
lift kit
i like the idea of making a sub frame. i've seen some scary hacthet jobs. is there enough room to hook front to rear with 4 inch lift? john, i'll call you.thanks again guys todd.
lift kit
hey,thanks for the info guys.and thanks zap for the back up! still would like some blue prints. anybody?? todd the grayhaired oldy
lift kit
ok how about pictures. i had some loose specs but lost them. as i remember it looked perty straight forwad. or are these patented? anyway just thinking about it todd ,not a newbe more like a olde
lift kit
i forgot ,its for a 84 brat or hacth.3 or 4 inch sorry for being so vage. todd
lift kit
does anyone have blueprints for lift kits? thanks todd
!!WA 9/15 meet and greet!!major update!! all read. !directions added!
i'm limping out. aside from being gimped up my wife , wants to cruze the east side, having one last fling in the heat. but if things change i'll make it. have fun & take care todd
i was miss informed. i was up there sunday helping fix a broken steering arm on a friends sub. todd
walker valley is closed. evens creek would be cool. i don't know how much rooting i will do as i herniated myself , but i'd like to come and bs and hear amazing storys of the CON. i'll limp on down. todd
