crawdad
Everything posted by crawdad
  1. Thanks everyone for the information I will start with alignment and check bushings then go from there, it has new struts and ball joints and new axles, haven't thought about the brakes and they are new too, could be stuck caliper but it seems to free wheel when I jack it up, also I have noticed the left (drivers side) front wheel lines up with the edge of the fender and the right (passenger side) is inside the fender, not sure if it's supposed to look like that.
  2. Has anyone out there with a 1985 brat ever had a problem with their Brat pull to the left under acceleration and instantly pull to the right when you let off the throttle? This has been happening for the last year or so and its not just a slight pull it's a major movement.
  3. It wasn't too bad until I tried to patch it now its warped too
  4. Lets do it, sounds reasonable to me, I have a paypal account let me know how to do it.
  5. Thanks, If its not cracked how much do you want for it?
  6. Anyone know where I can get a taillight lens for the passenger side rear of a 1985 Brat , mine has a crack and will not pass inspection Left hand drive U.S model.
  7. My 1985 did that it was the radiator it was clogged half way up,and there was sludge in the oil pan clogging the screen. it would heat up to red line in less than 10 minutes.
  8. thanks i'll try twisting tomorrow Ordered new cable today.
  9. It's very sloppy, moves about an inch either way.
  10. My clutch cable broke today on my 1985 brat, limped it home and found that the clutch fork seems loose when moved by hand, is this normal?
  11. Thanks wasn't too sure about screwing them in, just wanted to check.
  12. Trying to replace front brake pads but cannot get the caliper piston to compress enough to get new pads in. tried with c-clamp but it has e-brakes on front couldn't get them to budge, took them completely off vehicle loosened bleeder too.Is there something else i need to do?
  13. Just installed the lights they are 100 watts each and very very bright. Mounted them on the headrest mount for now until I can fab a rollbar.
  14. 2009-04-04 007.JPG]
  15. Pulled Oil Pan And Found A Thick Pudding Type Blob In The Bottom Of The Pan, Right Where The Pickup Tube Was. Scraped It All Out And Cleaned Out Pickup Tube And Screen.Don't Know What It Was Never Seen That Before.Now I Have 70 Lbs. Oil Pressure At Speed And 25-30 Lbs. At Idle.Very Happy With My Brat So Far.
  16. Flushed The Motor, Replaced Filter And Refilled With 20-50 Oil. Holds Pressure For 10 To 15 Minutes Then Bottoms Out And Starts Ticking Again.
  17. There Are No Leaks Around Pump Or Any Other Place. Am Using 10-30 Oil. No Oil Burning, No Smoke. Haven't Done A Compression Check But Seems Good. Have A Good Aftermarket Oil Pressure Guage Installed. Will Check O-Rings On Oil Pump. Lifter Noise Is Coming From Driver Side. Idle Is About 900 Rpm's. Old Oil Pump Did The Same Thing,But No Lifter Noise. Thanks For All The Advice Everyone, Will Remove And Check O-Rings And Replace Oil With 20-50.
  18. Need A Little Help With My ea81 oil Pressure Have Installed New Oil Pump And Filter,Have Good pressure At Startup, Will Hold Pressure For About 10 Minutes Then Start Dropping As Far As 8 On Guage Then The Motor Starts Ticking. What Is Wrong, screen,Pickup Tube, Bad O-Rings ?????? Did The same With Old Oil Pump. Any Suggestions ??
  19. Finally Got My Brat Running But Now It,s Making A Gurgling Noise On The Left (passenger Side )Of The Motor Like It's Getting Hot. So Took Out Thermostat And Wired Fan To come On When Engine Is Cranked, But Still After Running Just A Few Minutes And Shut Off Engine Still Gurgles.Timing Is set Right , Good Water Circulation At Radiator. Flushed Whole System.By The Way Runs Very Good No Smoke And Good Power.
  20. Thanks Everyone, Got Her Running, Now Having Some Cooling Issues. Working My Way Down The List.
  21. Stock Replacement coil Tach Does not Move While Cranking Test Light Does not Flash While Cranking No Grey Wire
  22. Does anyone Know The Color Codes To Wire A Coil On 85 brat?Or Pictures Of One Wired.Cannot Get Spark ,Have New Coil , New Distributor,New Plug Wires And Plugs. Did Run For A Few Minutes Then Quit. Cannot Restart. Fuel Pump Is Working Properly. Have Power On Coil Both Pos And Neg When Key Is On.Getting Frustrated...Help!!!!
  23. How Do I Check Coil For Fire? So Far I Have Gotten Number One Cylinder At Top Dead center,Matched Rotor Cap Too. Still No Fire, Must Be Pickup unit. Which Vehicles Will Interchange Distributers Exactly, Trying To Find One,ALittle Less Expensive?
  24. No Spark At Plug. Have Fuel At Carb. No Backfire Either.
  25. Tried That Today No Luck, Sure Wish That Was It.
