mikaleda
    12
Posts posted by mikaleda
  1. okay i kind of thought as much. i am not going to worry about the boot and stopper my old ones were in good shape still. i'm having the hole that the strut mounts through welded to fill the sloppiness. my local supplier said they are the same as a monroe mounting kit and should work fine with the struts i ordered. once i get the mounts welded and fixed i will put it together and see what happens everything looks like it should work.
    thanks for the quick response, much appreciated this darn car is driving me crazy :banghead:
  2. i just bought 2 boot kits and 2 strut mounting kits from rockauto.com and this is what i got left side is my old parts right side is the new raock auto parts.
    struts i know these are right kyb gr2 gas replacements
    boot kit kyb
    mounting kit mevotech
    and this is the most important part of all strut bearing
    new one
    old one
    the mount looks right but the bearings are noticeably different, i'm not going to worry about the boots my old ones are fine. all i really want to know will the bearing work
  3. whatever you want to think gd
    i was just stating my OPINION.
    i don't care how long you have been working on subarus but i have worked on all makes and models since i was eight i learned to drive at ten and i have seen winters you will never see where you live
    i also don't have money to spend jacking up cars. i just barley make ends meet right now and just normal repair costs are killing me as it is. so no i haven't driven a nice decked out subaru and yes i agree the newer autos are good. i would still rather had a stick and so far the auto that i have has cost me more money than both of my stick shifts
  4. i think that differs on were we live you live in a big city yes an auto is better there. i live twenety miles from the closest town and i have seen clutches go farther than 100k before and also i have two 90 legacys at my house one stick one auto the stick gets better mileage. and my legacy in first gear is like having low range. another pro to a stick is also were i live alot of the time people burn out autos because it is not unusual to see three feet of snow over night (i live less than fifty miles from canada as the crow flies) and when you need to get through that a stick is far superior.
    to tell you the truth my gl is a better winter car than my legacy for getting through the tough snow
  5. The GL series came from the factory with a cork gasket.
    The Legacy comes with factory silicone sealant and snugging oil pan bolts could actually snap one off. They are only to be torqued to like 3.5 foot pounds.
    i said snug not wrench on it. all it takes is a little bit they work their way loose after a while and if you are smart you only put a very small amount of torque on it other wise you will damage your gasket. if you are tightening enough to snap a bolt than you shouldn't be working on cars. no offense ment, but i have worked on cars since i was ten and the first car i worked on was a 67 chevy. they only use cork gaskets for oil pan and valve covers on older cars and if you periodicly snug your bolts it will keep your gaskets from leaking. when i say snug i mean less than one foot pound of tourqe.
    i am also familier with legacys i periodically snug the bolts on all of them that i work on they do work their way loose just like any other car. if the bolt doesn't want to turn easily than DON'T TURN IT it is that simple.
    the only reason i am stressing this point is the average joe can't just pull their engine just to fix an oil leak. like i said before i don't mean to offend any one but it just upsets me when you guys talk about pulling an engine like it is a simple process. it may be for you since you are in a shop and have all the tools and stuff you need, but it is not easy for the average joe.
  6. my strut mounting kits and boot kits were in the mail today but i got to the post office one minuet late for pick up. :mad: so frustrating, so close i could have had my struts in today. i laid rubber on the way home carb is working good :-p
  7. It's become just as notoriously apparent that the gl and loyale cars have a bit of a spongy brake pedal feel.
    It's just a characteristic. You get used to it. (So long as it's safe. If you're hitting the brakes and your car is not stopping safely, that's another issue).
    I tried for a good month to get the brake pedal to feel firm in a 93 loyale and then just gave up. Brakes work fine.
    my 80 gl doesn't feel spongy at all, at least it didn't before i put a napa brake caliper on it.
  8. yes, i reserched and my rear shocks are monroe i have a limited lifetime warranty through napa. i'm not sure if they would still have a warranty through rock auto or not though. my kyb struts are part #234028 gr2 gas replacement limited lifetime warranty i spent $220 for the set. i had to buy mounting kits and boot kits also for the tune of $106 from rockauto but, defiantly worth it now i can safely drive this car once i install these parts.:burnout:
    that looks like the same kit i got. the problem i had was i thought i bought a rebuild kit for my 80 but it ended up being a repair kit for a newer model but the parts were the same and they worked, i got mine from rock auto though. i know i went into napa and they had an actual rebuild kit for $35.
  9. finished putting my shocks in and put my carb back in i had to just repair it because i got the wrong kit. with as much improvement as i got with just new rear shocks i can't wait to see what kind of improvement new struts will make. carb is working way better thinking of either putting an ea82 carb on or just getting a weber, either way it is going to have to wait for a while. i will be getting my mounting and boot kits on Tuesday or Wednesday and have my struts installed by Friday hopefully. i can hardly wait until i get this fixed i want to go offroading with it when it is :popcorn:
  10. your problem is you switched to synthetic, penzoil has alot of perifin in it wich makes sludge. when you put synthetic in it cleaned the sludge out makeing your gaskets leak. try snugging your oil pan and valve cover bolts and if that doesn't work replace your gaskets :headbang:
    oh and don't waste your money on stop leak it rarely works. i don't really see the point in using synthetic it does last longer without breaking down but the problem is you still have to change your oil every 3000 miles even with synthetic because your oil filter will still get clogged.
    i have a legacy with 210k on it and i put 5w-30 in it and it didn't use any oil at all its pretty rare to see a subaru that burns oil.
  11. hmm i will have to look into that. i was able to take some of the parts out of my rebuild kit and do a repair on my old carb. but i will look at the carbs i have and see if it is worth while to do a swap. if they bolt right on i might just do that for a cheap horsepower upgrade untill i can get a weber.
