Everything posted by baccaruda
Sad day in Subieville...GL10Wannabe TOTALED
sue that guy and get your son some counselling. looks like you've already had good luck with this, comparatively, but good luck anyway..
Engine Rebuild
ah, thanks.. guess who's never rebuilt an engine before?
can somebody run this VIN?
"may be harder done than said" that's why I asked about running the vin
what is a GL10?
HOWEVER a lot of GLs came with all the GL10 stuff but no GL10 badge. go figure. Some RXes came without the RX designation in the same way.
hey, Brian.. skeet's car needs a new key as the only one it has is pretty worn down.. would you be willing to please hook him up with the master key code if he gave you the vin?
Engine Rebuild
what's that you're doing to the piston in the second pic?
AC compressor / bracket interchange
maybe i'll just grab the whole compressor then.. thanks
yeah, i'll have to switcharoo the A/C clutch. I plan on grabbing the alternator bracket too.. but will the XT's round A/C compressor's bracket hold my wagon's square A/C compressor?
turn your touring wagon into a discovery (or something)
i'm really interested in a full length canvas sunroof. http://www.streetbeatcustoms.com/sunconkit.html
I'm putting an 87 XT engine with spider intake in my wagon soon. *My wagon has A/C w/ smaller squarish compressor. *The XT engine has no A/C. *Pull N Save has an XT with A/C w/ larger round compressor. Obviously the bracket will fit on the engine and intake just fine. Will that bracket for the round style compressor hold my square style compressor as well or am I chasing the wrong bracket? I can't make it out to the yard, most likely, until the weekend, and would like to know if I should search for a different bracket instead of wasting my time with this one?? if anyone knows. thanks!
swapping XT engine into GL10 wagon
Hi Chris. OK, so you need a TPS such as the one on my new engine (thanks Tyrel!) from an 87 XT turbo? I'll be using the TPS from my 86 turbo when I put the engine IN my 86 turbo so it's all yours. I'll make a note to snag it for you. $10 including shipping OK?
Subaru and Pikes Peak
- Subaru and Pikes Peak
If Subaru/Prodrive build it, I'll drive it. We can do it! heh. The Suzuki monster is called the Escudo Pike's Peak edition or version or something. It has two v6es with either single or twin turbo and is close to 1000 HP. YIKES!- swapping XT engine into GL10 wagon
thanks all. hey tex. like the name change i have a few extra TPSes.. I've started to hoard old sensors in good shape after realizing that they're unreasonably expensive new from the dealer- ADDCO Swaybars
what's the price? do they make poly bushings?- A/C clutch interchange
EA82 A/C compressor ?s I am under the impression that the clutch can be changed without draining the oil or freon from the compressor.. My car has the square style compressor. Will the clutch from a round style compressor swap onto my square compressor? I don't know which manufacturers made which...- A new use for a roof rack
yeah, i was going to suggest charging your hood pins as well. I hope that guy gets a blowout at 85mph.. what kind of store was it? any security cameras that might have seen your car while it was parked there? and depending on your insurance coverage, you might not have to pay too much .. if it's just a hood it's probably less than your deductible though..- Head Gasket screwed, Carb sucks, god hates skeet
i hope it's just the OP gasket.. you might consider getting the weber from someone who supplies Redline.. someone else here might have the contact info for a source; it's been in a fairly recent thread..- swapping XT engine into GL10 wagon
aaahh, there we go. thanks BB- swapping XT engine into GL10 wagon
thanks. I figure the worst case anyway will be swapping connector ends onto my car's wiring harness.- swapping XT engine into GL10 wagon
thanks a lot! SVXpert, are you suggesting that I pick up the ECU from the 87 XT? my car has a different MAF and everything...- Wounded Loyale... HELP!
If you're going to have to replace the rear control arm, etc on one side, you might swap in control arms for both sides that allow a rear sway bar..- Head Gasket screwed, Carb sucks, god hates skeet
oh crap! I'm going to see if I can get some money back on the engine in light of this news.. also, you might consider doing both head gaskets at once instead of one at a time.. cause sometimes it turns out that way. which side has the bad gasket? passenger's side? how sure is he that it's a head gasket leak? could you SEE the oil coming out of the HG or something? give me a call..- XT6 sway bar installed!!
it's nice, isn't it? I have front and rear XT6 bars and I'm thinking about putting a stock front bar back in to see how it feels.. - Subaru and Pikes Peak
