Everything posted by stansgl
I put new front struts on my '84 Wagon and I noticed that they have these two threded ends with nuts on each side that looks to be a way of raising the front end. Does anyone know if it is and if not what there used for?? Thanks!
ran into a snag while wiring my third eye.
stansgl replied to subawoohoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Maybe someone has asked this before can you put the third eye in a double headlight setup like an "84 model?? -
What hop-up parts are you refering to? That would be of great interest to me, alot less work than an engine swap.
I've been reading and researching all the diffrent engines that came in subs and while knowing my EA81 is very reliable what is the engine of choice for more offroad power? I've read that the EJ22 is very durable so I just wanted everyones input on the subject.. thanks!!
Radiator.com $106 for EA81
Temp Gauge reading on EA81??
stansgl replied to stansgl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well I guess it's about mormal than.. may install aftermarket gauge anyways just to be able to monitor it better. -
Just seeing who all was near the southwest VA, area. Thought it would be cool to get some people together to do some offroading.
What is the normal reading on everyones temp gauge(I know there aren't #'s) 1/4... 1/2?? This is my 2nd "84 GL Wagon.. the 1st car run at 1/4 this one runs at 1/2 and had give heating trouble... replaced radiator and all is well but temp gauge is still at 1/2.. is this normal or are factory gauges just junk??? Thanks all!
Laugh if you like but I used a pipe wrench .. it worked great!
Thanks to all of you who replied.. yours answers have been helpful. Thanks MorganM for the tip on the struts ... luckily I had just replaced them. I was reading somewhere here that the weber carb really helps out with the extra power desired for pulling the bigger tires, is that something alot of you have done here?? I was looking at doing it anyway just because I like weber carbs.
The lift will be coming in the near future... this all started with me trying to find some old 13" Bias Ply mud grips like I had before... no where to be found.. So the pug wheels was the next best choice since tires where not as limited. So your saying 27's are the way to go for now?? What actual size do u recomend??? Thanks!!
I found a set of 14" steel Pug wheels off of a '85 model for $25 a wheel is that resonable or a bit steep for old steel wheels?? Thanks.
