2
Posts posted by Len Dawg
I'm running into the same problem, I seen some on a 93 wagon at the wrecking yard. They looked fairly new i.e no road dirt,grime,splooge..
Napa nope, orileys nope, autozone nope they got tops but that's all ...every thread always ends up Topic of the REAR!! Even though it titles as frrrrooont!! Lol! Why? Why? Wwhhyyyyyyy? No definitive answer. ..for front
My ea82 seems to have always done something like that.. 3,000rpm 5th gear. Never a need to floor it ESPACIALLY going up hill.. always at 1/2 throttle lessen it up a smidge and it gets a stronger pull. I've checked anything with intake system connections no cracks no nothing... never ever even taken the throttle bore apart or off the intake.. been this way to over 10yrs..
Not really trting to jack your thread man.. but I'm feeling the way you do lol!
I would be checking out the front lower ball joints...
Good to know
Well... I'm here to close my thread I'd suppose.
I replaced both half shafts and drivers side wheel bearing still have a slight shimmy accompanied by a minor shake. But no more woo woo woo woo's,
****General Disorder is spot on with the bearing the inide one was showing signs of becoming burnt and blackened.****
The stub is a all good and right as discribed nice and tight. No leaking from the seal either.
Figure the suspension struts and shocks whatever ya wanna call it should be next as I get popping always had popping noises at the top of tower when I accelerate and brake and I'm pretty dammed sure these ones are original to the car that is at 299,665.5 miles
So I be back again to update on that..
You guys are top notch...
Sure hope it's not differential bearings General Disorder!! Then again.. it's got 299,028 mi
I'll be taking it apart next week and put in new bearings and seals. Pretty safe bet to re-use the cone since it's only been compressed 2x.
Drove again last night.. and crossed some new pavement at 25mph and put it into neutral and coasted as long as I could with traffic being involved and can almost feel a choppy sensation as well the woo woo woo starting to fade right front passenger.. but when doing so it's almost a woo,wOo,woo,wOo,woO,wOo..like KISS and Iron Maiden got together for a jam session.
I've been watching that splined stub for years, and when I'm in the wrecking yard I'm doing the touchy feely on other victims to compare they appear relatively the same. I don't mess with it a lot but maybe a couple times every other year. I don't want the magical mishap to happen and it falls out! Because then i really dont know whats I'm doing..Lol!
The shimmy and shake story has now evolved into the woo woo woo's.. and this all starts before the ball joint issue came about and after...
Couple things first, I've had this car for about 11yrs started at 151,000 miles and now 900 miles away from joining the 300,000 mile club!!! Whoo!! Hoo!! I never replaced shocks struts, steering rack -kinda looks like it's leaking- and lost a lot of fluid from the resivor which it NEVER had before till the whole shimmy and shaking episode all began. But now seems to be steadily full again... weird... but I have done bearings, CV joints engine cylinder head gaskets, radiator, timing belts water pump tie rod end cheapo got a very slight pull to the left etc... oh yeah and those leaky hoses!! It's this one that is tripping me up, diagnosing the woo,woo,woo's..... of today on the Dawgmobile.
Visual inspection appears normal.. tire pressure, ride height/rake, bearings seems smooth and tight, the usual positive camber angle...made sure to scrubb inside of rim of debris around hub location, wheel weights eVeRyThInG seems normal nothing loose kinda sorta, I gots a couple questions at the end.
Normal operation 0-25mph'ish, no wobbly wheels,no lurching brakes, easy rolls in neutral, a slight clicking when turning midly left then comes the woo woo woo's with a light steering wheel shaking, more notably begins at approximately 25-30mph on up 50 million miles an hour!! Hwy speeds around corners left and right carries and even woooo.. In gear out of gear any gear, 4wd engaged disengaged, brakes applied unapplided, haven't tried reverse don't think it will get to 25mph don't think that's a great idea anyway lol.
Here's how we got to the woo,woo,woo and it's definitely not the usual r-ree r-ree r-ree bearing noise!!
Shimmy and shake Turkey neck affect ...
Oct,3 2017
Inspection of various components ok..
Front Brakes pretty beat up..
Replaced front rotor and pads> SOLVED
Feb, 13 2018
R-ree R-ree R-ree Driver side front rotated rim 1 lug location >Solved? Crazy but it worked! Lol!
Inspection of various components ok... brakes were only done just because of good measure..
Replaced rear drums and shoes> then it snowed
Feb 28th 2018
Shimmy and shake Turkey neck affect again...
Replaced broken lower Front passenger Ball joint> SOLVED
Mar, 15th-20th 2018
THEN the slow approach of the agonizing woo woo woo's as the sound of rain no longer pellets my tin roof...
Put it up and in gear to check rotation of tires.. possible bent rim, one had tire worn badly inside probably from broken ball joint...
Figured maybe i screwed something up in the drums I splooge the outside bearings x4> woo woo woo
Replaced tire with spare full-size tire> woo woo woo
May, 10th 2018
Inspected other 3 tires and some were not severe but closer inspection appeared out of round...
Replaced other 3 tires> woo woo woo
So...
The new..
Front rotors/pads and cone
Rear drums/shoes and cone
Ball joint
4 New Tires
So...
The old..
CV Joint axle- whatever ya wanna call it
Bearings
Rims -not jackman but Subaru wheels whatever they are they fit over my calipers unlike my other rims with winter tires that do not now after front brake component replacment ;/ argh >Jackman??
Shocks/Struts whatever ya wanna call it
Busings anywhere and everywhere
So I did notice when I pulled the new rotors off to splooge some grease in the outer bearings careful not to get dirt in there when i did the front rotor/pads the first time- I was borrowing someone's driveway and had to hurry- I took off the passenger side the washer impression was not CONCENTRIC to the center of the NEW cone? Don't think that much of a problem.. never seen it before though??
And where the axle meets the output shaft from the transmission not the axle but the stub appears loose and has always been loose as you can grab it and move it around? It don't leak that's a good thing thank Gaudd! but always wondered about how loose is loose?
Always had a popping sound from the passenger side.. sounds like the strut tower body frame in front of the door
I think it's the half shaft and new struts would do some good, but over all what a weird episode..
then again... perhaps the New Ball Joint should be subjective to question because as in my other post as I had a ball joint question it did fit smoothly in the spindle housing but gave no effort of cinching it's self into the lower arm.. It just dropped right in all the way to the shoulder of where the rubber attaches to the balljoint... and i mean on the very very light side of being too big... and the woo,woo,woo's WERE NEVER present even with warped rotors,out of round tires or before the balljoint broke ....Goodtimes
The Dawgmobile
of Portland, Oregon
Just stopped by one here in Portland, Oregon... not too shabby guys been in business for a couple yrs now. Gots everything ya need. 5 star reviews.
If ya haven't already done research what tools ya need layed out it may take a few extra. I.E. doing your wheel bearing axles?? pre-pack your bearings, preset torque wrenches 3 pcs. 1 balljoint castle nut, 2 Axle nut, 3 lug nut ???? could do the job even faster with a friend ????
One time I parked and 2 hrs later went to start and I was flat dead.. turned out to be the wire that connects to the starter slid off the tab, it was truly amazing to had found my problem with in 15 mins. I wish the same to you ????
To me ... it looks like all those things that work have a ground attached separately with the ignition turned off.. so part of the system is charged... alternator? Starter?
Hott ride man! ????
After all that hard work, to get a picture to up load that's the answer you get!?!! Lol ! ????????
I love my ticks!! All 298,174 miles of them !! I've replaced a lot of everything still ticks ???????????????????? for the love of tick!
Maybe the bearing slid forward on the axle when ya put on the drum, my 93 Loyale 4x4 had some weird issue like that... I had to push the bearing back and hold the axle forward and slap the drum back on before is came out again...
Trippy story... I got a grip of things wired into a aux strip KC Daylighters, CB Radio, Airhorn compressor, couple other things fricking cant remember lol! I figure eveything run on 12v.... I killed mine only because I zapped it, one or twice... it lived for about 6 to 9 months then slowly died. With out me really knowing no lights no nothing on the alertt something is wrong panel, suddenly over a 3 day period of driving just off battery power the dummy lights were fading on and off... one tough battery!!
Here's what a fel-pro looks like after a couple years, the mechanic either did a crappy job and or it's just that ... fel-pro.
I got my last set from the dealer and when I compared the sets it would appear the dealer set has a metal tab the covers the area where the fel-pro failed.
I'm with General Disorder..
- 1
Fricking wow!
- 1
Well... spoke too soon it's back!! Kinda... sorta..in a round about way... it's a weird one, left front squeaks when I turn left ????????????????????????????????????????????
Check this..... I have had a drivers side wheel bearing squawking with kinda serious vibration at 55-60mph and a narley familiar bearing r-ree r-ree r-ree.. driving through town, which I know something is going on because I walked outside of my car in a parking lot at work with the motor off coasting and I'll have to go in to pack or replace.
i took the wheel off and rotated to a diffrent lug location and it got 90% better although i think it could be the inside bearing.. yes I'll brag.. it got better but it's faint.
Then -in a RARE episode as i don't beat on my subaru eveyday- today trying to merge a lane in traffic with signal activated to please let me in nobody would give me a shot to get in..so i had nobody behind me and nobody in front in my lane so i slowed back past all those tightwads that wouldn't let me in, I wound up the rpm's up and dumped the clutch and burned the rubbers not just the powerwheel rightside but both, then one of the tight wads decided to pull out and cross in front of me to a side street. So I slammed the brakes and again burnt the tires to get in... yeay!! f$%<× s@#&heads!! I gotnin!! and meanwhile slooowing to a stop at the next light whadya know? No more bearing noise! Not that I would suggest following my remedy but it's my belief that perhaps I spun the bearing?? Lol! Never thought of it... but still I'll have to go in a repack or replace plus i should get a center ring just because perhaps it's just that... who knows right? Lol!
- 1
Oh yeah! Now that ya mention the manufacture!! Duh! It's Duralast for the make lol! And there is ample treads
Thanks for the replies ????
- 1
1993 Loyale Wgn 4wd EA82 1.8 Litre
So I replaced the passenger side today... although things went smoothly smooth almost concerningly smooth. The Ball joint I bought at autozone seemed the proper diameter fit form and function. Yet the threaded stud didn't seem to have a taper or much of one to tighten it's self into the lower a arm, as well there was no hole on the end for a cotter pin to go through a castle nut. Which seemed strange as it came with a nylon locking nut. I already know this is probably going to be a pain to change next time. All seems well so far, still got a little shimmy with the shake cruising the highway but I feel as though I'm not living on the edge anymore lol!
Anybody else get something similar lately?
The Dawgmobile of
Portland,Oregon
My ea82 has got some kinda rubber squeak as well. It's with in close range this side of the fire wall. I figure it may be some rubber bushings at the pedal.. but it is weird though that it only starts to sqeak when harder pressure is applied.. sometimes while stuck in traffic I usually play a tune to it with the radio down low. Never really investigated.. ????
- 1
1993 Loyale 5spd 4wd Wgn last fall new front rotors and pads yesterday new rear drums and brake shoes.. kinda bent/madd because i gots ta use more brakes now to get front wagon wheels to fit again... apparently I picked up the wrong ones for the snow tires!! Yeah that ought to take another 10yrs to wear down so they fit aAgAiN!! LOL!!
therapy time....
Posted
Yeaup something juuust like that! ha ha ha!
