My 85 GL
It sure is other then the carb issue she is great got new axels in it drives smooth. 2nd subaru but gotta say like way more then my SVX.
- New from Washington
My 85 GL
My 85 GL just put new axle on it need to get carb adjusted likes to stall out at lights and figure out where the broken heater is not sure if core or thermostat stuck but i do know there is something dead in the vents.
Greetings from Wyoming
what we have a pull and pay. The only one i knew about closed a few months back. I need to go and take a look
i'm going to school in Laramie. Going to Wyo tech up there but commute from Cheyenne everyday.
carburetor questions
yes it is stock
Hey everyone new here and also pretty new with a carburetor. I had my carb rebuilt and now i need to adjust it. I found the screw in front and thought that was it i adjusted it to get idle right now its getting to much gas so assuming that was the air/fuel adjustment. So ppl saying to get to the others i need to remove the roll pin. My questing is where is the roll pin and what does it look like. If anybody has a pic or can have detailed instructions that would help a lot. Thanks
- Mice... Why did it have to be mice
hello everyone new to the forum. Glad to see a forum for the older subies i own an 85 GL sedan. looking forward to all the great post and hopefuly find some parts to keep the GL going strong.
85 GL suspension
no you read it right im still on the fence of if i want to raise it or lower it. I like the look of the off road but also like the look of lowered. A lot of guys do the raised and i dont want to look like all the other GLs out there.
85 GL suspension
im sure this has been posted several times but i have an 85 GL and looking to either raise it or lower it what suspension can i use or where can i get it. Is there any newer subies with compatable mounts even if needing a little mod or no.
LilLink1
