Everything posted by matt167
02 forester--put in engine forn OB wagon?
matt167 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXback as far as 1999 in a Forester. Your looking for a vehicle with an EJ251 engine tag. If you match that, then you have a swappable engine
Oil Filter
matt167 replied to keith3267's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsort of.. FRAM says it works and it does. The issue comes is that, they have an 'if it fits, it ships ' way of thinking. The 6607 and 7317 are identical except the 7317 is longer.. If you search Fram by application, it will tell you 7317 for FB engines. 6607 for 2004-10 ej and 3593a for most 2003 and older ej. If you cross the 12a OEM filter you get the 9715.. Now does it really matter. Not really. The bypass will open sooner, but the filter will filter.. If the threads and gasket match, it will work.. But Subaru could have a warranty issue with Fram since they technically spec the wrong filter
Oil Filter
matt167 replied to keith3267's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInteresting.. I deal with Fram filters every day, since I'm a service technician.. The 12A filter crosses to a PH9715 filter that, I don't think we even carry. spec pressure is 16-28 PSI. We cross a 6607 to that application using our Fram book.. The 15A filter crosses to the 7317 altho the 7317 spec pressure is 13 PSI which I know is too low on a Subaru.. Our service filter books call to install a 6607 in place where a 6607 is spec'd or a 7317 is spec'd, which makes the 6607 service filter we use, work for pretty much any 4cyl Subaru after 2002, Honda's starting in '02-'03, Nissans, Mitsubishi's, most Kia's and many others... The predecessor filters of the 12A are the same filter. it's an engineering change. likely manufacture changes
Oil Filter
matt167 replied to keith3267's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe torque is 32 ft lbs iirc... Just so you know, the FRAM 7317 does not really cross to the correct filter like the purolators do. The FRAM catalog lists it as correct, but its not exact. It crosses to a 4610 purolator going by specs.
Oil Filter
matt167 replied to keith3267's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso which filter did u get? 6607, 7317 or 3593A?
2000 OB Calif Compliant - shop says needs new cat/sensors $2K
matt167 replied to mwd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck the rear 02 voltage with a scan tool first, make sure it's reading correctly.. If not, it might be the issue.. I found AM Auto parts has dirt cheap downstream sensors that fit these cars. I bought one for my Forester and it was $19 with free shipping, one for your car is $23... The sensor I bought works just fine. don't recommend cheeping out on an upstream sensor since it effects the fuel mapping but, a rear/ downstream sensor on a pre 2005 is just fine as long as it functions correctly
Retiring '97 Legacy
matt167 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think, if its a 2.5 the alarm should swap because the electronics are same.. The box is under the center console as I recall. I could be wrong..
Retiring '97 Legacy
matt167 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa 1999 legacy will have an ej222, and the electronics are different than the 1997 ej22e.. A 1999 outback has the old style electronics and will swap with an ej22e
Oil Filter
matt167 replied to keith3267's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow is it poor engineering if, every vehicle they sell uses the same battery, and all except the 6cyls use the same filter... You can't put a filter on it designed for a different engine, and expect a warranty to hold up.. Besides if you were going to do that, a Pl4612 would fit, look the same as the correct filter and I know it will be on the shelf. That's the most common filter for many things
EJ25D: difference between auto and manual trans?
matt167 replied to pginter96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep. The only engines in those years that were any different between auto and manual were ej22s and autos have egr, manual does not
Oil Filter
matt167 replied to keith3267's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXonly in some engines is the relief built into the engine, like the small block Chevy.. The Subaru uses the filter bypass. when it comes down to it, any filter that will fit will filter, but any except the spec filter will void warranty
2012 Impreza rear brakes
matt167 replied to matt167's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, those clips. One was pretty far gone. I thought it used 4 of them per set of brakes, so that's what I installed.
My mom recently had her rear brakes done at the local mechanic along with mounting her tires. I was going to do the brakes but with work, I haven't had the chance.. Anyway she got it home from the shop, but began making constant noise. She took it back and he said rotors had to have hotspots.. She asked me to take a look and. I took it all back apart, noted rotors were flaking and should not have had pads installed on them.. I put new rotors on it and noticed that there was only one brake pad retainer 'clip' per side. one on the bottom only. I'm used to Subaru's having them top and bottom, so I went and got a brake hardware kit and put them in.. But I wonder, did Subaru omit them for these FB engine cars or did he omit them? he has done at least one set of rear brakes on it in the past... Nothing about the brake system should have made a noise, those rotors would have just ate the brake pads in no time
Coolant overflow tank full??
matt167 replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyea, esp if its an ej25d still
1995-1997 Subaru Legacy L Wagon KOEO Test
matt167 replied to gbowne1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthose lights lit, key on engine off is normal
May need new tire. Do I replace all four?
matt167 replied to nitroman58's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXroad hazard is basically, un repairable damage within the first year or 25% of treadwear or less, the tire is replaced free of charge. After that, its pro rated. Caveat, a tire plug voids road hazard in most cases that its required
matt167 replied to nitroman58's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWalMart wont pull a temp plug to patch a tire. If the temp plug is failed, the tire is because the plugs can absorb water into the tire... Awd needs 4 tires. I've put 2 tires on subarus for people in a pinch. I'm not supposed to, but with a disclaimer signed, I can . You can feel and hear the tires fightingg
Ez30 swap outback. Logistics?
matt167 replied to Legback0203's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's a TCU issue with the CEL, you can use a microcontroller and a few resistors and such to mimmick a transmission functioning.. If you can mimmick a neutral position, that works in a lot of cars too. It's not looking for trans output then.. not sure about Subaru.
Wrong head gasket?
matt167 replied to Zaridar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou have about a 75% chance it's going to cause an issue, and a 100% chance that it will need new head gaskets if it does cause an issue... They are 22E heads, so just do them in car and forget about it.
1996 and 1997 Outback Manual Transmission Questions, Time sensitive
some have definitely made it into the states, but import costs ect, not many have, and those that have wont be cheap or listed as a regular trans.
a 4wd does not exist, at least not in north American subarus since the 80s... You can use pretty much any 4.44 ratio manual from 96- at lest the end of the ej series engine run.. After 1998, there may be sensor differences but idk. They will bolt up and function
gauge not lit.
matt167 replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpull the cluster. Couple screws, the fascia pops out, then usually 3 screws hold cluster in. Very easy to change bulbs.. They are T5 and T10 base bulbs. 194s can be used in the T10s and 74s can be used in the T5s. Subaru used some weird T5s that are uncommon for the gauge illumination, but 74s work
1996 subaru legacy L
matt167 replied to Coltb36's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would do an outback/sus hood and bumper for a hood scoop and fogs, SUS\GT rear deck if its a sedan for the spoiler, and some 2004ish 16" Impreza wheels. You can mount 205 55 16s on.
2.5 engine comparability
matt167 replied to Yotanut's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru used a couple different sensor wheel variations. Those sensor wheels need to match car or it wont run right.
miles to a tank
matt167 replied to shauny-s's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits done with a thermister I believe, and the gauge on mine reads below e before it comes on
