apintonut
Everything posted by apintonut
  1. Dose no offer a mini spool? Maybe sjr can get them? What is the axle diamiter and spline coint?
  2. Ive always just filled in between 2 teeth top and bottom in the same plase so they hit at the same time when turnd 180* back and forth so that you can still turn a corner with out as much wheel hop and ive only ever had a stick wellder to use
  3. Side drafts have been done
  4. Im building one right now to my best guess is im going to be 900-1100 lb my frame is only about 150 lb. I could probly save wieght buy spending more money but im trying to keep the price under 500$ if you built your own suspension and i think legacy would be easyer than ea82
  5. Just thouught it was better than buying honda springs and these older cars can be droopy in the bum
  6. Well this would be less work if i was using 4th gen parts but im going to make due but if some one had some garbage front struts for a dl i cut the bottoms off of that they would be willing to donate that would be cool as i want to make a upper control arm's im near kent wa
  7. Well still no title. Mager bummer, time to part it out. And build somthing els. Ive had a buggyworld.com frame i had sitting in my dads shed for 10 years so i drove down and picked it up and started mock up today. Going to part out the dl into this frame
  8. hmm im going to hafta disagree the carb is a good carb ive pulled pintos out of the woods after sitting 10+ years and put gas in them and drove them with out having to touch the carb they are solid and reliable bigger than a Hitachi
  9. If you live in ca you hafta put your stock carb back on every 2 years
  10. Still waiting on the title for this car if i dont get it soon ill just part it out
  11. Its been raining and the mess is a garage so no room to get the car in. So i havent worked on it painted my lift blue and one of the others red and one black
  12. Has any one tryed this? Its a pice of 2" tubing said 1.84 id 2 od i was just standing in the garge looking at my painted parts and thought ide try it looks like it worked good and realy cheap but its probly been seen by every one els im just a noob
  13. Has any one tryed this? Its a pice of 2" tubing said 1.84 id 2 od i was just standing in the garge looking at my painted parts and thought ide try it looks like it worked good and realy cheap but its probly been seen by every one els im just a noob
  14. well im going 2.5 body 4" suspension 14" wheels 225/85/r14 tsl (kinda funny found my wheels at the wrecking yard had them for a few days went to drill them out and seen some one had marked 3 of them to drill for a subaru
  15. well im going 2.5 body 4" suspension 14" wheels 225/85/r14 tsl (kinda funny found my wheels at the wrecking yard had them for a few days went to drill them out and seen some one had marked 3 of them to drill for a subaru
  16. +1 http://spokane.craigslist.org/rvs/3976821603.html frame already built
  17. not sure how far to go with the lift? 2" w/ springs and 2" blocks w/o body lift or if im going to body lift it should i do 2" 4" 6" ?
  18. nope 4cyl / 5 speed / junk yard / 50$
  19. they are WAY to stiff could have just welded it solid going to cut a coil and try again
  20. any one lift there car like this?
