montermahan
Everything posted by montermahan
  1. If the oil pump (or else where) is sucking air, causing lifters to not pump up solidly, wouldn't very small bubbles show up in the oil on the dipstick after the engine was run a while ???
  2. It is carburated, and the teflon coating on air filter cover has upped my gas mileage also. I streched relief spring in banjo fitting around 1/4" (don't talk metric), drove it 5 miles and no tick. time will tell. MM
  3. Thanks for the good write up tweety. I was curious what a stock Subaru was turning at highway speed's. The VW engine Redlined around 5,000 and at 3,000 RPM it was around 60 MPH, and the Subaru redline around 6,500 and I am turning 3,000 at 60. DaveT stated his was turning around 4,000 at 65. Mine at 4,000 would be 80. I would like to go with smaller tires to get my RPM up to 4,000 at 65, would have more power all way round, but I also like the 3,000 at cruse. Would be curious to know the difference in gas mileage and engine longevity. Maybee when It cools down around here, I will stick on a set of smaller tires and test for myself. I am now running 205/70R15's. I put a push button on my handlebars for the electric shiftdown, so I can hit it to pass or hold it in when going thru the gears for a higher shiftpoint, which is still 5,000 RPM, I don't think I want to change the governor weight's to get it up to around 6,500. sound's like it is really screaming at 5,000, but I'm used to VW's.
  4. Picture from the front. 2 GoldWing radiator's in front of rear fenders for cooling. Runs around 176 Deg. Adapted to a VW full auto trans. Kennedy adapter. 10 gal fuel. 32 MPG. Have 20,000 trouble free miles (ceptin sometimes a lifter tick). I have built around 10 trikes, VW's, Corvair's, 215 Buick, 151 Iron Duke motors, this by far is my favorite. Don't need no stinken paint, rust is like teflon--nothing sticks to it.
  5. Right now I'm running 15-50 Mobil-1 with about 1 pint MMO. It's 100 Deg. here now.
  6. I have a trike i built using an EA82 engine and VW automatic. Figureing my gear ratio, I should be running 130 MPH at 6,500 RPM. I run out of power at 90, which is 4,500 RPM (fast enough I know). I cruse at 60 and it is 3,000 RPM. was wondering what a stock one runs at.
  7. I purchased an adapter from an outfit called Kennedy, it was for an EA82 to VW automatic. worked perfect. don't know if they make one for ur motor. MM
  8. I have an EA82 engine on a trike I built adapted to a VW auto transaxle and it is working great. I purchased the engine from a person who got a bunch of them that were removed from cars in Japan and All I have is the serial # on the engine, It is 094690. Is there a way to identify what it is out of from this. Last year I replaced the oil pump seals and the TOD was gone for about 10,000 miles, now it is back sometimes, not continuously, I got a new seal kit for it and it come with a lip seal for the shaft, I thought I remembered it had an O-Ring shaft seal. Did some of them have an O-ring or my memory is weaker than this motors lifter system. I don't want to take the pump apart till I'm sure I have the right part's to put it back together. Thank's for any feedback. MM
