bearbalu
Topics posted by bearbalu
How to remove Power Steering Pump Reservoir
By bearbalu, in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 19 replies
- 16876 views
CEL, Vehicle Speed Sensor
- 2 replies
- 1019 views
Driver Side Power Window
- 4 replies
- 804 views
CEL, Speed Sensor
- 11 replies
- 2657 views
My notes from head gasket, timing belt, valve clearance and clutch job
- 8 replies
- 5691 views
Engine shake after Engine Removal/Head Gasket replacement
- 24 replies
- 7003 views
Can I swap spark plug wire 2 and 4?
- 6 replies
- 2253 views
Replace release bearing clip while replacing clutch?
- 3 replies
- 1293 views
Installing Flywheel on 98 outback - only one way?
- 8 replies
- 1233 views
Test engine compression with engine removed
- 16 replies
- 4086 views
redoing half moons on DOHC EJ25 head
- 6 replies
- 1182 views
Engine removal on 98 ob, pitching stopper must be removed?
- 6 replies
- 814 views
Counter clockwise rotation of crankshaft
- 4 replies
- 2809 views
Loosening Camshaft sprockets bolts - timing belt on or off?
- 6 replies
- 1089 views
Valve clearance with timing belt off, valve shim questions
- 4 replies
- 2632 views
Engine removed - when to put spark plugs?
- 7 replies
- 830 views
Putting clutch : Grease on transmission shaft main spline ?
- 2 replies
- 2751 views
Replaced head gasket - BLINKING Check Engine Light with Cylinder 2 misfire
- 17 replies
- 5379 views
Timing cover seals - adhesive or sealant?
- 3 replies
- 532 views
Fixing Timing belt Idler Bearings
- 6 replies
- 1220 views
Epoxy the punched hole in front outside timing cover...
- 6 replies
- 882 views
Sealant for Water Pump and Oil Pump
- 13 replies
- 6148 views
Cleaning cyclinder block, head, camshaft etc
- 1 reply
- 1311 views
