Another A/T  Binding Issue, my apologies
Vehicle:             1997 Legacy L Sedan (203,000 miles)
Engine:              2.2 Liter
Transmission:   4EAT
Symptoms:   Severe binding during turns, even slight deviation from straight ahead. Seems to lack power but that could be normal, as this is my first experience with
  Subaru.
Checks performed:
Tires and wheels match, pressure checked OK	FWD fuse installed, binding relieved but transmission noisy (whine)	ECU and TCM code retrieval procedure performed, no codes present (2hz)	Checked ATF, looked old/burnt, drained and refilled once (will repeat)	Checked Differential gear oil, at proper level and seemed fine	Checked  rear end, lifted rear of car with transmission in neutral, both wheels rotate freely and rotating either results in opposite wheel remaining stationary or opposite rotation. Manually rotated driveline, results in both wheels rotating in  the same direction, everything seems free, no resistance noted
Checks in progress:
Disconnect 16 pin multi-connector aft of throttle body on bell housing and check resistance of each sensor/solenoid	If all sensor/solenoids measure correctly, reconnect and check voltages/resistances at TCM
Help, Advice Requested!!!
Am I proceeding down a logical path for the symptom noted or should I be heading elsewhere? Please advise!
Electrical Engineer playing mechanic with Daughter's car!
Thanks
Navet
Update, Sensor/Solenoid resistance readings:
Vehicle Speed Sensor 1
450-720 Ohms (expected)         541 Ohms (Actual)        Correct
ATF Temperature Sensor
2100-2900 Ohms @ 68F           4200 Ohms @ ~35F (Actual)        Correct
Duty Solenoid "A"
1.5-4.5 Ohms (Expected)           3.3 Ohms (Actual)        Correct
Duty Solenoid "B"
9-17 Ohms (Expected)               13.3 Ohms (Actual)        Correct
Shift Solenoid 1
20-32 Ohms (Expected)              24.5 Ohms (Actual)        Correct
Shift Solenoid 2
20-32 Ohms (Expected)              24.4 Ohms (Actual)       Correct
Shift Solenoid 3
20-32 Ohms (Expected)              25 Ohms (Actual)        Correct
Duty Solenoid "C"
9-17 Ohms (Expected)                33 Ohms (Actual)        Houston, I think we have Problem!
I assume this means Solenoid "C" is bad? looking for confirmation before I pull the tail shaft housing.
Thanks again.
