bratdad
Everything posted by bratdad
  1. I have an 85 brat, and it said "VIN failure" also!
  2. I've had good luck getting suby parts thru Partsgeek.com where others don't offer them. Might be worth checking. I can't remember where I got the fuel pump tho!
  3. I actually cut threads into the steal flange and put in a short bolt w/ larger dia. as a temporary fix since the flange was tight against the head already. It only worked because 1 hole was still good and firmly attached to the head. When my son was ready to overhaul the engine, I did the correct fix and put heli-coils in the heads in the damaged holes.
  4. I agree with them. Everything should be tore down before washing/hot-tanking them. Heads can be done with the valves and springs still in them, but only if you're putting them back on right away and running the engine because some moisture can still be trapped in the valve guides. I run a machine shop for 19yrs now. The caustic solution will also "blacken" the aluminum if left in too long. I usually charge $50 to "cook" a bare block, so $80 is probably right depending on your area. Besides pine needles, I'd be concerned about moisture getting into the steel areas of the engine and rusting up.
