Everything posted by 19804wdPOS
Ok thanks
If i can't fix it she has to go to the "field"
Ea 71 engines and tranys
19804wdPOS replied to ivans imports's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I could use one of those -
Motor mounts and transmission mounts pooped out on me andi can't find a replacement for an '80 1.6 manual. If you have them and you are in washington i am willing to buy them.
I was just wondering if it be worth the time. I believe they only want $900 for it.
Are there any turbo/bigger motors that drop in?
I put a new oem cv axle in. I followed every step. It happened again.
I have not
Is it possible to build a turbo motor(120hp) on a stock 4wd transmission?
I fixed the чертовскй cv axle and it broke after half a mile. I think my car was destined to be rwd.
I believe that it is stock but I am not sure.
I can't open any of the links.How does one go about taking out the cage assembly?
Nick are you in the pnw? If so you should come out and help with the "little" project.
the axle popped out and I've wanted to go rwd and I'm lazy
I'm probably going to do this. So do i need stubs or can i just remove the front axles that attach to the knuckle?
There is no reverse 4wd in the '80 gl.
No reverse though.
How do i get the cv out?
So rwd?
Hmmmm... rally? Or rally?
Ok so i really dont want to replace the front axle and regrease it because as we all knoe thats messy. So should i fix it or do a rwd conversion?
I broke the passenger side axle shaft. That is why i asked.
I have an 80 gl 4wd and i was wondering if i could do an rwd conversion without swapping transmissions and everything?
I have a 1980 gl and i've been wondering about doing a 5 lug conversion. I really just want to know if i can use parts off of a gl10
