sid_vicious
Topics posted by sid_vicious
Timing Mystery
By sid_vicious, in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 5 replies
- 566 views
Spark Plug Change Problem 1 2
- 31 replies
- 3302 views
Vacuum Needle Goes Bonkers
- 8 replies
- 761 views
Clutch Pedal Behavior
- 4 replies
- 749 views
Phase II EJ25 Bellhousing Bolts
- 5 replies
- 4359 views
Phase II SOHC Coolant Temp Sender Compatibility?
- 3 replies
- 1085 views
Loose Rear Suspension
- 6 replies
- 827 views
Slow acceleration '03 OB Sport
- 5 replies
- 1693 views
Hose from throttle body to heater return pipe?
- 8 replies
- 1232 views
Question about the latest version of oil separator cover.
- 2 replies
- 1287 views
Rust on the the timing belt?
- 3 replies
- 857 views
Best spot for oil temperature sender?
- 2 replies
- 405 views
No CEL when oil pressure sender is disconnected?
- 8 replies
- 657 views
Torque Converter Stuck on Driveplate.
- 6 replies
- 832 views
OOPS...a question on fuel and AC discharge.
- 11 replies
- 730 views
Is this normal crankcase wear? (photos)
- 22 replies
- 1694 views
Anyone used a Topline rebuild kit?
- 5 replies
- 730 views
Bought an EJ22...think I got a good deal?
- 3 replies
- 477 views
What's an EJ22E?
- 3 replies
- 828 views
Timing Belt Help Needed ASAP
- 8 replies
- 1100 views
A note on dash lights.
- 10 replies
- 1330 views
Water pump seal (not the gasket)?
- 1 reply
- 729 views
Automatic vs. Manual trans for engine swap?
- 2 replies
- 787 views
Strut choice for Scorpion lift springs?
- 5 replies
- 859 views
'99 Outback Limited Brake Pads
- 2 replies
- 521 views
