3
Posts posted by scalman
snow is just best time for subarus... specially later ones with VDC
not much flex thats why you need something there to compensate that and keep those axles in one peace
winters 265/65r17
depends in where. they one of the cheapest sure. but low range is still low range , noone can touch it rly.
front 7 cm , rear 8cm lift
7cm without subframe drop is not good for offroad means for articulation its too much, so get back to 5cm , but then i tried something in rear without changing too much.
so i did rear subframe drop another 1,2cm all with oem bolts so i changed nothing just put some spacers only , so i gained space in wheel arches plus with that i put back rear 7cm lift. so its 8cm in all in rear now. and cv axles now happy they not compressed too much
so 5cm vs 8cm in rear 5cm still in front
when lifting it on struts more then 5cm in rear began problem with axles, i just put there older gen 2001 pbk cv with shorter axles from older like imprezas foresters maybe legacys , nots sure but those older sure are shorter axles .
i destroyed rear diff last time when i pushed 7cm lift on that in rear. so now i thought lets try shorter ones thats i used on my 2001 obk. and looks how much they changed . and really newer obk axles with cv's are lighter then older ones
obk axles are not shorter so i used obk CV and older impreza forester axles there with same diff cv but different wheel cv so i needed to make my own shorter ones. and result they are shorter and with that let me drop rear to 7cm lifts spacers just on struts. or find longer rear struts, which bmw has , bmw rear struts are like 10 cm longer and they fit, just 10 cm is like too much, and front struts on BR obk are like 8cm longer so in front you can lift front like without any spacer just with longer obk strut, just need to cut maybe spring 1cm or smt. but for rear you need drop subframe , but you can get same looking bmw rear strut thats is 10 cm longer. i means there you go long travel for cheap
i love those place where you can just exist alone there ... mostly... nice man , i wish i could have all that open area just for me .. some ppl would hate it ... i love it
- 1
that looks insane .. cool. do you like live there ? like its your yard lol ? cool . noone can tell you to not do it there... noone around lol
new MT tires
why you did lift and then went for largest rim ? well you gonna have more problems to find right tires for that size for sure. i think yoou could fit there with lift 235/75r15 so thats means you can fit there 225/65r17 . that was i was using at leats on 17 size there and then went to 15
spacers for rear that i needed to do long time ago but did just now, with some my own modifications that i didint saw others would do
because those spacers now that lower link doesnt fit anymore, so i saw that most just use then subframe spacers and drop all down then all fits fine.. but i mean its just small link and very simple made, so i redone it for my angle
and then front bumper cut
and now i need to redone relocate front hi lift jack points recovery points with that cut bumper
now with 3 points in front, one extra in middle to lift all front in one move
Since when subaru's got this bad? Did cvt killed it?
You guys see here pics or video, im not, on android phone, chrome
why i never found this info before from anyone ? SH9 forester front struts are about 2cm longer or more even and they fit bolt on for 3.0/2.0D BP outback models, so you get free lift , more travel for same price. rear ones could be adapted too , they just need bottom bushing changed i think. but for now i put SH9 forester struts in front with 5cm spacers, in all i got 7cm lift or some more there
small tires 225/50R17 , enjoying forest in this years amazing winter
- 1
how rear diff broke. looks like mine as all 2005 outbacks on 3.0 are 3.27 there , so will look now for other used one. cv axles are fine strangelly they didint broke or anything , only diff .
when i lift rear car passenger side wheel spins freely with cv axle and in diff there it bad noise , but drive shaft doesnt spin . driver side wheels spins with cv axle too and with drive shaft means that side is still good then . i wonder in wat way that diff could be still used , maybe make it welded diff then.
had some fun just before it started clicking rattling noise
now propper rear spare tire carier foldable back, 2 positions full back and just enough back so trunk will open for smaller spaces
hi lift jack winter edition upgrades
and as winter is here and snow is here that means to have lots fun with car
- 1
hi lift jack winter modification for better grip
tire carier done. looks strong , feels strong as well, folds down in 2 positions , fully or just enough to open trunk like in places where is not much space maybe, well just option that could be done easy so why not.
DIY tow hitch spare tire carier. just holes and bolts missing from pics.its folding back, when its folded back have idea to make then table on top of that so you can sit inside trunk and have table there or sit on sides in chairs. but that will add later.
with all those cheap led lights nowadays , those where like 10-25 euros and have led ring for like DRL and then full beam combine spread and spot. just 30w but they pretty small so could fit under grill even make it like hidden ones
215/65/17 2008 Outback
Posted
my speedo shows correct numbers even with 225/65 r17 but those wont fit without lift and some plastic cut. if i would find some good rubber i would then think what to do to fit them, as those tires dont come in all sizes in most cases . so you need to pick other size or do lift or smt. just check tire size comparison and then you will know . why guessing ? narrow tires are good for everything rly. just dpends what you going for there ... looks or more sidewall then you could go lower psi but car would handle more rubberish as you would have more higher tire so it would move more to sides ...
