jf1sf5
Everything posted by jf1sf5
  1. I have a monotube standard design (HotBits DT2), not an inverted like yours or the Proflex evo 2 I had before. You probably fit seals above and under the plain bearings to keep them lubricated ? Do you have any drawings of your design ?
  2. What oil are you going to use for the lubrication between housing and shaft (shock body) ? I have tried different hydraulic oils (LHM, ATF Dexron 3, motor oil, fork oil...) and the one that really works great is Motorex Fork Oil 2,5W (you can mix with higher grades). Have'nt tried other makes though. For the seals, I use PU (polyurethane) because they don't stick like the NBR do (Nitrile). Hope it helps !
  3. Ah ok, sorry for rubbing salt in the wound, it was only an information.
  4. I don't understand the "rub it in" but sure must be funny like you want me to send you a BG Outback...
  5. I got that exhaust for free but if I had to buy one, I'd buy a whole car. Here in Switzerland, you can find a BG Outback for 300/400 $ with 200Kkm.
  6. Like it how you are hanging the exhaust higher ! But wow, all that rust... Did some same sort of work last week. Frankensteined my Forester with a Legacy Outback BG exhaust manifold, up-pipe and down-pipe as the european specs make them take the same route as the turbo Subarus, above the front right cv axle. https://partsouq.com/en/catalog/genuine/unit?c=Subaru+Europe&ssd=%24HSUzdAJ2cgt_cnQ8IkkKCgEACk1ddllUS0xsdGNfY1MHWFcBdwJbFA%24&vid=212&cid=&uid=5410&q=jf1bg9lfbwgo89558
  7. I have Heri axles on my '97 Forester since 2+ years. The inner boots are very fragile and the inner cv's now have some play but still do the job. Its not super quality but the design helped a lot for the long travel coilovers (10"front, 11"rear, no body lift).
  8. I don't rally my forester but drove in Morocco on sand dunes and hit a hidden rock. Did a nice "bang" on the skid plate but only slightly bent it. I love the low range but mostly use it for crawling. With your bigger engines, I think that a standard forester 1,447:1 should be enough. And remember that you can shift from high to low on the fly, they have syncro rings ! But don't push too hard on them, they don't really appreciate...
  9. I have an 8mm aluminum skid plate made of Dural. Its bolted to the chassis with 7 bolts. I can hijack the front of the Forester 2 wheels off the ground without issues anywhere on the skid plate. Few pics of the 1,59:1 low range conversion, DCCD and the skid plate : http://www.forum4x4.org/threads/117587-Subaru-forester?p=2307266&viewfull=1#post2307266
  10. I haven't broken my Heri axles yet but they get a lot of play, like 4-5°. The concept is very good but quality is average. I bought them at Advanced Auto Parts through a friend living in Colorado 2 years ago. I'll try to find some FWD Legacy axles here in Switzerland.
  11. Very nice skid plate. Am impressed with the angle you can get with oem cv axles. I upgraded to Heri HD cv axles but they are not very HD though they give much more angle than oem. What cv axles do you use ?
  12. There are 3 different low range ratios in the EJ gearboxes. Early Imprezas ('93-'95) with 1.6 or 1.8 engines had the 1,59:1 with 3,9 differential ratio Foresters with the 2.0 engine had the 1,45:1 with 4,11 differential ratio Legacys with the 2.5 engine had the 1,19:1 (can't remember the differential ratio but think it's 3,9) Other engine/model/year had 1,45:1 and 1,19:1 but the 1,59:1 was only in the early Imprezas. As said by Cyfun, I think that low range would be too weak for rallying. Better find a 6 speed.
  13. Ah, ok, I see what you mean ! Like you, I have no more sway bars. I do more crawling up mountain tracks (no deserts here !) even though I went to Morocco twice. For more oversteer, I chose the DCCD center differential (35/65 split) route with the possibility to lock 50/50, and for better traction on slippery surfaces, Quaife helical differentials front and rear. And of course, the famous low range modified at 1,59:1 ! But this is your thread, and I'd love to have your skills and be able to adapt motorbike forks (KTM for example) and see if it works even better !
  14. The rear spring rates are softer because of the lighter weight and longer stroke. And because I usually travel empty. What is the tape measure ? (sorry, my english is very basic, I usually speak french !)
  15. http://www.forum4x4.org/threads/117587-Subaru-forester?p=2074279&viewfull=1#post2074279 Here are a few pics, didn't do any torn apart ones though…will do ! And here is a calculation I did for another Subaru enthusiast (email I sent him) First, I converted everything to metric, its easier for me… Weight front : 845 kg - 100 kg (unsprung weight) = 745 kg - 40 kg (strut spring force at ride height, 20 kg per side) = 705 kg Spring rates : 1x 254 mm x 50 N/mm + 1x 254 mm x 40 N/mm = 1x 508 mm x 22,2 N/mm ((50 x 40) : (50 + 40) = 22,2) 705 kg : 22,2 N/mm = 31,7 cm (amount of compression of the springs at full load like when diagonal spin occurs) Spring length at ride height : 508 mm - (317 : 2 = 158) = 350 mm (divided because the weight is on both front wheels) Ride height : 350 mm - 165 mm (thread height) = 185 mm (rod length) Weight rear : 710 kg - 100 kg = 610 kg - 40 kg = 570 kg Spring rates : 2x 280 mm x 40N/mm = 1x 560 mm x 20 N/mm 570 kg : 20 N/mm = 28,5 cm Spring length at ride height : 560 mm - (285 : 2 = 142) = 418 mm Ride height : 418 - 165 = 253 mm I did this calculation if you want to have maximum stroke (what I did to mine). Your hydraulic settings are quite hard I think but its easier to change the oil than the settings. HotBits uses ATF Dexron III (viscosity 34 cst@40°C). I changed for Motorex Fork Oil 7.5W because it works much smoother (no stick-slip) but has the same viscosity because my settings are like oem Subaru struts and I can harden the compression with the knobs (DT2) Et voilà ! Hope it helps you ! Vincent You can see that I use 2 springs per strut because I couldn't find long enough springs. Did this calculation for the newer struts and more for crawling than rallying. Edit : seems I can't post the images
  16. Hi pontoontodd ! Just signed up here to follow your build, especially the suspension setup. Your skills are amazing ! I have a '97 Forester which had custom Proflex Evo 2 struts built for a Forester engaged in the '08 Dakar. I bought them 2nd hand from Bruno Picard in '10 but don't use them anymore as they are not comfortable enough, its my daily. They are inverted struts, I had the same problem as you, the bearings needed to be lubricated to work properly so I tried to find a solution with upper and lower joints around the bearing and fork oil. The result was fine but needed too much maintenance... As I don't have your fabrication skills, I tried another route and found non-inverted struts built to my specs with 24cm stroke front and 26cm stroke rear. I calculated the maximum stroke possible in the front to be 24cm because of the inner CV's and steering components (no body lift) but I can see that you have even more stroke, especially on compression…how did you do that ?
  17. Hi all ! I live in Switzerland where Subarus are quite common, but no one modifies them….except me ! I found on this forum some very good reviews about engine swaps a few years back, which I did. Sorry for my english, I usually speak french.
