[Forester XT 2015] ECU Replacement
rodrigoijk replied to rodrigoijk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHello guys, thanks for the help. I bought an used ECU and convinced the Subaru dealer to reprogram it to my vehicle. He tried to do that, but he related the same problem, the used ECU is not responding as well. So now they think there is something else blocking the ECU or preventing it to communicate. :angry: They are 100% sure that it's not the wiring or a power supply problem. They opened a support case to Subaru in Japan and now I have to wait...
rodrigoijk replied to rodrigoijk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do I check if the immobilizer was triggered with the crash? Isn't the immobilizer just another computer in the vehicle? All the fuses are ok, according to the mechanics. I didn't inspect them by myself. And yes, the keys are correct, they open and lock the doors. This car has a keyless system, so when I push the start button, all the interior lights are turned on and the multimedia is working fine. The lights in the dashboard are displayed and even the mileage. My best option would be to buy that used ECU and ask the Subaru dealership to reprogram it to my car. Do you think they aren't able to do that? I suppose they should have all the keys, passwords, pin codes and everything to replace the original one, but looks like they are refusing just to sell a new one.
rodrigoijk replied to rodrigoijk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook the number of different versions of the same part.
Hello, I've bought a damaged Forester XT Premium 2015 and I'm starting the recovery process. While I'm waiting for the body parts I'm focusing in putting the engine to run. First I sent the car to an mechanic and he told me that the engine ecu is not responding, because his scanner wasn't able to connect to the vehicle to read any fault codes. After that I sent the vehicle to the Subaru dealership and they confirmed that the ecu is damaged and needs to be replaced. I think that diagnostic is weird, because the crash didn't affect much the engine or any electronic parts. Does anyone know about something that might be 'blocking' the access to the ecu, maybe due to the crash? Something like the air bag system blocking the engine or something? The dealership is asking me $2000 for a new ECU, while I found an used for around $600. Is it possible to just replace the original ECU by a similar from another car? Is there any kind of locks, keys, passwords or something that might block the communication between the ECUs? Regarding the ECU partnumbers, mine is: 22765AH011, while the used I found is 22765AH010. All the other parts I found in the stores are not equal, but similar partnumbers: 22765AG970, 22765AG973, 22765AH510. http://parts.subaru.com/ http://www.subarugenuineparts.com/ https://www.subarupartsdepot.com/oem-subaru-parts.html Are all these ECUs the same, but with different 'software versions'? Is it possible to know if they are compatible? All of them are for the same vehicle version: Forester XT Premium 2015. Thanks in advance for any enlightenment!!
rodrigoijk
