Posts posted by njdrsubaru
oh and p.s. to whoever comes across needing mt tranny mount bolts doing a 5 speed swap ( use your old crossmember bolts ) they are the same size!!
the bolts were the same for the rear part of the crossmember, the front ones i had to look for new 17mm bolts.... thank god i have countless cans of subaru bolts lol
did u end up getting the p1101 code?
ok I'm not quite done yet
I have a p1101 cel
does anyone know how to get rid of this code? it's the neutral switch malfunction.... do I have to run a wire from somewhere to one if the ecu pins?
tru true... i dont have any problems as of right now but i still have a cel of p1100...
i didnt have anyone to take pics for me but i'll do a write up of the steps, problems ive encountered and parts i needed to get from the dealer...
i can say one thing, if you drop the engine and trans married at once its a hell of alot easier... ive done many autos in the past but this is the easiest one i have ever done.
info to come...
that sucks.... i just did this swap like 3 days ago and i love it....best $700 bucks i ever spent on this car
i would go to a junkyard and pull one yourself ....youll walk away with it cheap!
just remember to buy new bushings..... i only got bushing for the shifter itself and not the stay rod and im regreting it..... also you will notice the 5 speed tranny mount is really soft .... might wanna go with a group n tranny mount later on....youll feel how soft all the bushings and mounts are the first time you get into it lol
i still hafta ground the pin on the ecu and wire up my reverse lights.... but its drivable right now.... i just left the auto's inhibitor switch hooked up and in the "park" position so it would start ( as well as the little black switch by the auto shifter was cut out by the wires and the wires connected together)
i just got the dreaded CEL but thats because of the ecu the code is p1702 and its cuz the auto isnt there and it knows it
if you have any questions pm me and ill do my best to help
-jarrid
I think I won't have too much problem with the cel... I have a 5spd ecu but I'm not there quite yet I have a few things to button up today and hopefully fire it up... I guess tomorrow will be a junk yard hopping day to find that shifter rod
ahhhh evrything went well except that the person who got me the 5spd swap kit gave me the wrong shifter rod... i need a new correct one anyone has one?
hey guys and gals
so ive created some b...s and started my 5spd swap prep... all parts have been collected and clutch kit will arrive on monday...
ill keep yall informed how it goes and im sure im gonna have tons of questions
ill place pics as soon as i get it all apart
actually I know they are jdm... it's in brazil, south America.... subaru started selling legacies there in 1991 with the ej18 and ej20 so that means all the NA ej20s up to 98 are non interference that's what I though thanks guys btw all the AWDs and dual range!!! yummy I'm looking into a 96 legacy wagon gx looks good but again I need to be there to buy it so it's gonna have to wait till I go see my mom
even the ones from the 90s? I thought those were based on the ej22
so im buying a subaru in another country so i have a car there when i go there... are the JDM EJ20 from 94 to 98 non-interference?
doh! it started doing it again today.... im gonna replace the ecu next and see if it gets better.... compression checked in all 4 cyl... im running out of options
ok this is the second day after replacing the intake manifold gaskets and still no sgn of misfire when starting cold or warm
I just replaced the intake gaskets lets see what happens I'll keep everyone informed
no cel... it misfires then if pu rev it up for a bit it stops as it goes back down to idle
it happens after I drive, park and let it cool down a bit then when I try I start it misfires for about 20 seconds or so or until I step on the gas reving it up
ok i changed the CTS and still doing it
now... can a intake manifold gasket do this?
i was thinking about that CTS...
o2 and knock wouldnt have a misfire symptom
it could run a bit lean or rich but not misfire like it is
now how about the AIC?
it usually happens when i first start in the am or after a drive
it misfires for about 45 seconds and it idles fine
now i have already replaced the following:
plugs, wires, coil, ignitor, injectors, fuel pressure regulator, fuel pump
im out of options
i am toying with the idea of a 5spd swap... i have 2 working autos but the reality is that they are more trouble than it is worth...
i hve done a search here my didnt come up with anything substantial
i need wiring info so i dont get a CEL on after the swap, ABS wiring info and any helpful tips
this is being done to a 97 outback, mind that i already have matching rear diffs all i need is to get a 4.11 manual trans
any info is much appreciated
thanks
successful swap now onto the AWD binding problem
good luck!
thanks... I'm gonna have lots of taupe body parts for your wagon, same color 8)
thanks guys I'm working on it right now...
5spd manual AWD question
Posted
hey guys
ive just finished my 5spd swap on my outback... now it feels like the tras doesnt have AWD... today is raining here in the NE, when i tried to take off from a stop light the front wheels were spinning and no traction to the rear.... is there something wrong with this trans? there is no torque bind
