How do 4WD EA82s do in snow autocross?
++++++++++++++ if 4WD has any advantage they will outlaw it or put it in another class ++++++++++++++
differences between EA82 and EA82T pistons etc?
+++++++++++++++? How about using thick head gsk? +++++++++++++++
circa 1980 emission controls
++++++++++++++++++++++ just can't bring myself to post this in the tech forum......but I've been making progress on my 1980 rat's nest of vauum tubes! i've isolated each device: distributor; vacuum control module for the coasting bypass valve in the carburetor; EGR; antibackfire valve. All temp control valves and solenoids bypassed for now. Here's the breakthru: I use drip irrigation 1/4 inch tubing "flag" emmiters as inline vacuum tube orifices. i use 4gallon per hour (4gph), 8gph, and 16gph. By driving around with a big vacuum guage in the windshield i connect and disconnect each device separately in order to become familiar with each devices' funtion and then regulate it's operation. By this method I've adjusted the vacuum control module for the coasting bypass valve, limited the maximum opening of the "EGR, and made the antibackfire valve operate as intended (this one is trickey because it uses a regulating dual diaphram control sytem similar to the distributor. to increase the antibackfire effect you restrict the upper hose with a smaller orifice.. These devices are no longer a mystery and i have found many cracked hoses. comments welcome
Are new struts still available?
++++++++++++++++++++ i put fwd strut tubes on my 1980 4wd. they were koni adjustable from: DCS consulting: 1755 Mission Rd., 2nd FloorSouth San Francisco, CA 94080+1220US Main Phone: (650) 756-3533Fax : (650) 756-5533Wholesale distributor of Koni obsolete and discontinued Koni shock absorbers. Exporter to Australia. +++++++++++++++++++++++ they were old stock and 2 for $17.50 on ebay. they sold me a third for $5. the first on i instlled clunked. so i had to take it apart and put a spacer between the inset and the bottom of the tube ( a 1" junk brass nut) now they're fine. a little too stiff at 1/2 setting. these things arn't too mysterious. i'd try any Subaru stuff. stay awayfrom Monroe! hope ths is helpful. ++++++++++++++++++++++++
Boot Repair (?)
I have been using GOOP for just about everything...... ++++++++++++++++ Its'been two months. Goop is still holding on the boot. No grease coming thru. ++++++++++++++++
Boot Repair (?)
Put in new fr axle and had difficulty. Loosened sway bar bolts. After turning and twisting the axle I found to my mucho consternation that I had ripped the new boot! from the bolt heads. Also reluctant to remove axle again because the threads are getting thin. I have been useing GOOP for just about everything. It retains some elasticity as it hardens into its final congealed and contracted state. Have cleaned boot with carb cleaner and applied several thin coats to speed drying. Later after a little grease came out had to glob on some more but now it's holding at 70mph. Actually there is more stress turning sharp corners when boot is cold. I think this would make a good off-road repair if you can wait a few hours for it to dry. At least it slows down grease loss and minimizes cleanup. Home Depot-$5
justy struts
Try DCS Consulting in San Francisco. Overstocked Konis. (on EBay) DCS1755@sbcglobal.net (650-756-3533) If they have them they will be cheap. I bought two for $17.50 and they threw in a third for $5. good luck. Very helpful people.
Choke heating element
Found it. The fuse is behind the fuse block. Label on it, in English, too! Right next to the fuel pump fuse. Thanks all for the help.
Screwing around with a screwdriver and blew fuse or something on choke heater element-1980. Fuses ckeck out. now what? Help apprec. Why did i buy these Haynes manuals anyway?
Old info that I think should be revisited..
Let's keep this alive! Fugi Heavy industries might have made some military vehicles for export using Subaru parts. How's your Japanese? Along the lines of disengaging one rear axle: Chevvy S-10 used a vacuum- shifted spline sleeve. What a concept--turning spider gears for a zillion miles.
Subuie in a Corvair convertible?
Yeah. P 914 would work too, but face only a mother could love.
Strut insert replacement.
Haynes is not helping me here. Is the inner shock cartridge removeable on the '78-80's? I'm getting some Koni's from a 2wd and I wonder if I can install them in my '80 4wd. Also wondering if grease seal replacement on transaxle is straight forward?
The engine was installed in the middle with stock dif. and modified saginaw 4sp tranny. The corvair (sag) end-cap was removed and a modified (sag) input shaft intalled(from most any Chevvy trans). The modification was to internally machine the shaft to the dimensions of the corvair shaft and install the needle brgs. There was about a 3/16 plate betwee the bell housing and the trans which provided motor mounts and "collared" the t.o.b. snout which replaced the old corvair end-cap. There were 4 roll pin holes drilled thru the plate and the cast iron trans to provide allignment and as described the integrity was dependent upon the snout which was bolted to the cast iron trans--but was never cast with the idea of providing strength. Corvette could have had a decent mid-engine set-up at any time merely by having Saginaw cast the 4sp Chevelle trans with the "ears" on the back end like the Corvair. The trans and differential were strong. This set up was long and heavy, however, compared to an alloy transaxle. my failures were due to hittng curbs in autocrosses. and due to mis-aligned adapter plate holes during contruction. The kit from Crown Mfg was drag raced successfully (w/o breaking) with big blocks. The competition in ice racing was stiff with: shortened Corvette auto; Chevvy Healy; Ford MGB; Porsche, Jeep Quadritrac tubeframe. I moved on to a turbo X1/9. (smaller class.) Moral: there's alot more to building a mid-engined car than the engine placement. Driving the car at night when you punched it, the headlights were in the tree-tops. Noise was deafening what with the crank pulley right about where your kidneys are! Subie conversion would leave room for decent seats and engine cover. The Crown kit had Fibreglas seat and engine cover. I don't think we had ur. foam back then but it would have helped alot.(around 1978)
I put a 327 corvette motor in a '66 corvair some years ago for ice racing. It was heavy and the tranny broke alot. But the car wasn't bad. A flat six 5-speed with low center of gravity and light weight would be better. The car could be lightened up instead of being made heavier. Radiator was easy to install (used Ford GT40 style hood ducts) Last summer i met a guy from indiana who has a couple of Yenko Stingers. He said there is a surprising following for corvairs and many speedparts are available on the cheap. Tires and wheels are chevvy 5-bolt. Cool street machine?
EA82 carb running like crap
Maybe no vacuum advance. BTW what did removing the front sway bar buy you? There used to be a St Joseph hospital in FBKS-born there. Still got a Lathrop High?
wrw166
