Everything posted by Tireman28
Blowing oil out valve cover vent tube. Help
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD DO I HAVE TO BACK THE HEAD BOLTS OFF 180 DEGREES TWICE, OR CAN I SOMEHOW SKIP THAT STEP. IM NOT SURE IF THERE IS A BETTER WAY TO TORQUE THEM OR NOT.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are decked.20 over. Haven’t checked
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHaving them cut back flat today. Idk what happened. I’ve torqued these heads a million times. Not sure what happened. Maybe just the quality of gasket. I had the felpro the first time, then i tried I think the brand was cometic or somthing. The metal shim type. What type of gasket material are the 2004 sti ones u reccomened?
EJ22 Water pump change without removing timing belt
Tireman28 replied to Zoltan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt won’t work brother. Need to remove it. It’s way easier and faster.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD ANY SUGGESTIONS ON HEAD STUDS? I RACED SATURDAY NIGHT AND BOTH HEAD GASKETS WERE BLOWN RIGHT IN THE MIDDLE. I ORDERED THE GASKETS U RECOMMENED TO USE. IM NOT SURE IF MY HEAD BOLTS ARE HOLDING UP OR NOT.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat head gasket do u recommend for my race car?
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThought so. I’ll redo them. I had to redo the driver side head last night. But didn’t check the pass side. Plugs looked good on pass side so I assumed. Thanks alot
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAwsome info GD. Also only other issue I had was the coolant from the system kept filling up the over flow tank
2003 Impreza rs. Round track race car. I race in 3 rd gear at the rev limiter. It literally will blow out 1-2 qts of oil and dump it into the air breather. Any help?
2004 Impreza rs.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCar runs great has a spoob ton of power. Def needs to be tuned though. Not getting anywhere w the enduring solutions. I’ve emailed and there website is hard to navigate. I have no idea what I need to tune it.
2004 Impreza rs.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do I do the esl swap? Where do I start to buy the process?
Best racing clutch
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat will work with my “push type” hydro clutch??
2004 Impreza rs.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do I delete the rev limiter?
Best racing clutch
Have a 2003 Impreza rs 2.5, 3000 race grind cam, stock valves, and ported heads. What is the best racing clutch for this car. Again my car is a round track oval race car, we run 30laps a race and it’s WOT, brake, left turn all night. Lol.
2004 Impreza rs.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI’m listening Matt. Any advice on where to start?
2004 Impreza rs.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood question about the Brz computer. I wonder what year?
2004 Impreza rs.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit is a round track asphalt race car. I'm having a 3000 race grind from delta cams, one over sti valves, and porting pretty heavy. just not sure if i will need a tune or not. i just don't want it to go to lean and bust something. and i also have the year wrong, its an 2003
2004 Impreza rs.
Will a Cobb access port work on this car. It’s a na ej25 sohc. And if so what one do I need to buy just as a tuner. Is there anymore options?
How to delete rev limiter 93 Legacy.
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I run fuel injection. It’s asphalt oval and kinda like mini stock yes. My stagger I currently went up to my largest is around 71 3/4. I just need more straightaway power. Feels great coming out of the corners just cuts out about 40 foot too soon.
I have 93 ej22 that I race on the round track asphalt. Cuts out at 6500 rpm in 3 rd gear. Need more rpm. Just a little. I need prolly around 7000 or 7100. Any advice?
93 ej22 motor with 02 Impreza transmission
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat’s what I was thinking as well. How different is that? Do I need the entire pedal assembley out of the wrx?
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI’m only concerned because my ej22 is a cable clutch setup and the ej20 Impreza transmission was a push clutch hydro setup.
What type of clutch do I need to run? The 2002 Impreza clutch?
2004 subaru impreza rs 2.5l
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat about head work? ive had cams done at delta, 3000 race grind. will the stock bottem end handle them? or do I need to get forged bottom end?
what are some plug and play horsepower tuners for this car.
