Raynman1989
Everything posted by Raynman1989
I'm after a new tailshaft for my legacy. I know that subaru tailshafts aren't technically rebuildable and that they can actually be rebuilt but I can't find anyone locally to do it so im wondering what my options are? Is the gt tailshaft the same as the none gt lagacy? Someone has stated that newer gen driveshafts are compatible, is this true and if so which ones?
I "think" my tailshaft needs replacing, u-joints feel quite rough when moved by hand, centre bearing rubber housing seems okay (no cracks) besides it sagging but I do get a "vibration" under hard acceleration that feels exactly like a center bearing housing failure. Maybe the vibration is something else? Apparently these tailshafts can't be rebuilt and with the car being an uncommon import I'm having a hard time finding what tailshafts are compatible.
A previous owner of my legacy gt has cut off part of the pitch stop mount so it is no longer welded to the firewall. What are some suggestions? Just leave it off? And maybe upgrade the engine mounts to something stiffer? Weld it without removing anything in the engine bay? Making a homemade bracket and using some big rivets?
I just fitted a 22mm whiteline front Sway bar and endlinks and to my untrained eye the different angle between the link and bar looks terrible (it's the same on both sides). The car also has lowering springs which of course make the angle worse. Is it going to be an issue? Surely it will wear the bushes out considerably faster at the very least?
The motors done 220,000ks and had a full service history (headgaskets hadn't been replaced in that time) up until about 20,000ks before I got hold of it. I took the previous engine out due to headgasket issues. Guess I may as well do the headgaskets with the symptoms it's got and considering I've got headgaskets for it and need to replace the clutch while it's out. Tbh I've never really spent too much time trying to "burp the coolant system besides running the engine with the cap off, will air in the system stop circulation?
Yeah I mean distance it's only about half a tooth away from the mark (the mark lands between 2 teeth). Moving it would make it an equal distance past the tooth. Man I've really been hoping it's not a headgasket. Only just put this engine in and done under 10,000ks on it but everything seems to be pointing at a headgasket failure
I've been having some issues with my ej, overheating and high fuel usage. I ook the timing cover off to check the water pump and noticed the timing seems to be off by about 1 tooth. If I line up one cam and the crank with their marks then the remaining cam doesn't line up but moving the cam 1 tooth causes it to move past the mark and still not line up. The timing belt shouldn't be stretched (if they even stretch) since it's only done about 10,000ks. Should I just move the belt that one extra tooth and see if it changes anything?
Ej22 l series running hot/overheating
Raynman1989 replied to Raynman1989's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Man I sure hope it's not the headgasket as the motor only just went in to replace a motor with leaky headgaskets but I haven't been contemplating taking the motor out to replace the clutch so that will be a good time to do the headgaskets. Will a compressions test pick up on a leaky headgasket? Surely by now all the air would be out of the cooling system? Or can air work it's way in at any time? Phase 1 (1989) ej22e? Well tbh I've only had a block temp gauge to go off but I can certainly tell when an engine is running hotter besides the block temp reading considerable higher, a large amount of coolant overflowing from the radiator and the smell of a cooking motor -
Having trouble keeping my ej22 cool in my l series. I've fitted an aluminium (cheap ebay one) ej radiator and have both thermo fans hooked up together. It runs fine on the highway and in cooler weather but when the ambient temperature starts getting over 20⁰C the temperature will start climbing, especially on the beach and in stop start traffic. There is a slight coolant leak that I can't find, used maybe 1 litre on a recent 700km trip. Could that cause overheating?
Different driveshafts for l series?
Raynman1989 posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just curious If there were different driveshafts for the l series? The reason I ask is I bought some kelpro cv boots for a set of repco front driveshafts I purchased not too long ago and the boots are about 10mm too small in diameter on the large end for the cv cups. This caused me to check the diameter of the old driveshafts I've had laying around and they are smaller (the correct size for the kelpro boots I bought). I thought maybe repco just decided to make them bigger but I went back instore and the shafts they have are of the smaller size. So was there a particular model that for some reason had heavier duty driveshafts and I've somehow ended up with them? I'd like to find out so I can try and possibly get some kelpro boots to suit instead of the crappy universal ones I'll have to use for now. The car is a 5spd 89 touring wagon. -
Nah i definitely made it more complicated than need be haha. Yeah when it'd "not working" in the car it clicking ever time throwing the gear out but only spins maybe every 10 key turn. I have taken the whole thing apart and cleaned everything including the brushes and armature and whatever else is in there but maybe the brushes do need replacing, they look fine although obviously worn.
Sorry if I didn't explain it very clearly, I'll break it down as best I can. Starter was working intermittently, most of the time it was just clicking. Tested it out if the car and it was the same. Took the whole starter motor apart, cleaned every contact surface and replaced the solenoid plunger and contacts with new ones. Still doesn't work when fitted to the car but now works fine when tested on the bench (gear is thrown out and motor spins). Test fitted a totally different starter motor from a newer vehicle and it works 100%.
It's not the original unit but it is a "fuji heavy industries" unit. Weirdly enough I've got the starter to work 100% while out of the car but when I fit it to the car it still does the same thing, just clicks. The other starter motor i have that fits but isn't the right one for the car works fine though! I'm confused even more now. Could it be the ignition relay isn't supplying enough amps and the newer starter requires less therefore it works?
Alright so I just fitted new contacts and a new plunger and also took the motor apart and gave all the contact points a good sand/clean and it's still got the same issue
Well I narrowed it down to the starter being the issue, fitted a starter from a liberty and it works 100% besides the grinding if you don't let go of the key quick enough haha. Managed to get my hands on some contacts and a plunger so I'll replace those and see if it fixes the problem.
So I've recently been having trouble with my starter motor. Sometimes (not often) it will start right up and other times it try for about 1 minute and it will eventually start. Now I am hearing a "clicking" like the solenoid is working but the starter doesn't turn. I took it apart and clean/adjusted the solenoid contacts but it made no difference. I pulled the gear out by hand and it seemed smooth also the plunger seems in good condition and moves easily. Will/can an auto electrician rebuild it? Id attempt to rebuild it myself but I plan on using the car soon and I can't get parts quickly. Should I just buy a new one? Id prefer not to since it's a genuine on. Cheers
How would an ej22 manual with low range l series compare to a h6 outback auto without low range? I've currently got a lifted ej22 l series and I'm thinking of upgrading to a 2005ish h6 outback auto. I would eventually lift the outback 2-4 inches when funds allow it. I'm leaning towards the outback as it's newer, more powerful, safer, better on road, better parts availability. I don't do any extreme off roading but I do a lot of sand driving and occasionally go to the local 4x4 parks. Basically it comes down to will the outback without low range still be just as capable in the sand and occasionally doing some medium difficulty 4wd "only" tracks?
Ej22 poor fuel consumption
I found the connectors I believe they consist of 2 green and 2 black according to someone else. Only problem is the guy who did the ej22 swap seems to have cut of one of the black connector. Any idea what colour the wire should be so i can try and find it?
