consmi
Everything posted by consmi
  1. Brake rotors and pads replaced, handbrake didn't work so we were leaving it in reverse gear to hill hold while parking it for about 2 weeks before going back to get it tightened.
  2. Yes it's all wheel drive, transmission oil is fine. Have not checked differentials. Good idea, I need to get more jacks. Thanks
  3. (updated with the answer) Symptoms: The transmission on my 5 speed 2000 Legacy GT (AWD) sounds like an angle grinder or go-cart (grinding/buzzing/putting noise). Started making noise overnight, in every gear and in neutral, sounds like something rotating/grinding and is proportional to the car's speed. When the car isn't moving there isn't any noise. Another interesting thing is that in 5th gear (possibly others, but most noticeable in 5th) it makes noise with 0 throttle, less noise with 1/8th throttle, and then more noise again if you go past that. What more knowledgeable friends have said: A trusted mechanic said it's probably a bearing in the transmission, but he doesn't work on them so I'm not confident he knows the exact issue. A good friend said he had a similar issue on his 2000s era Forester, and it was the center differential, but I've heard that if the differential is the issue, the symptoms will get worse while making tight turns, and I haven't experienced that, at least at low speeds. Possibly relevant info: I had a rear tire replaced this past summer, they didn't shave it down. I measured them and it was essentially the same size. Maybe a small difference in diameter caused an issue? ANSWER: I'm transcribing from the mechanic so this may not be 100% accurate: The transfer gear was split, which damaged/destroyed center differential (and the back clip came off). The transfer case damaged as well. The mechanic said it was just normal wear and tear, so I'm not sure if this had anything to do with one of the tires being replaced.
