cmiller
Everything posted by cmiller
  1. Ok, so I've re-wired the starter signal wire to the black wire with the red stripe coming off of the starter solenoid. I tried to start it up again and nothing has changed. Still dies after a couple of seconds. Also I checked the codes again and now the CEL just flashed constantly... Just FYI there is no exhaust on this except for the headers, no cat/O2 sensor, nothing. But that shouldn't make a difference here... I'm running out of ideas other than the IAC is toasted or out of adjustment even thought the factory paint on the screws hasn't moved. If the timing were off would it react like this? Any other thoughts?
  2. Ok, thanks. I'll just put a T in one of the lines coming off of the black vaccum canister behind the passenger side head light. I'll look into this and run the starter signal wire off of this. Its sounding like this is the issue. I have all the PCV and IAC lines hooked up properly. Could the Idle Air Control be bad or out of adjustment? The factory paint on the screws is intact so nobody has messed with it, should I try adjusting it? I'm assuming the SPFI Loyale fuel pump is sufficient? Do I need to get a MPFI Turbo fuel pump? Thanks for your help.
  3. Do you have a pic of this? not quite sure what you mean here, sorry. I can hear the Fuel Pump turn on when the key is on. So I know its working. The power for it is coming off of the old EA ECU harness. I'm pulling it from a wire marked Ignition Switch, pole 38 on the large plug for the EA ECU pinout sheet. All of my vacuum hoses are hooked up and fluids are perfect. There's just something that I can't seem to find that is keeping the motor from running more than a couple of seconds. I'm keeping at it all day but if anyone has any other suggestions or is available to call me please let me know. It's frustrating when you're so close...
  4. I switched MAF sensors and tried to start it again. It fires right up runs for 2 secs and then dies, even faster when I give it throttle, same as last time. Don't know what to do there. Also I checked the codes and I'm getting a "Code 12" which I'm guessing is the starter switch or circuit? How would that effect it from idling when it fires right up?
  5. Anyone know what this vacuum canister is? Do I need to keep it in with my EJ22? It had a line coming off of a EA sensor module on the motor. Where did you EJ swap guys put this into on the EJ motor? Thanks!
  6. Here's a few pics: Engine in and running Using the EA lower half of the air box with tabs welded on to accept the EJ top part of the air box and a K&N panel filter inside. Also just used a small tube bender to mate the EJ power steering lines to the EA lines on the engine cross member. They hooked right up perfectly.
  7. I agree, a re-seal is way too easy to pass up. You can pull the motor, re-seal it, and drop it back in all within a day, easy, done, no worries.
  8. That is exactly what its doing, open throttle and... blah...dead. But even just sitting there it will die on its own. So I'll check the codes tomorrow and see whats up. Thanks again for your help.
  9. IT'S ALIVE!!:banana::banana::headbang::headbang: I was missing a couple of relays and also had the wire from the fuseable links grounded instead of hot. (Duh). It fired right up first try! The only thing now is it won't idle so I'm thinking it needs the O2 sensor and a cat on or the maf sensor is bad. I'll try swapping these out to see what's up. Scoobyclimbs was a great help today in helping me problem solve the mess. I have video and will post it up a little later along with some pics as soon as I finish putting it all back together. Thanks everyone for your help and suggestions. I would still really like to see how you guys kept A/C with this EJ swap so if you have any pics please put em up. I just don't see the room for the condenser and radiator fans.
  10. I got the switched 12V from the ingnition switch wire going to to the old EA ECU. My problem is that the EJ harness is powered fine, just to power to the rest of the car, All connections to the EA fuse box are dead...
  11. Hey Numbchux, there is a pigtail on the EJ harness that you have wires labeled Fuel Pump and Switched 12v on it. Also there are a bunch of yellow wires on the same pigtail going to a tan plug (6 wires) and a light green plug (4 wires). What are these two plugs for?
  12. Or maybe just time for some new tires...? Bald tires and wet gravel seem to be the contributor here.
  13. I did remove the wires that were hooked up to the EA coil. It looked like there was a power feed from this to the harness because it had an inline fuse. Could this be the culprit?
  14. Yep, no power past the firewall. No head lights, dome light, dash lights, or anything. When the key is on nothing happens. No lights anywhere. Very confusing...
  15. Results here: http://www.rallydata.com/Results/MtHood_2009_ClubScoreBoard.htm
  16. Starter is getting power, fused links are fine, just no power to the interior harness. So ECU doesn't know when the key is on. hmm... So tomorrow more trouble shooting and hopefully get it started!
  17. Top 8 CARS after SS 4: Mager Leads, Svedin +0:26, Eklund +0:03, Buren +0:22, Garth +0:06, Goodwi +0:25, Mark T +0:40, Beck +0:01
  18. I'm going to try and triple check everything again today to see what went wrong. It would be great to see another EJ swapped EA rig to compare to.
  19. I made a lot of progress today. I got all of the wiring hooked up under the dash, got the air intake installed, radiator fans mounted up, and cleaned up the engine compartment wiring. So I hooked up the battery and turned the key and...... nothing, no fuel pump coming on, no lights, nothing. Okay, so maybe the optima battery is dead since its been sitting for a couple of weeks(yeah right), checked, as expected 100% good. So i have spent the last half of the afternoon today checking my connections, correct wiring, etc... nothing. I'm out of ideas... Is there anyone in the Portland area that has done an EA to EJ swap that could come over this Saturday, Sunday or even Monday and double check my work to see if I have missed anything? :confused: I can offer food, beer, even some cash for your troubles. PM me if you can. Thanks!
  20. Tonight I got the wire harness in the car and routed properly. It took awhile to make room through the fender and behind the strut but I got both halves in and under the dash. Just need to splice a few wires before starting it up. If it runs then everything will get put in its place and bolted back on.
  21. Thanks to Numbchux I figured out what needs to be removed and what stays to be spliced into. The wires on the left all stay (mainly headlights, corner lights, horn, turn signals, etc...). The wires on the right are all from the EA harness and need to be removed. The hard part is finding what goes where under the dash so I can pull the un-needed wires out. Then I should have enough room to push the EJ harness through here and hook it all up. Also the spot in the upper right of this picture has some wires (green and yellow plugs on the left) that need to be taken out so I can thread the other half of the EJ harness through. Its a small hole behind the strut but should work if I can get all of the un-needed stuff out. Getting closer to having this all hooked up. I should have it all working by this weekend. Then off to get an exhaust put on...
  22. The mechanical part is fairly straight forward and goes in quite well. The wiring takes a bit more time and resources to do. I've been only able to work on this after work each day so it takes a bit longer. Luckily when I run into a snag there is the USMB as a great resource of info from folks that have done the leg work already.
  23. The Mt. Hood Rally is coming up this weekend out in Hood River, OR. info here: http://www.mthoodrally.com/2009/
  24. Thanks Chux, The PDF for the Loyale is a great help. I just thought that since on the Legacy, part of the harness went through the firewall in the middle of the engine compartment instead of through the fender. So to me it looked short from the factory not from your modification. I'll see if I can snug it up and get it through the fender wall. So this pin out is from the plugs that plug in to the back of the gauge cluster not the mess under the dash? If so that makes it a ton easier to cope with. What did you get this pin out from? Haynes, Chilton, or Service Manual? Thanks again for your help.
  25. Here's the rats nest: everything is labeled and sorted on the engine side, just that getting it to all connect to the EA bits is a PITA!
