104
Posts posted by 1 Lucky Texan
I paid just under 25K for my '03 OBW H6 AT (no VDC) a coupla months ago.
fyi
Carl
1 Lucky Texan
If you have eliminated the possibilty of swapping a fuse or a relay(if it even applies) then you certainly could use a voltmeter or even one of those lamp testers with the sharp probe to see if there is voltage being applied to the siren. Check the parts store, they should have one. just clip to a good ground and stick the point through the insulation (better to touch the connector if you can get to it). and see if is flashes when you 'break in'.
Carl
1 Lucky Texan
What year did Subarus switch to the new refrigerant?
Carl
1 Lucky Texan
You deserve a big round of APPLAUSE!!!
I wish I had your dedication, I woulda' let the dealer have it I think. Though there was a time in my life when I HAD to fix the '48 Willys, the '51 Chevy(that thing ATE generators!), the '78 Civic that sucked a valve in cylender #2, the '64 Ramb - well- other car issues in my life) 'cause of no money but I guess I've gotten lazy and stiff as I've gotten older.
Also, I think this thread will be helpful for folks in the future too. I learned a lot. You have helped unknown future Sube owners and they OWE YOU MAN!
good job
Carl
1 Lucky Texan
Brian, if he used the FWD fuse under the hood would that help in diagnosing the problem?
Carl
1 Lucky Texan
A few posts up LorryB confirmed that a tab was broken off.
Even if there are other confusing issues, it won't start now.
I doubt a reliable fix for the existing gear is possible. So, over on marketplace or at a local junkyard ,a used one might be found. Otherwise, a new one will need to be purchased.
too bad - but I think you're close!
Also, it probably isn't a problem, but can any of you other guys explain about the tenisoner? Is it gonna 'pump up' like a hydraulic lifter? If so, what keeps up from being to loose when the engines starts?
Carl
1 Lucky Texan
Where's the crank angle sensor on this engine? Could it be damaged/disconnected?
I'd confirm spark/fuel again.
Did you try the trick with a strip of paper at the exhaust to see if it gets sucked in when cranking the off-timed engine? Maybe it would show you an out-of-time indication now if you think the timing is drastically out of sync. Probably need a helper to crank the engine though.
Hope you get it running soon.
Carl
1 Lucky Texan
If its like my OBW, there is a connector under the driver door sill that is used to engae/disengage the 'passive arming'.
I've gotten used to using the driver door switch and closing it last, but my wife complained that this car DOESN'T passive arm like her Windstar did. I just didn't tell her about the option. ;^) There's little danger of her finding it in the manual - based on previous experience.
Carl
1 Lucky Texan
I wonder if a 'weak' or clogged PCV could cause oil to 'go' somewhere? (valve guides?) Is that the only symptom? Cylinder wash down from a bad injector could maybe cause high oil consumption.
just guessing
Carl
1 Lucky Texan
Of course no one can tell you how long it will last, but from an engineering point of view, having an axis that something can now vibrate/move around is usually a recipe for disaster. That third bolt was preventing that. You now have a line instead of a tripod support. Any movement will be concentraed between the 2 remainig supports. Fix it soon.
Carl
1 Lucky Texan
check eBay but others have pointed out the importance of getting the same FCC number on the back of the remote.
Carl
1 Lucky Texan
Take your vehicle back to Autozone (or similar) and have them check the alt voltage. maybe it's too high.
In most of Texas, 3-4 years is max lifespan. I wonder if higher than normal temps on the east coast has killed some batts.? I've read that high CCA batts dont like the heat and high reserve capacity (like those for the South) don't tlike th cold - but regardless I hope you got some pro-rated consideration on the warranty - that is VERY short lifespan under any conditions.
Carl
1 Lucky Texan
Could you or a family member have driven through deep water recently?
Here's a WAG - If the tranny gets cooled off by being submerged in deep water, contraction can suck water inside that could vaporize at operating temp causing a 'geyser' like effect - um I GUESS.
Carl
1 Lucky Texan
I don't know if I can help, but others may be able to if you give us some more info.
You say it couldn't have been overfilled 9 months ago. Did you look?
Also, what is the level now(after the 'burp')?
Did you get a CEL or an AT Temp light.
Did you check any other fluids to be sure that's where the smoke came from?
Carl
1 Lucky Texan
I had a Toyota burn through a <3k old timing belt when I was hundreds of miles from home because I wanted to 'save money' and didn't change the tensioner bearing.
My personal feeling s are - if you really need the highest reliabilty, you change everthing that is turned by or runs against the TB (within reason of course) AND every seal you can get to.
Carl
1 Lucky Texan
....at
http://www.freebmw.net/share/CarsBoatsBikes/Subaru/FSM/
might not be up long!
Carl
1 Lucky Texan
HEY! I just remembered reading posts about the harmonic balancer not getting enough torque when its reinstalled, something about the books all being wrong. Do a search for that thread and see it it may have applied to your engine.
just a heads up
Carl
1 Lucky Texan
I think you should GO to the dealership and have then SHOW you why they think the crank is bad. I agree that sounds a little weird unless its something like that keyway issue.
Unless you heard noises (not rough running - actual metal on metal sounds) then the valves should be OK. If this is a SOHC engine, from what I've read, the valves won't hit each other anyway.
If you have the skills, time ,inclination, fix it yourself. I certainly wouldn't have this dealership do the work UNLESS they can 'buy' you confidence after some 'face time'..
good luck
Carl
1 Lucky Texan
(thanx for the update!)
So, my '03 OBW won't need an inspection sticker for 2 years. When it does, will they find a dual dyno setup for it, do some kinda abreviated emissions test without a dyno or use the FWD fuse and test it like a FWD car?
Carl
1 Lucky Texan (D/FW area)
Want to say thanx. I'm enjoying reading the data and thinking about the weird differences the Soob engines have from 'regular' engines.
thanx again
Carl
1 Lucky Texan
I think you tried as hard as anyone would expect and I would've given up sooner I think (given the distance you had to drive to the vehicle).
PLEASE let us know what they find - don't leave us hanging OK?
Carl
1 Lucky Texan
Do you still have the fuel smell? If so, it would be cool if next time the poor running condition presented itself you could pull #1 plug to see if it was wet with fuel. Can an injector stick open intermittently?
just a WAG
Carl
1 Lucky Texan
One thing I've learned from this board is that some Subarus (like mine) have a fuse which can be installed under the hood to force the AT into front wheel drive only mode. This MAY help isolate the problem. Also, are both rear tires the same size? Different diameters can cause torque bind. I suspect your mechanic would've noticed though. I'm sure others here will have more help for you.
Carl
1 Lucky Texan
Keep in mind - BOTH of these cars wouyld be new to YOU and a real pleasure after so many miles in you present vehicle. AND the 2004 will be a used car too the insatnat you drive from the lot.
Still, if you have the funds to 'get what you want' you should do that. Don't 'settle' for less. As much as you are in your vehicle - you shouldn't have buyer's remorse traveling with you - either for the money you spent OR the model you bought.
I don't suppose leasing is as attractive in Europe as it seems to be for a lot of folks here in the States? Some who can take advatage of tax breaks when using their vehicles for work are able to trade in every 2-3 years. maybe a short term lease would work for you until you save a little more money for a 2005-06 or something?
just some thoughts
Carl
1 Lucky Texan
Anyone else do the water cleaning trick?
Posted
In the old days we used Berrymans B-12 for that carb-sucking, choke it to stall with the last half bottle- routine. Tehn let it sit for a while. I guess the Berrymans would sit there and help loosen crap. I've heard of a guy that used beer!. It may just be the shock that knocks the carbon off. I suspect you'd get a good idea if it would help by looking for carbon/soot on your plugs first though.
Carl
1 Lucky Texan
