05 Impreza Speedo, Trans, timing Belt
1 Lucky Texan replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCrank pos sensor getting flakey? A VERY long time ago, I read of an STI owner that cleaned some debris (ferrous dust particles) from a CPS and it fixed some intermittent issues. Not sure why it wouldn't set a CEL...?
Searching for a transmission!
Be aware, if it's like the 5spd on my 06 WRX, the shifter is held on the shift shaft by 2 spring pins...1 INSIDE the other!
2006 WRX wagon clutch pedal
They replaced the slave. If they give me the old one, I might investigate rebuilding it and keep it with the other spares I have for the car. With fresh fluid and a bleed, maybe the master will be ok, if not, it's the onley thing left so, I might tackle it myself but really guys, maintenance and repair work is getting to be a challenge for me nowadays.
slave cylinder I had the mechanic do it since it was in for its inspection sticker. pricey, intercooler had to come off. thanks everybody
thanks folks. I forgot to mention there are no leaks/drips under the car.
since it pumps back up, I figured it isn't a cracked lever. The problem seems more hydraulic in nature?
Long time no write... After retirement, I rarely drive my wagon, after it sits for a while, I find the clutch pedal does not return after pressing. I CAN lift it and pump it enough to shift, then, after driving for a while, it starts behaving mostly normally. Anyone experience this? clutch master or slave cylinder????
2006 6DISC CHANGER PROBLEMS
1 Lucky Texan replied to CALHOONS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only issue I've read about in the past is a CD getting stuck/not ejecting and it causing enough drain to kill the battery.
1997 Subaru Outback major oil leak
1 Lucky Texan replied to Sakai's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis the oil pressure switch up top on that engine?
1992 Legacy loss of power at the pedal
5spd? maybe time for a clutch...
2000 Outback- lackluster performance
1 Lucky Texan replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXseems unlikely at low miles, but a bad knock sensor can keep timing retarded and kill performance. Might be the only sensor that doesn't need to be OEM. most folks report $25 units work fine if you don't overtorque them and make sure to route the cable from them in the same orietation.
2004 Forester Alternator $580?? Crazy
1 Lucky Texan replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow!!
20 plus years “on the drawing board.”
that diesel is short enough? there were some Subaru diesel crate engines available at one time, or source a used one from overseas? back in the 70s, folks were putting Kubota diesels in some small cars....... or maybe a Mazda wankel ?
05 STi Intermittent No Start
you might try 'popping' the clutch pedal 2-3 times next time it fails. maybe the safety switch on it is failing. Or the one on the brake pedal?
No reserve auction on BAT...1995 RHD Subaru Impreza Gravel Express
1 Lucky Texan replied to azdave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat spare has got to go. otherwise, it's awesome. Hip spoiler could look good....
P0420 - Replaced Cat and 02 sesnor, this thing won't go away.
1 Lucky Texan replied to phyregold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDenso or OEM (same?) is preferred for sensors. Folks sometimes report problems with aftermarket including Bosch.
1 Lucky Texan replied to phyregold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^ what he said - plus, the filler neck behind the plastic shield gets rusted-out holes.
Hard left turns engine stumbling and throws cat system engine code
one very long shot - I once read of someone that had intermittent problems when turning, they found a wire harness section routed near the steering u-joint was abraded and shorting out.
CEL U0073 Causes
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn the past, I've had spurious codes set, often with no driveability problems, on 2 different vehicles - that came down to weak/old/damaged batteries.
alternator swap
1 Lucky Texan replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think so. The H6es get ECU control of the alt. best bet, find a local rebuilder and have your original alt. rebuilt. unless of course, it was already given up as a core. car may be down a few days. or check into parts from DB electric or Maniac motors(?) in Texas. even an alt from a wrecking yard (must be H6) is preferred over any alt from typical parts retailer .
2002 Forester timing pulley failed
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXleak down test should tell you right?
1st Gen legacy wagon!
needs a 'Wagon Mafia' sticker
1 Lucky Texan replied to phyregold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXexhaust system leak? a:f problem?
Noisy EJ251 in '05 Outback
1 Lucky Texan replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes the noise get increasingly aggressive-sounding with increased rpm, or, does it kinda come-and-go ? if the latter, might be a weak tensioner.
Windshield Washer Jets Poor Spray Pattern
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXour old 2003 had a an angle/elbow that leaked. Felt sticky and fragile? easy repair with some kinda vacuum line assortment kit from VatoZone w'ever.
