October 9, 200916 yr Just noticed the right side light is very dim compared to the left. I took the light out of the headlight and put it in the left side and it is very bright. I also notice the left side dims, but the right side stays the dim light at all times. I have a grounding issue or a short. Does anyone have any suggestions, a headlight wiring diagram would be helpful, or any help. Thanks
October 10, 200916 yr Check the connectors that the lamps fit into, sometimes they deteriorate over time. For what it's worth, here's a thread from a few years back: http://www.ultimatesubaru.org/forum/showthread.php?t=41301&highlight=headlight+connector
October 10, 200916 yr just fixed one. one of your plugs are going bad. either replace or cleanup, either way use some dielectric grease for a better connection on both.
