holley/weber carb on ea82
hey guys, i need some advice. i am considering putting a holleyweber carb from a pinto onto an ea82 eng. i know i'll need an adapter, and have to adapt the linkage and choke. what i am wondering about is if there are any red light problems, such as jetting [will real weber jets fit ? ] etc. hopefully, someone has done this and can steer me in the right direction. thanks in advance.
I would steer clear of the Holley Weber. It's a DFV clone but they have extraneous stuff on them like bowl vent solenoids, etc. They also have smaller venturi's than normal DGV's making them of dubious upgrade potential. Then you would have to rejet it - not with the same jets as a DGV because of the smaller venturi's....Get yourself a DGV, peen a dent in the power steering reservior to clear the choke housing and call it a day.
thanks for your help gd. what i was hoping for was someone who had either done this successfully or had run into a drop dead problem. anybody ?
  • 3 years later...
hmm im going to hafta disagree the carb is a good carb ive pulled pintos out of the woods after sitting  10+ years  and put gas in them and drove them with out having to touch the carb they are solid and reliable  bigger than a Hitachi
