November 1, 200916 yr i have a 2000 legacy outback wagon- with 4.11 5spd trans. it took a superpoop i need to know what other transmissions i can put in, obviously must me another 411 5spd- but for example, a 99 forester 411 5spd- direct swap? im aware that they have different 1st05th gear ratios,i could care less- as long as it bolts in, throws no codes, and i dont need to modify axles or drivelines. please help asap- my car is down and i have small subie enthusiests that need to go to school
November 1, 200916 yr i have a 2000 legacy outback wagon- with 4.11 5spd trans. it took a superpoop i need to know what other transmissions i can put in, obviously must me another 411 5spd- but for example, a 99 forester 411 5spd- direct swap? im aware that they have different 1st05th gear ratios,i could care less- as long as it bolts in, throws no codes, and i dont need to modify axles or drivelines. please help asap- my car is down and i have small subie enthusiests that need to go to school Subaru 5 speed transmissions pretty much interchange over a fairly wide spread of model years. Just watch the rear diff ratio and whether it's a cable or hydraulic clutch (although even that can sometimes be converted). Check out the USRM for transmissions that would suit you. A Forester transmission would probably work just fine for you. Lastly, try to match up engine types (e.g. I wouldn't install a EJ18 transmission in your Outback even if it might fit). Edited November 1, 200916 yr by edrach
November 1, 200916 yr Author i have a factory transmission gear chart, both are listed as 4.11s with hydro push clutches. and all foresters came with an ej25, as did my outback...so in my mind its a swap- but as ive stated before, im an ea expert, not an ej
November 2, 200916 yr match gear ratios and clutch type and swap all day. i've heard people say you can interchange clutch/cable style trans but you'd have to deal with swapping all the linkages, cables, pedal stuffs, etc. and i haven't actually seen it done/confirmed.
November 2, 200916 yr match gear ratios and clutch type and swap all day. i've heard people say you can interchange clutch/cable style trans but you'd have to deal with swapping all the linkages, cables, pedal stuffs, etc. and i haven't actually seen it done/confirmed. I currently have a former WRX ('95 JDM version) transmission in my Impreza. Needed to convert a hydraulic to a cable type. Needed to change the clutch fork, move the pivot ball, remove the hydraulic stuff and install. Works great!
November 2, 200916 yr It sounds like this might be answered? as such, i have a similar but different concept question. What do people think about swapping an Aussie Forester (say 98-00?) 5MT into a USDM 95 Legacy? What issues concerns might i need to think about and look into more deeply? As I understand the AU FOR is 4.11, so i'll need a 4.11 rear diff, but otherwise will there be other concerns if FOR is 2.5 and my Leg is 2.2? If there are different bolting (bell housing) paterns, say FOR is 6 bolt but my Leg is 4 bot, would they still mesh where they overlap?? Thoughts continue, but looking for more heads' worth of Suby experience, and ideas I wouldn't think to concern myself with. Thanks! -mark- Edited November 3, 200916 yr by superu 4.22 corrected to 4.11 per edrach
November 2, 200916 yr It sounds like this might be answered? as such, i have a similar but different concept question. i'll need a 4.22 rear diff -mark- I'm sure this is a typo, but you'll need a 4.11 rear diff.
November 3, 200916 yr I'm sure this is a typo, but you'll need a 4.11 rear diff. Good catch! And yes that's what my fat fingers meant
November 17, 200916 yr i have a similar but different concept question. What do people think about swapping an Aussie Forester (say 98-00?) 5MT into a USA 95 Legacy? What issues concerns might i need to think about and look into more deeply? As I understand the AU FOR is 4.11, so i'll need a 4.11 rear diff, but otherwise will there be other concerns if FOR is 2.5 and my Leg is 2.2? If there are different bolting (bell housing) patterns, say FOR is 6 bolt but my Leg is 4 bot, would they still mesh where they overlap?? I have a cable (push?) clutch. Are AU FOR clutches cable (push?) or hydraulic (pull?)? Thoughts continue, but looking for more heads' worth of Suby experience, and ideas I wouldn't think to concern myself with. Thanks! -mark- bump
