November 15, 200916 yr Hello. I have a 1987 Subaru Brat (European version) with an EA81 engine, caruburettor, breakerless ignition system with the ignitionmodule inside the dist. One day I strted my car as usually, got about 50 m when it suddenly stopped. It was just like somebody had turned a switch. I stood still for about 30 minutes, without any kind of lifesign from it. Then suddenly it strted again. I got about 500 m, when it just stopped again. After that it hasn't started again. There is no spark, and no signal from the ignition coil. I have replaced the; distributorcap, and rotor. I have also tried with another ignition coil and cable between the ignition coil and the distributor. I suspect that it could be the ignitionmodule, but I haven't found any way to test it. According to my Haynes manual the resistance can't be chekked on my type of system. I also have another weird problem, at least I think it is a problem. When I remove the fuse for the fuelpump and turn on the ignition, the pump starts, but with the fuse in place, the isn't a sound from the pump. Does anybody have an idea of how I can fix it, could the fuel and ignition problem be related? I am very grateful for any tip. /Tobbe
November 16, 200916 yr If you have power at the coil (and it's good) and no spark from the distributor then your problem is very likely the ignition module. I would pick up a used distributor and give that a try. GD
November 26, 200916 yr Author Is ther any way to measure the ignitionmodule first, so that i really can see that it is broken before i look around for a used distributor. About my fuelproblem. Does anybody know how the fuelpump control unit work. Believe it is a relay of somekind that says cleaner cont on it. When I wire the fuelpump directly from the fuse to the pump it runs continuously, but with the correct wires connected it only runs for a short time when the fuse is removed. Electrical stuff is not my cup of tea so, any tip is welcome. If anybody has subarus original workshopmanual, i'd be gratefull if you could e-mail it to me.
November 27, 200916 yr The fuel pump control unit needs to see ignition pulses in order for the pump to run more than a couple seconds.No pulses=no fuel pump. Your ignition module is likely fried.They are sometimes sensitive to high resistance in the ignition secondary circuit.Check for a bad plug/coil wire and extra wide spark plug gaps before replacing it. The modules are a little difficult to test. If you have a known good one,you can compare readings between terminals using the "diode test" function of a digital multimeter. Easier test is on the car. As long as you have 12 volts at coil - w/key on,wiring is intact,and a test light that does NOT flash when connected to coil - while cranking,the module is bad. Take the disty cap off and check for play in the shaft too. Service manual http://www.finleyweb.net/JonsStuff/SubaruDocumentation/tabid/54/Default.aspx Edited November 27, 200916 yr by naru
November 27, 200916 yr I agree that the ignition module is likely toast. Hopefully, you have the Hitachi distributor where the ig module is relatively easy to replace. If you have a wrecking yard nearby you can pull just the module and know how to re-install it in your car.
