phantomcrooner Posted November 16, 2009 Share Posted November 16, 2009 I have an 87 GL Wagon with a EA82. Ometimes when I start the car it has no oil preasure and will start to ping. If I rev up the engine, the preasure gauge will move up to where it should be and stop pinging. It will idle without driping, but if I drive it a couple blocks and then look under the hood I can see oil flung all over the front of the engine and oil driping under the car. If i rev up the engine, the oil starts to run out from somewhere, then disipates after it goes back to idle. I think it is an oil pump seal but wanted to double check with you guys. Thanks, Chaz Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 16, 2009 Share Posted November 16, 2009 Pull the crank pulley and timing belt covers and locate the exact source of the leak. Could be the front main seal or an oil pump seal. GD Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 16, 2009 Author Share Posted November 16, 2009 I pulled the covers off and cannot tell where oil is coming from, it just throws oil around while running, and stops when i kill it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 17, 2009 Share Posted November 17, 2009 Most likely it's the front main seal then. That would throw a lot of oil - I've had them go out before. I sugest you just do a complete timing belt/water pump/front seal job on it. The kit's are gonzo cheap off ebay and it would be silly not to do everything while you are in there. Pull the oil pump as well and inspect it for damage - get a seal kit from the dealer.... sounds like you have a bit of lifter tick mixed in there as well so better safe on the pump and pump seals. When you do the water pump, also do the heater core bypass hose. It's a major biotch to get at if you have to change it later. GD Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 17, 2009 Author Share Posted November 17, 2009 Okay, thank you sir. I made a stupid agreement with my wife that if I did'nt have it repaired by the time we moved, that I would just get rid of it. When I said that I had two months before we moved, now I am down to a week and a half and am starting to freak out as I have no intention of getting rid of my car. I only need it to drive three hours, then I'm going to do an EJ22 swap in the next couple months. I just don't have much time to work on it before we go. I will do my best, thanks again. Chaz P.S. Yeah I know it was stupid, I made that agreement in the middle of an argument. Quote Link to comment Share on other sites More sharing options...
john in KY Posted November 17, 2009 Share Posted November 17, 2009 Pressure sender. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 17, 2009 Share Posted November 17, 2009 Have you ever done an EA82 timing belt before? It's about a 3 hour job if you have done it before and the belt covers are in place. Give yourself an afternoon if you have never done it before and make sure you have all the parts you need.... might want to just buy a new oil pump.... in case. GD Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 17, 2009 Author Share Posted November 17, 2009 yes, I have done them on my GL-10 Turbo, i couldnt figure it out, so took it to a mechanic who specialized in Subaru, Toyota & Nissan. He had it for a month and finally called me and said he did'nt know why it would'nt start. So I read the chiltons again and realized that i was turning the engine over 360 deg. instead of 180 deg. between belts, started right up. :-\ The covers are off permanantly, I have a splash guard underneath to keep junk out. It saves time in changing belts, which I do every 2 years. Plus i Keep a set in the car just in case. Hmm, i could check the sender, but I don't see any fresh oil on it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 17, 2009 Share Posted November 17, 2009 The sender wouldn't fling oil anywhere - nothing near to it that could catch and fling it. They just drip. Sounds like you are set then - just rip that sucker apart, replace some seals and the two pumps, and throw it back together. Should be able to do that in half a day. GD Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 17, 2009 Author Share Posted November 17, 2009 Sweet, thanks a lot for your help, i'll post once it's finished. Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 19, 2009 Author Share Posted November 19, 2009 I took off the oil pump and the mickey mouse gasket was split and mangled in 1 spot, it looks like the only reason it had not leaked before was because of the thin bead of rtv silicone it was installed with. I put new seals in and reinstalled the pump. I ran out of light tonight but plan on puting the crank pulley and timing belts on in the morning. Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 19, 2009 Author Share Posted November 19, 2009 Well, its not the pump gasket, or at least not entirely. As it turns out my older brother owned this engine and put the oil pump on with a used crushed gasket that he had pulled off another car and filled the gap with silicone. Any way I changed that hoping it was the prob. It appears that was not the problem, next stop, main seal, which should be fairly quick and simple I think. Just remove crank pulley and belt, pull it carefully and tap new one in with socket. Is there anything else obviouse that is could be? It is not sending unit either. Thank you. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 20, 2009 Share Posted November 20, 2009 Those are about the only two. The only one I've ever seen "fling" oil off the crank is the front main. GD Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 20, 2009 Author Share Posted November 20, 2009 Okay, The new main seal will be here tomorrow, so i tore the engine down to that point again. When I took the two sprokets off the crank, they were dry with no fresh oil and it does not look like it is leaking, directly under it though is the oil pump sprocket and the block around it has no grease just fresh oil. I am going to take the oil pump back off as I have found that I also have an oil pump shaft seal, it looks just like a main seal only smaller. Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 20, 2009 Author Share Posted November 20, 2009 The oil pump shaft seal was really worn, I think its the culprit, since I dont have the main seal yet, and i can put it back together in about 30 min I will see if this is it. As you can see it is really bad. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 20, 2009 Share Posted November 20, 2009 Interesting - yeah you might have something there. Make sure the shaft doesn't have a nasty groove in it where the lip on the seal was located. GD Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 20, 2009 Author Share Posted November 20, 2009 WOO HOO!! The oil pump shaft had no signs of wear, but that shaft seal was so loose i pulled it out with my fingers and it was hard as a rock. I know that the Mickey Mouse seal was leaking some since it was smashed flat and torn in one section and the shaft seal was leakingeven more. I did put it back together and drove it easy and no leaks, so i drove it hard for a couple miles and still no leakes. The crank shaft seal is still soft and plyable, so i'll just put it in the back with my spare timing belts. Thank you all for your help, I really appreciate it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 20, 2009 Share Posted November 20, 2009 Excelent - glad you don't have to get rid of the car! Always nice to know that all that stuff is new anyway. Good work on keeping at it till you found the issue. GD Quote Link to comment Share on other sites More sharing options...
CHIM Posted November 20, 2009 Share Posted November 20, 2009 Awsome, finally got her wuped!, rite on man. First time on in over a year, great now im gonna get addicted to the usmb all over again:banana: Quote Link to comment Share on other sites More sharing options...
phantomcrooner Posted November 20, 2009 Author Share Posted November 20, 2009 Glad you're back bro, notice how I blamed it on Mark? lol If it was'nt him it was his twin, ooooh, I just got a cold shiver. Quote Link to comment Share on other sites More sharing options...
CHIM Posted November 20, 2009 Share Posted November 20, 2009 Yeh well mark is to blame, besides i blame stuff on him all the time, it's just easyer that way. Quote Link to comment Share on other sites More sharing options...
